Am I the only one? Post your unique mods or custom fab (all gens welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by adk_tacoma, Jan 24, 2018.
  1. Jan 29, 2018 at 1:33 PM
    #101
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    No all four catalytic converters are gone I used URD's power extractor pipes as they're called for coming off the engine block then had the Y pipe (also from URD's site) modified for enough spacing for welding the pipes (you'll see where the cut was made in pic four) that then run to the resonators I don't have a write up for this and I had a shop do the welding though I was there for the whole process it's actually pretty simple as only an inch to inch and a half was cut out of the Y pipe also the tabs (you'll see what talking about in the pics) to allow for the spacing from there it was just a few cuts of the straight piping and welding everything in.
    Grumpy and su.b.rat[QUOTED] like this.
  2. Jan 29, 2018 at 3:01 PM
    #102
    su.b.rat
    su.b.rat broken truck
    right on. well i was figuring the actual exhaust part wouldn't be too hard to wrap my head around... but what about codes, driveability, tune/throttle weirdness, and emissions, etc or whatever you can comment on? and any driving/motor improvements? i run the OV tune for the MT and it's great, but i also know there's more available, particularly in terms of throttle response & modulation.
    shakerhood likes this.
  3. Jan 29, 2018 at 3:32 PM
    #103
    Venator_2033
    I also run OVtune but mines an AT so v1.02c shift map a (Can't wait for v1.03 to finally be out of testing) can't really comment on driveabilty yet as it's been quite cold here in Michigan since install temps have been from the single digits to low 50's so on the cold days the truck runs like crap barely able to hold even 5th gear on the highway going 60 and with it poor mpgs as well typically 14 to 15mpgs this is also with a 4inch lift and heavy 33's, however on the few days it's around 50 to 45 degrees it runs quite well going up small hills and other slight inclines in 5th with just a bit of extra throttle also without losing any speed and average between 18 to 19mpgs.
    The codes it's showing are P0420 and P0430 both say Catalyst system efficiency below threshold bank 1 for 420 bank 2 for 430.
    su.b.rat[QUOTED] likes this.
  4. Jan 29, 2018 at 4:07 PM
    #104
    CO_0321er
    CO_0321er Well-Known Member
    My storage system for camping and cooking.
    Not really Fab work... but home made
  5. Jan 30, 2018 at 5:36 AM
    #105
    adk_tacoma
    adk_tacoma [OP] Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    that looks familiar, is that a westin brush guard?
  6. Jan 30, 2018 at 6:32 AM
    #106
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Yes sir it sure is coated in bedliner
  7. Jan 30, 2018 at 9:29 AM
    #107
    watkins303
    watkins303 Well-Known Member
    Travis
    Orange
    2017 White Sport
    AthensTac, 8675Tree09, Phoosa and 5 others like this.
  8. Jan 30, 2018 at 10:51 AM
    #108
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    63 swap and shock relocation.
    [​IMG][​IMG]
    Stocklocker, Phoosa, Mr-Paul and 2 others like this.
  9. Feb 2, 2018 at 12:31 PM
    #109
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    Around 2 months ago I installed larger wheels and tires and noticed about a 2 MPG decrease. After trying to think of some ways to get back some of that mileage I decided to design and build a pan to go under the truck to decrease drag and increase my MPG. Three days ago I posted in another thread since I wanted to post it the actual day that I installed it. The following link will give you a much more detailed write up.
    https://www.tacomaworld.com/threads/what-have-you-done-to-your-3rd-gen-today.399305/page-3812
    See post#76236.
    The trip information is from a trip that I have made around 25 times in the last 2 years. I was averaging 24-25+ MPG before the new wheels and tires but it dropped to 22-23 MPG after. You can see that my MPG on this trip was 25.5 MPG. I will be making this trip another 10 times in the next few months to get a more accurate average but I am very pleased with the preliminary results. This trip is almost 90% highway on I-95 in Florida which is about as flat as you can get. I usually drive with the flow of traffic in the middle lane which is 75-80 MPH. I do not expect the city driving MPG to be very different because the effect of drag is much less.
    a400ryan, Guerrilla, mackb and 7 others like this.
  10. Feb 4, 2018 at 7:26 AM
    #110
    adk_tacoma
    Joe
    Waterford, NY
    how thick is the metal you used? That looks like it would help keep debris out of your chassis.
    skyking3[QUOTED] likes this.
  11. Feb 4, 2018 at 9:51 AM
    #111
    skyking3
    Tom
    I used 3/32 inch or .090 inch of 5052 grade aluminum sheet. It is thick enough to prevent rocks being spit up on the road from denting it but not so thick as to add any unnecessary weight. It is not a substitute for an off-road skid plate but it will give some protection. My only purpose was to improve my MPG.
    Grumpy likes this.
  12. Feb 4, 2018 at 6:26 PM
    #112
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    whew, I'm glad I scrolled down. At first I thought it was an anal plug. You know, one of those sleeper performance mods no body sees, but they FEEL the difference.
  13. Feb 5, 2018 at 4:14 AM
    #113
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Everything is an anal plug, if you're brave enough.
    Gator352, Joe23, Sean73T and 7 others like this.
  14. Feb 6, 2018 at 11:04 AM
    #114
    adk_tacoma
    Joe
    Waterford, NY
    how has it held up? ( rust, collision and such)
  15. Feb 6, 2018 at 3:51 PM
    #115
    SR5 BRI
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Really well two years old and no signs of wear. I have had them on my trucks before and the guards do start to show rust. The BEDLINER I used is called ONYX it is a lot rougher than others
    adk_tacoma[OP] likes this.
  16. Feb 9, 2018 at 3:48 PM
    #116
    adk_tacoma
    Joe
    Waterford, NY
    have you ever hit a deer with one?
  17. Feb 9, 2018 at 5:02 PM
    #117
    SR5 BRI
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    No what town do you live in up there
  18. Feb 9, 2018 at 5:31 PM
    #118
    UplandExplorer
    UplandExplorer Level of crazy: Chukar Hunter
    Turbine Tommy aka Mr.Pickles
    Nor Cal
    2017 White TRD OR DCSB
    mud, bugs, feathers, and dog hairs.
    This looks great! Do you have a write up on this? Any specs? Part numbers? Do the drawers pull all the way out and utilize all of the space under the deck?
  19. Feb 9, 2018 at 7:30 PM
    #119
    spearfishingkid
    spearfishingkid Well-Known Member
    James
    2016 White Tacoma TRD OR
    How do you get 25 mpg on I-95??!! I drive it pretty often and average AT BEST 18 doing the flow of traffic.
    olecoot likes this.
  20. Feb 10, 2018 at 12:43 AM
    #120
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
