Am I screwed? Need opinion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KrnTaco08, May 4, 2019.
  1. May 4, 2019 at 9:58 AM
    eon_blue
    Azusa, CA
    You can drive on busted CV boots all day, worst thing its going to do is make a greasy mess. Those CVs should be replaced now anyway, and your front lift lowered to 2.5" max on a 4wd.
  2. May 4, 2019 at 9:59 AM
    KrnTaco08
    KrnTaco08 [OP] Well-Known Member
    LA
    2017 Taco
    Yeah. I will definitely decrease the preload this time.
  3. May 4, 2019 at 10:02 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    The angle on your axles is huge,no wonder they gave way.
    slomoe, Chew, Junkhead and 1 other person like this.
  4. May 4, 2019 at 10:06 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just drive it. I ran mine for 225000 miles. It never broke.
  5. May 4, 2019 at 10:10 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    :facepalm:
    OP- Don't drive it - get it fixed. You probably already spun out a lot of the grease. Its the difference between replacing just the boots vs replacing the axles because you drove it with dry joints.
    KrnTaco08[OP] likes this.
  6. May 4, 2019 at 10:11 AM
    KrnTaco08
    LA
    2017 Taco
    Yup. Lesson learned. Gotta crank down on the Kings.
  7. May 4, 2019 at 10:15 AM
    OnHartung'sRoad
    Then others are right though, angle is too much for OEM boots. There are some other threads here explaining this...
  8. May 4, 2019 at 10:16 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    just get new CV axles.. they're like $60 on rockauto.. you'll be fine as long as you're not driving through mud holes for the time being.. eventually the grease will all burn up/sling out of the joint, and they will start to click especially while turning/extending (droop) suspension.. they should be replaced sooner than later. I recommend a diff drop (spacers, and longer bolts)
  9. May 4, 2019 at 10:17 AM
    KrnTaco08
    LA
    2017 Taco
    I know the right thing to is to lower my angles. Would getting aftermarket boots be a better deal or just purchase oem?
  10. May 4, 2019 at 10:17 AM
    OnHartung'sRoad
  11. May 4, 2019 at 10:20 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    How about lower the lift to 2.5 inch. Diff drop I read on here does more harm than good on 3rd gens.
    stun gun and KrnTaco08[OP] like this.
  12. May 4, 2019 at 10:21 AM
    KrnTaco08
    LA
    2017 Taco
    They will be getting replaced next week for sure. Looks like a lot of grease came out and it’s all over the LCAs. My issue is that I’m currently at work and need to drive home which is an hour away. Trying to decide if it’s ok for now to drive and take it to my local mechanic.
  13. May 4, 2019 at 10:21 AM
    KrnTaco08
    LA
    2017 Taco
  14. May 4, 2019 at 10:23 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Drive it home, park it, buy boot kit, fix, lower preload while it's jacked up changing the CV boots. The angle is what caused this in short order, and it probably rides really bad with little down travel as it sits(CV angles and your UCA uniball misalignment spacer being basically maxed out tells me this thing is lifted to the point of basically being at full droop perpetually). It'll drive better guaranteed once the lift is decreased
    I've driven probably a 1000+ miles with a cracked boot. Just dont run it dry of grease completely, and don't drive in rain, snow, sand, etc. Clean roads only otherwise the CVs will be toast. And don't replace your factory CV axles with cheap parts store axles, they'll fail even sooner.
  15. May 4, 2019 at 10:23 AM
    #35
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    You have AAA ? A co worker maybe?
  16. May 4, 2019 at 10:25 AM
    #36
    OnHartung'sRoad
  17. May 4, 2019 at 10:28 AM
    #37
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    And this is why I dont mess around with lifts.
  18. May 4, 2019 at 10:28 AM
    #38
    KrnTaco08
    LA
    2017 Taco
    Awesome thank you. That’s what my local mechanic pretty much told me. Stay on dry roads and stay away from dirt, etc. gotta take it next week.
  19. May 4, 2019 at 10:28 AM
    #39
    KrnTaco08
    LA
    2017 Taco
  20. May 4, 2019 at 10:28 AM
    #40
    KrnTaco08
    LA
    2017 Taco
    Haha
    friendlywithbears likes this.
