Am I screwed? Need opinion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KrnTaco08, May 4, 2019.
  1. May 4, 2019 at 10:31 AM
    #41
    Taco 6x6
    Taco 6x6 Well-Known Member
    The SFV
    19 Taco 4x4 Off Road M\T
    Keep it on the road outta mud and sand....drive it home or for another week or two.....get it fixed....no harm no foul.
    Big tall dave and KrnTaco08[OP] like this.
  2. May 4, 2019 at 10:34 AM
    #42
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    I’d drive it.
  3. May 4, 2019 at 10:34 AM
    #43
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    If it’ll make you feel more comfortable driving it home, go to a local auto parts store and get some grease and lube it up so you don’t get metal to metal contact if the grease in there is already depleted. I’m sure you’ll be fine
  4. May 4, 2019 at 10:36 AM
    #44
    eon_blue
    Azusa, CA
    I would just put new CVs in...the joints inside the boots have been exposed to the elements and you don't know how long they'll last even if you replace the boots. The tiniest bit of dirt getting in there can severely compromise them.
    In order to change the boots you have to remove the axle anyway so you might as well just replace them.
    RTX Taco, mynewtoy and KrnTaco08[OP] like this.
  5. May 4, 2019 at 10:43 AM
    #45
    Hank Heel
    Hank Heel Well-Known Member
    WA
    If you’re getting these replaced, then driving on them is fine. You’ll just have to grab a can of brake cleaner and clean all the grease from underside.
  6. May 4, 2019 at 10:43 AM
    #46
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    I drove my 4Runner for 3 years with torn boots. Eventually the CVs started making noise. Still drove on the freeway at 70mph. One day I replaced both axle shaft. Dont worry about it and just fix it one day. Also a diff drop on 2nd and 3rd gen is a waste of money. Research this and you will see. Good luck with your truck.
    Jessrin, rlx02, mynewtoy and 4 others like this.
  7. May 4, 2019 at 10:47 AM
    #47
    Mully
    CA
  8. May 4, 2019 at 11:04 AM
    #48
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    YOU'LL BE FINE, Only when they start clicking should you worry (can damage bearings, and seals if they bind).. the clicking is a sign of low grease, and wear of the 3 ball bearings races against the cage/internals of the CV.. You could probably drive it a good 500 miles before they start clicking. just turn down the radio, open the window, and listen for any front end noises.
  9. May 4, 2019 at 11:08 AM
    #49
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    That upper ball joint is how mine looks when off the ground. You probably don’t have much if any droop.
    KrnTaco08[OP] likes this.
  10. May 4, 2019 at 11:12 AM
    #50
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    wrap the ripped boot with duct tape and drive very cautiously home
  11. May 4, 2019 at 11:16 AM
    #51
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Well, I can only speak from my experience with 36,000 trouble free miles on my lift that’s not the case. If it were wrong I’d be replacing shit like many others.
  12. May 4, 2019 at 11:18 AM
    #52
    eon_blue
    Azusa, CA
    When you're in 2wd the CV axles serve no purpose, there's nothing wrong with driving on busted boots in 2wd. No need to be cautious or anything like that. Just drive it home when you can and get them replaced.
    You'll need to lower your lift, high angle boots are just a band aid. The angles on the cv shafts are too severe and the axles/joints themselves are a lot more likely to break when under that kind of stress.
    Or put limit straps on your front end but that seems overkill unless you do a lot of hard wheeling
  13. May 4, 2019 at 11:20 AM
    #53
    BillsSR5
    bill
    2014 SR5
  14. May 4, 2019 at 11:37 AM
    #54
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    They all can go bad eventually, this is the reason why one should stick with 2wd’s...
  15. May 4, 2019 at 11:39 AM
    #55
    BillsSR5
    bill
    2014 SR5
    yes we can all see what that lift did for the OPs offroad capabilities, now he's off to spend a ton of money to get it repaired:thumbsup:
  16. May 4, 2019 at 11:41 AM
    #56
    OnHartung'sRoad
    they all can go bad, perhaps he should have gone for a solid axle mod with that 3” lift too. :)
  17. May 4, 2019 at 11:43 AM
    #57
    BillsSR5
    bill
    2014 SR5
  18. May 4, 2019 at 11:55 AM
    #58
    KILLINTIME
    KILLINTIME Like a Villain
    Drove mine everyday on the interstate for a year with my axels looking worse than that. Just because the boot is ripped doesn’t mean they are “broke” order some more and replace them, it’s not hard.
  19. May 4, 2019 at 12:21 PM
    #59
    KrnTaco08
    KrnTaco08 [OP] Well-Known Member
    LA
    2017 Taco
    I guess I should’ve rephrased my post to “ is this drive able on the freeway for one hour back home” Haha.
    I know these boots are torn. First time happening since lifting my truck over a year ago. Lesson I learned today: less pre-load.
  20. May 4, 2019 at 6:26 PM
    #60
    DaBears
    DaBears Well-Known Member
    CONUS
    10 trd sport
    Yes, your good to drive home. Fix it yourself or have a mechanic do it. Just as you had said previously.
