Am I missing some vacuum line?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flash1034, Mar 21, 2011.
  1. Mar 21, 2011 at 7:52 PM
    Flash1034
    Flash1034 [OP] Well-Known Member
    Southern California
    2003 SR5 TRD 4x4 Extracab 3.4 liter
    None
    I have a 2003 3.4l engine. When you open the hood and look at the top of the intake manifold, there is a hard vacuum line with nothing attached. Is there something missing? What is that hard line for?
    Thanks,
    Flash
  2. Mar 21, 2011 at 7:53 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Nope. You have DBW throttle body.
  3. Mar 21, 2011 at 7:55 PM
    Flash1034
    Southern California
    None
    Drive by wire?
    Flash
  4. Mar 21, 2011 at 7:55 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Crap you are missing something, but it's not that hard line. Just behind the right side of hte hard line there's a barb that goes into the intake manifold. That should be capped off.
  5. Mar 21, 2011 at 7:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yes...electronic...as in not vacuum based.
  6. Mar 21, 2011 at 8:55 PM
    Flash1034
    Southern California
    None
    Thanks. Are you talking about the barb pointing straight up on the right side of the picture?
    Thanks,
    Flash
  7. Mar 21, 2011 at 9:00 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yessir. That's the one. Put a cap on that. As it is now, you have a tiny vacuum leak.
    EDIT: I have DBW so the experts on the pre DBW throttle bodies might have to chime in but I think that is for the vacuum throttle opener. Can't swear to it thought.
  8. Mar 21, 2011 at 9:58 PM
    Flash1034
    Southern California
    None
    Thanks for the info. I really appreciate it.
    Flash
  9. Mar 22, 2011 at 9:07 PM
    Flash1034
    Southern California
    None
    Ive been running with that thing uncapped for thousands of miles without any symptoms. Its capped now and I dont see any difference. Any idea what i should have noticed from that unplugged port on my intake manifold? Just curious.
    Thanks,
    Flash
  10. Mar 23, 2011 at 8:57 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I bet if you pulled your spark plugs, it might look like you're running lean. Either way, the stock ECU is pretty good at adapting for from the driver seat you wouldn't have noticed any difference. Best case, you saved yourself a future check engine light.
  11. Mar 23, 2011 at 9:03 AM
    Flash1034
    Southern California
    None
    Thanks.
    Flash
  12. Mar 23, 2011 at 9:12 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    But it isn't drive by wire is it?
  13. Mar 23, 2011 at 9:42 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Sure it is. The later first gen Tacomas still have a hard line running to the pedal, but the traditional vacuum serveo thottle body is eliminated with electronics. That's what that electronic box is atached to the thottle body. Also note, there's no vacuum throttle opener.
    I believe you may be thinking of ETC (Electronic Throttle Control) in which the pedal itself is electric and eliminates the need for a physical cable. Toyota has done this with thier newer vehicles.
