Am I the only one who thinks gas tank seems SMALLER than advertised?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SteelerJim, Nov 10, 2018.
  1. Nov 10, 2018 at 6:31 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    3 gallons may seem like an excessive reserve but for me that's only 75 miles which some places isn't far enough. Nice to know 30-40 is worry free when the light comes on.
  2. Nov 10, 2018 at 6:50 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Way past zero. 20.2 gallons to fill.
  3. Nov 10, 2018 at 6:57 PM
    tcjacado
    tcjacado Well-Known Member
    I have had to put 21 in. Forgot I was out of gas when I got home Friday after work. Got in it Monday and started driving, hoping I would make it to the gas station I use. A couple of miles around here can mean the difference of 50 cents a gallon. I made it..... but it took a real full tank. Not 17. Lol
  4. Nov 10, 2018 at 7:06 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    That’s not true for the majority of vehicles, including the Tacoma. It’s very dependent on the fuel pump used and how it’s setup in the tank. Running it empty then only filling it up to 1/4 then run to empty again, do that constantly and I’d agree with you, it’s not great for the pump. But run it to empty then fill up it’s fine and exactly how it’s designed to be used.
    tonered and SteelerJim[OP] like this.
  5. Nov 10, 2018 at 7:09 PM
    mutely
    I’ve run mine to 45 ~ 50miles passed 0 several times and get about 20gal in the tank. So I’d say a little more than 3gal, maybe 4. But 3 is close enough.
  6. Nov 10, 2018 at 7:17 PM
    mutely
    This gets 6, 8 if I take it easy, and has the same size tank as the Tacoma. But it does have 2.5 times the HP and just over 2.5 times the Torque of the Tacoma.
  7. Nov 10, 2018 at 7:22 PM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
  8. Nov 10, 2018 at 8:16 PM
    Nick13
    Nick13 Well-Known Member
    Dominic
    2017 sr
    This falls under the smiles per gallon clause:burnrubber:
  9. Nov 10, 2018 at 8:17 PM
    Nunya Bizness
    I know its definitely not as good as my other (now broken and dead) vehicle. But that's not the tank size. That's the engine and mpg. The other would display 530miles to empty when full.. the Tacoma only shows a lil over 300 and it has a bigger tank. But again mpg is the difference there.
    SteelerJim[OP] and tcjacado like this.
  10. Nov 10, 2018 at 8:20 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    I ran mine well past "empty" one time and put 21 gallons in. Butt puckering.
  11. Nov 10, 2018 at 8:28 PM
    Mcsosgt110
    Mcsosgt110 Well-Known Member
    Northern California
    2016 Trd offroad
    In the works
    I am surprised no one has said it's Trump's fault yet. On a serious note my understanding with some vehicles is that if depends how far the filler tube goes into the tank. Sometimes the manufacturer will purposely place it further in the tank so topping off does not happen like some of us do. Fuel pump makes sense. Who knows my 16 offroad says 384 miles till empty when full. I have taken it 16 mi left on one occaision.. Took 19.5 gal or so.
  12. Nov 10, 2018 at 8:28 PM
    medic2230
    Murph
    Bama! Roll Tide
    I’ve run mine down to the middle of the E. Put in 20.5 gallons.
    Use to do the same with my first gen. Still working just fine at 209k when I traded it in.
    tonered likes this.
  13. Nov 10, 2018 at 9:45 PM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    I don't understand the fuel pump thing either. It's always brought up on forums. Isn't the fuel pump cooled by the fuel running through it, not the fuel surrounding it. There is no way Toyota or other makes would design pumps to fail unless you kept the tank 1/4 filled or more. You would hear of failures all the time if that was the case.
  14. Nov 10, 2018 at 10:06 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  15. Nov 10, 2018 at 10:14 PM
    #35
    Bishop84
    Bishop84 Well-Known Member
    No tank can be fully filled, vapor prevents this. I imagine cold days fill higher than warm.
    I married my tacoma likes this.
  16. Nov 10, 2018 at 10:17 PM
    #36
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Sure, but how much? Enough to drive 100 yards further on a cold day?
  17. Nov 10, 2018 at 10:20 PM
    #37
    Tacomike18
    Tacomike18 Well-Known Member
    J
    When the dealer first gased up my 18 tacoma, it said 385 miles til empty, then after I filled it up it said 373, then 360, now it just says 330 or if im lucky 355. I have no idea why, I just go by the needle now.
  18. Nov 10, 2018 at 10:25 PM
    #38
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    Disconnect the battery and it’ll change.
  19. Nov 10, 2018 at 11:29 PM
    #39
    bagleboy
    Scott
    Norcal, Santa Rosa
    Gas is metered based on a 60F baseline volume. At 100F you end up with ~3% less by weight and at 32F ~2% more. It's volume is not temp stable. Fuel temp affects fill volume more so than the air temp in the tank. Underground tanks take longer to heat up during the day but still, buy in the morning when you can.
  20. Nov 10, 2018 at 11:41 PM
    #40
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    been there....done that too.....after gassing up, went and got some Prep H :)
    Alesimo[QUOTED] likes this.
