Am I reading this resistance result correctly?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Feb 13, 2023.
  1. Feb 14, 2023 at 9:59 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your measuring this with all the plugs removed from ECM like in your picture ?
  2. Feb 14, 2023 at 10:08 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    Voltage, no.
  3. Feb 14, 2023 at 10:09 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    What are you checking for Kristi?
    TnShooter likes this.
  4. Feb 14, 2023 at 10:58 AM
    Kristi with a K
    Western MA
    Anything off (not right). I have had a high, hunting idle for over a year. I have done all kinds of buttoning up (gaskets, hoses, etc). Checked various sensors. Replaced some. The latest was the TPS. It was definitely in need of replacement. Did that. All the settings line up meaning closed is 9.8, etc. Whelp, idle went up. Crap like that keeps happening.
    I don't throw codes very often. Usually only when I say, unplug something whilst the truck is running.
    I'll pass a smog check & then not. I did before I did the TPS & now I'm not.
    All that is the baseline for my frustration.
    & has brought me to here. One more thing though. My EFI fuse blew sometime last summer. I replaced it & the idle went down. Why did it blow though? Anyway, thought I'd see how to check the ECU, & logical or not, am now focusing on those things that share the B+ power & ECU ground wire & this is how I ended up here.
  5. Feb 14, 2023 at 11:47 AM
    Kristi with a K
    Western MA
    Thanks for this. One of the things I had done was clean up the engine bay grounds. Missed the one under the data link, though. Maybe it’ll help? We’ll see….
  6. Feb 14, 2023 at 12:10 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    If it can reach, probe a seat anchor bolt. Pretty sure those are clean and very well connected to the body.
    Oh, and make sure you stab it.
    Kristi with a K[OP] likes this.
  7. Feb 14, 2023 at 12:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Great advice.
    I will add, cheap meters don’t help either.
    I’ve had cheap meters show different readings just moving the wire to leads.
    I’m not saying you need a Fluke, but a good Klein or Craftsman Automotive meter is worth the investment.
  8. Feb 14, 2023 at 12:30 PM
    Kristi with a K
    Western MA
    So I have b+ at the ECU backprobed. No key. When I put it to body ground, engine bay or door, I get .76v. Coincidence that it’s the same amount of ground I am getting at the pos signal hot wire on the O2 sensor?
  9. Feb 14, 2023 at 12:35 PM
    Kristi with a K
    Western MA
    Still not sure if I’m supposed to get any ground at the pos signal wire. The neg signal wire is not hot.
  10. Feb 14, 2023 at 12:36 PM
    hamsmash
    hamsmash Well-Known Member
    Sacramento, CA
    00 Tacoma 3.4 4x4 5spd
    Why measure the voltage with everything off? If you're checking ground, I'd think you'd want to check resistance which should be near 0, or continuity to show that ECU ground is connected to body/frame ground.
  11. Feb 14, 2023 at 12:47 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I'm pretty sure B+ floats when key is out.. Almost 1V is a quite a bit but not worrisome yet. Without checking your wiring diagram, the O2 positive is probably floating as well. You should have very high resistance between a floating point and ground (ideally infinite), so if that's the high R you've been measuring, then it's fine.
    With truck running, these should be near-battery voltage when negative probe is grounded.
  12. Feb 14, 2023 at 1:30 PM
    Kristi with a K
    Western MA
    Should I have continuity from the B+ at the ECU to the B+ at the O2 sensor? I have ground to ground continuity.
    HondaGM likes this.
  13. Feb 14, 2023 at 2:06 PM
    TnShooter
    Deogee
    STOCK
    Yes, Both of those are powered by the same supply.
    The 20A EFI fuse feeds power to them through the EFI Relay.
    Bivouac and HondaGM like this.
  14. Feb 14, 2023 at 3:11 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    The manual is intending that you check the resistance at the ground for the component, not a random place on the chassis. Bad grounds are a notorious cause of electrical issues of all kinds, and it's very common for corrosion, especially when you have multiple connection points, to cause high resistance and subsequent problems. Disconnect the body ground for the ECEM, clean all the connectors and the body point, reconnect and try again. If you see anything green and puss-like (aka, "the green crusties") chances are good you've found if not all the issue, a big part of it.
  15. Feb 15, 2023 at 9:41 PM
    #35
    Kristi with a K
    Western MA
    There are .72v at terminal 3 (think I have that correct, the non-hot terminal - 30 or 87) of this relay (key off), which very, very slowly starts to decline when the relay is pulled. Also, anywhere from 3.-ish M ohms - 10.-ish M ohms. Fluctuates sometimes quickly, sometimes slowly. Seemingly no rhyme or reason. Pulling the main power outlet fuse has no effect on this terminal 3 voltage. It does cut off the hot terminal voltage, as it should.
    Seems to maybe be affected by my pulling the EFI relay, which is right next to it. Slows down the fluctuation. They are on different circuits as far as I can tell.
    Would I be correct in thinking that since there is no capacitor involved in this circuit that this should not be happening? (Should not be any reserve voltage. Not even sure if a relay can function that way).
  16. Feb 22, 2023 at 11:09 AM
    #36
    Kristi with a K
    Western MA
    I am getting continuity across pins 3 & 5 (load side) of the EFI relay at the box. No key.
    This should only happen with key at start or acc, correct?
  17. Feb 22, 2023 at 11:14 AM
    #37
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Yep, seems like it should not be connecting with power off.
    does it click when you switch the key back and forth?
  18. Feb 22, 2023 at 11:47 AM
    #38
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Someone above mentioned the use of a good quality meter, and I agree. For something as hard to track down as your issue seems to be, you can make it a lot less painful on yourself if you are using good equipment (and using it properly).
    Im always super cautious using the 'auto range' feature on any meter for any reason. Its very easy to mistake a reading of 0.9M ohms (0.9 million ohm or 900,000 ohms) for a reading of 0.9 ohms. The first being extremely high resistance (essentially an open circuit) and the later being very good conductivity.
    If I want to prove I have or test for continuity between two points Ill use the lowest Resistance setting on my meter (for example 200 ohms). In that setting I know whatever the meter displays is the value, in ohms. No k's or M's to worry about. If the value is higher than 200 ohms the meter will show something like Lo, -1, or nothing depending on what model / manufacturer. For the purpose of grounds, anything over a few ohms is probably a no-go anyway. If Im testing a certain component then I would set the meter to the next higher range. For example 2000 ohms setting for a 1.5k resistor, or the 20k setting for a 10k resistor.
    Hope that helps a bit.
  19. Feb 22, 2023 at 12:35 PM
    #39
    TnShooter
    Deogee
    STOCK
    Are you testing the relay?
    Or testing the terminals in the fuse box?
  20. Feb 22, 2023 at 12:41 PM
    #40
    Kristi with a K
    Western MA
    i’ll try that when I get home in a bit.
    At the box. No key.
