Am I paranoid or is it my head gasket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Northern Taco, Mar 3, 2017.
  1. Mar 3, 2017 at 4:28 PM
    Northern Taco
    Northern Taco [OP] Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    so reading all these head gasket failures on 2005 Tacoma's got me checking mine. Here's what got me investigating. My CEL came on a couple times, once or twice while starting it wound over slightly longer than normal. Idles fine, no overheating.
    One concern I have is if I start truck with radiator cap off the coolant will slowly push up and overflow. However there are no bubbles at all, and all cases I've seen with bad head gaskets have bubbles in the coolant. Is a coolant system pressurized this way? I'm hoping its normal to have pressure in the coolant system as I don't want to spend thousands on dollars on replacing my head gasket.
    Anyone have any insight on whether this pressure, rising coolant with cap off (no bubbles!) is normal?
    I'll have mechanic hook up a code reader Monday when it goes in for pinion bearing replacement. Just looking to ease my mind in the meantime
    Thanks.
  2. Mar 3, 2017 at 5:09 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    what happens if you pull the rad cap off when the truck is fully warm (not over heated) and make sure to undo it slowly with a rag over the top. The coolant should stay inside.
    Id bet the slowly push up and overflow you are seeing is a result of the tstat being closed when cold.
    Are you experiencing any coolant loss?
  3. Mar 3, 2017 at 5:20 PM
    Northern Taco
    No coolant loss, overflow tank hasn't moved in last 1000km (how long I've owned it)
    Haven't tried opening rad cap with engine up to operating temp yet.
    I just got truck back from frame replacement last Friday evening, so it has fresh Toyota coolant.
