Am I missing anything for a suspension upgrade?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by INTERRUPTOR22, Dec 18, 2022.
  1. Dec 18, 2022 at 5:04 AM
    INTERRUPTOR22
    INTERRUPTOR22 [OP] Well-Known Member
    Port Hueneme, CA
    2017 tacoma TRD off road 4x4 Magnetic Grey
    BakFlip tonneau cover. Rexing front and rear dash camera. Leather seat covers Dessert Does it seat jackers TRD Pro Front grille OTT ECU 285/70/R17 Falken Wildpeaks AT3W. Methods 703 Bronze 0 offset Fox 2.5 with Remote Resi with DSC adjusters front and rear ICON Tubular UCA Cab mount chopped Superbump bumpstops with Ubolt Flip kit Meso customs interior black out kit with LED white/red map light and dome light and TRD shift knob with hidden buttons Kustom 45 headlights with rgb halo ring.
    Goal: Buy once, cry once suspension set up that can accommodate extra 350lbs of gear while still being a daily driver.
    Listing:
    Fox 2.5 Factory Coilovers with resi and dual compression adjusters front and back.
    Camburg X joint UCA
    OME Dakar Heavy Duty Leaf Spring kit
    Overland Torque tune
    Tire and Wheels:
    385/70/17 Falken Wildpeaks AT/3 load C type
    Method 703 bronze 17x8.5 | offset- 0/4.75"
    Anything else I missed or should think about, feedback is welcomed.
  2. Dec 18, 2022 at 5:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    You meant 285 for the tire, correct?
  3. Dec 18, 2022 at 5:51 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Might want get 2 degree axle shims, also you sure you want heavy duty leafs? With only extra 350lbs. I would do clam shell bearing right away. Assume you meant 285's, you probably will be doing some trimming for them to fit.
  4. Dec 18, 2022 at 5:52 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Recalibrate your speedometer for the larger tires. Otherwise your odometer and fuel computer will be off as well.
  5. Dec 18, 2022 at 5:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    So you recommend a Hypertech unit?
    Or do you have cheap tricks for this?
  6. Dec 18, 2022 at 6:20 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Hyper tech or rough country. They are the same unit.
  7. Dec 18, 2022 at 6:21 AM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    As mentioned, the ECGS bushing for the front diff while you're in there. Also consider extended rear brake lines. Not familiar with the extended length of those rear shocks, but they may allow enough travel to stretch/break factory lines in rear.
    Mark77 likes this.
  8. Dec 18, 2022 at 6:43 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Some things to think about.
    CMC (expect front end rubbing).
    Mud flap removal (rubbing).
    Carrier bearing shim (drive shaft angle).
    Extra Credit Reading: Big brake kit (BBK), and regearing
    Mark77 likes this.
  9. Dec 18, 2022 at 6:44 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Extra gas money.
    All good points above.
    Shims probably, 350lbs is not that much extra weight. Extended rear brake lines. Chop cab mount, lift doesn’t prevent rub. ECGS bushing. Alignment.
    I wouldn’t worry about the speedometer. I went up to 32” tire and the speedometer still consistently reads about 2mph less than GPS speed at 70mph.
    Mark77 and na8rboy like this.
  10. Dec 18, 2022 at 8:36 AM
    guest_707
    guest_707 Well-Known Member
    I just learned yesterday that some people do a sway bar relocate kit. This was for bilstein 6112s though so I'm not sure if it's applicable for your fox shocks.
  11. Dec 18, 2022 at 10:08 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    You sure those 285's are C Load?
    I may be wrong, but thought the only came in an E load in 285's??????
  12. Dec 18, 2022 at 2:01 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    replace needle bearing with bushing?
  13. Dec 18, 2022 at 2:03 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I'll ditch the OME HD for Deavers, stage 1
  14. Dec 18, 2022 at 5:39 PM
    SpeySquatch
    2016 TRD OR DCSB
    I second the above to ditch the Dakar pack and go Deaver, Icon RXT or Alcan.
    A much smoother ride will be the outcome…been there done that
  15. Dec 19, 2022 at 1:20 AM
    INTERRUPTOR22
    Port Hueneme, CA
    For all yes. 285's
    Okay are the deavers stage 1 that much more worthy and smooth? Experience?
    I can see about the shims for the axle
    Cab mount chop needed even with the 3" that I was planning on.
    Definitely good call on the speedometer calibration and wheel and tire calibration.
    What would the ECGS bushing fix or alleviate?
    Regearing to 4.88 wayyy later on though. Gotta save up for that.
