Am I reading this right?
Discussion in 'Suspension' started by PB65stang, Jan 9, 2010.
  1. Jan 9, 2010 at 8:25 AM
    PB65stang
    PB65stang [OP] Well-Known Member
    Patrick
    Kansas City
    2006 Infiniti M35x
    Hey guys, just as a disclaimer, I DID try and search and read about this before I posted, but...
    I'm looking at a set of 5100's all around to try and level out the front of my '09 DCab 4x4. This is the only lift I'd consider because I drive about 25,000 miles a year on the highways and this is basically for asthetics alone. I do a good amount of camping, but the roads and trails I'm on could be more than handled by the stock suspension.
    Am I right in thinking that the 5100's set at 1.75" in the front (and probably a set in the rear, but I know no lift there) will NOT require me to mess with UCAs or worry about much increased wear on other suspension components? Also, would this require me to run spacers on the front wheels, or is the lift not severe enough to need that? I can't risk worrying about too much increased suspension wear because I do drive so much, but I'd love to add a little lift to the front of the truck.
    Thanks for any help.
  2. Jan 9, 2010 at 8:30 AM
    rick
    rick `
    you will be fine with that set up
  3. Jan 9, 2010 at 8:41 AM
    PB65stang
    Patrick
    Kansas City
    2006 Infiniti M35x
    Thanks for the info. Are the wheel spacers a non-issue with the 5100s at 1.75"?
  4. Jan 9, 2010 at 9:09 AM
    rick
    rick `
    check the gap between your tire and uca. if it rubs then you will need spacers.
  5. Jan 9, 2010 at 4:11 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Will you be going to a wider tire on stock rims??
  6. Jan 10, 2010 at 3:22 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    Not an issue,Correct.:thumbsup:
    Only if you're going to use a wider tire on stock rims would you consider using a wheel spacer.
  7. Jan 10, 2010 at 8:38 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Yea i ran that set up for almost a year with no problem or buying anything else besides the shocks.
  8. Jan 10, 2010 at 9:23 AM
    thegrandpoohbah
    thegrandpoohbah Well-Known Member
    Fort Nelson, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Did you need to get an alignment done with that set-up?
