Am I screwed? Need opinion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KrnTaco08, May 4, 2019.
  1. May 4, 2019 at 11:53 PM
    #81
    supralee
    supralee Well-Known Member
    Lee
    Boulder, CO
    2018 Sandshark Tacoma DCSB 6MT TRD OR
    I agree, but I think they also say that lift on 3rd Gens should be limited to 2" inches for the TRD Offroads because they come from the factory with 1" already. But like I said, if the CVs aren't damaged from wear or debris you can rebuild them with new boots and reinstall. It's not difficult to do. This is your chance learn more about your Tacoma. Get the tools and parts you need and find out how to do the work.
  2. May 5, 2019 at 12:08 AM
    #82
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    That would drive me nuts.
    Chew likes this.
  3. May 5, 2019 at 12:28 AM
    #83
    Pax11B
    Pax11B Well-Known Member
    2017 Quicksand Tacoma TRD OR AC
    https://www.tacomaworld.com/threads/pax11b-quicksand-build.491885/
    I couldn't do it. If I get home and see a torn boot...I'll be up all night thinking about it and especially the clicking. But I can be old like that
    Pro-Taco[QUOTED] and kite_325 like this.
  4. May 5, 2019 at 5:47 AM
    #84
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It would be impossible to size the bearings. They are not roller bearings.
    Paul631 and Boghog1 like this.
  5. May 5, 2019 at 6:52 AM
    #85
    TacoLoco17
    TacoLoco17 Well-Known Member
    Craig
    Conshy, PA
    17 TRD OR DCSB Super White
    TRD Sport Hood swap TRD Exhaust TRD Intake TRD Skid plate TRD Pro Faux grille w/ Raptor lights MORIMOTO XB LED Headlights Rigid D series Fog lights Rigid E series 20” lightbar Spot/Flood MESO Ultimate Turn signal MESO Stage 1 Tailights 3x Remote Start Hypertech In-line Speedo Calibrator OV Tune Bilstien 6112/5160 Set at 5/6 OME Dakar Medium Leaf Pack Pioneer Avic 8400 NEX Headunit Infinity Reference 6x9s Front 6.5"rear Kicker Subaru Tweeters JL Audio Stealthbox w/ JL Audio RD500/1 amp ARE CX series cap Toyota OEM Trifold Hard Tonneau Body Armor HiLine Front Bumper Smittybilt X20 Gen 2 10K Winch SCS Ray 10 17x8.5 Gunmetal Rims 275/70 Falken Wildpeak AT3W tires
    They break, not seize. if it did break problem would be the shaft clanking around and could cause damage if it does break. like others have said if it’s not clicking it’s definitely safe to drive just no 4wd and take it easy
    KrnTaco08[OP] likes this.
  6. May 5, 2019 at 7:04 AM
    #86
    KrnTaco08
    KrnTaco08 [OP] Well-Known Member
    LA
    2017 Taco
    That’s good to know information. Thanks
    tcjacado likes this.
  7. May 5, 2019 at 7:04 AM
    #87
    KrnTaco08
    LA
    2017 Taco
    Good to know. Thanks. Learn something new everyday.
  8. May 5, 2019 at 7:05 AM
    #88
    KrnTaco08
    LA
    2017 Taco
    Yeah I know. I’m Not going to dealership though. Heading to my local 4x4 shop after work
  9. May 5, 2019 at 7:36 AM
    #89
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    Just one reason i want to do the straight axle conversion.
  10. May 5, 2019 at 7:48 AM
    #90
    Doc1303
    Doc1303 Well-Known Member
    '16 TRD Sport 4x4 DCSB Barcelona Red
    Just curious, how long did you have the 3" lift for?
  11. May 5, 2019 at 7:50 AM
    #91
    KrnTaco08
    LA
    2017 Taco
    Over a year.
  12. May 5, 2019 at 8:31 AM
    #92
    KrnTaco08
    LA
    2017 Taco
    Question for King owners, how many clicks are you guys running for the driver and passenger side?
    My was 15 drivers, 13 passenger. Thanks
  13. May 5, 2019 at 8:43 AM
    #93
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    No need to replace the Axles. Remove, disassemble, degrease, clean, reassemble with a fresh boot kit. Your issue is the CV angle. You have too much lift in the front and/or not enough lift in the back. Lower the front a bit and throw in a diff drop, easy fix.
    Your shafts are fine, but fix the underlying issue.
  14. May 5, 2019 at 9:07 AM
    #94
    KrnTaco08
    LA
    2017 Taco
    Yeah for sure. I didn’t think about lifting the rear more. I do have a full OME leaf pack. Can I add a leaf to my existing leaf pack?
    I apologize for all the questions. I’m a noob when it comes to lifting.
    19d? Scout?
  15. May 5, 2019 at 9:16 AM
    #95
    dustin19d
    Dustin
    Washington
    How is the stance of your truck? Does it look level or is the front high? Post a side picture.
    Sure you can add a leaf into your pack, I did that with my AllPro 3" pack. Probably easier to just drop the front a bit and throw in a diff drop. Diff drop's are cheap and easy to throw in.
    Used to be, 19Z now.
    KrnTaco08[QUOTED][OP] likes this.
  16. May 5, 2019 at 9:17 AM
    #96
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    In all honesty lowering the front is a way better idea than lifting the rear. The amount of problems going from 2.5" to 3" just isn't worth it.
  17. May 5, 2019 at 9:23 AM
    #97
    eon_blue
    Azusa, CA
    Wrong. Those "fucking things" don't seize and even if the bearings did, how is that going to stop the shafts from freely spinning in 2wd. Ive broken CVs and even with a broken inner tulip joint the thing still spins in 2wd like normal.
    medic2230, KrnTaco08[OP] and koditten like this.
  18. May 5, 2019 at 9:36 AM
    #98
    KrnTaco08
    LA
    2017 Taco
    Yeah the front is a lil higher than front. Ill probably bring my kings down to 10 threads? Currently at 15.
    Like I mentioned before, I heard more bad then good when it comes to diff drops on our trucks. That’s why I never did it. But maybe if I had it done I wouldn’t have torn CV boots?
  19. May 5, 2019 at 9:37 AM
    #99
    KrnTaco08
    LA
    2017 Taco
    Yeah the front will be getting lowered for sure.
  20. May 5, 2019 at 9:43 AM
    #100
    eon_blue
    Azusa, CA
    Diff drops don't really drop the diff at all, they just tilt it forward a bit. They really don't do anything if you ask me, I put one on my truck and it didn't make any difference in boot angles.
