Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. May 9, 2016 at 8:43 AM
    #2081
    O906
    O906 Well-Known Member
    It can be both. However the station has to have both separate parts a Igate and a digipeater.
    Igates will only allow a packet to hop if the packet specifically calls for it to do so. Any packet that reaches an Igate otherwise will be terminated and sent to the APRS servers.
    gray223[QUOTED] likes this.
  2. May 9, 2016 at 12:36 PM
    #2082
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    There's also the question regarding the amount of hops specified by the originating station. Digipeters, when they transmit, can have their aprs transmissions rebroadcast on other digipeaters too depending on how many hops are requested which is likewise interesting to note.
    Some people request FM only rebroadcast vs having their data transmitted through APRS IS systems to keep their information private.
    gray223 likes this.
  3. May 9, 2016 at 12:45 PM
    #2083
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    They usually are their own.
    iGate is a receiver connected to the internet to forward messages to their source.
    Digipeater is a receiver/transmitter with the sole task of rebroadcasting messages it can hear. Of course it looks at hops and such before deciding to forward it.
    EDIT: I see I was slow to respond.
  4. May 9, 2016 at 12:52 PM
    #2084
    kalieaire
    Santa Clara County
    It's ok Chip. :p
    Chipskip[QUOTED] likes this.
  5. May 9, 2016 at 1:02 PM
    #2085
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Digi and iGate are two separate functions, but can be combined into the same device. Here is one example:
    In my area many digipeaters on mountain tops, are stand alone digis. The iGates are usually located in areas where fixed line internet is readily available, like a school, somebody's house.
    However, some radios like the Kenwood TM-D710GA can function as a stand alone digipeater. And It's also capable of iGate terminal operations if connected to a computer with internet.
  6. May 9, 2016 at 1:06 PM
    #2086
    Crom
    Nick
    San Diego, CA
    Millions
    What do you set the path to so that packets are not iGated? Also let's be more clear, sans encryption, nothing in amateur radio is private, and nobody using it should ever have any expectation of privacy. :) Would not want to mislead anyone. :)
  7. May 9, 2016 at 6:29 PM
    #2087
    kalieaire
    Santa Clara County
    The expectation of privacy with regard to APRS is identical to the expectation of privacy that comes with urinating on a bush.
    gray223 likes this.
  8. May 9, 2016 at 7:03 PM
    #2088
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Reported for politics :D
    ebbs15 likes this.
  9. May 9, 2016 at 10:48 PM
    #2089
    kalieaire
    Santa Clara County
    Do whatever you want. as long as it doesn't include coming around to look at my penis while I'm peeing.
    teamhypoxia[QUOTED] and ebbs15 like this.
  10. May 10, 2016 at 4:45 PM
    #2090
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    There's an interesting Overland use case for APRS as well.
    Let's say @teamhypoxia, @ebbs15, @chenbro and I are all going out to drive the Rimrocker Trail. I give each of them a dedicated APRS transmitter, with my callsign (even though technically all of the above have their own license.) and set them up to transmit on 432.400mhz with an SSID of "TeamHypoxia, EBBS15, or CHENBRO" and then in the comment section I put my call sign.
    Now, I also put an APRS transceiver in my truck, with a display, and xastir, or another APRS mapping software. I've effectively created my own, contained "caravan tracking" system. Because APRS stations are technically under "Automatic Control" a license isn't needed to operate a vehicle with an APRS transmitter onboard. It's just a Licensee must be responsible for the setup and operation of the stations.
    Crom, gray223 and ebbs15 like this.
  11. May 10, 2016 at 4:50 PM
    #2091
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    now could you do the same thing only have us use our own dedicated APRS transmitter? by that I mean, could each of us be able to pull up the "caravan" on our own APRS transceiver with display?
    also, how hard is it to set that up... is it simple enough to program say while you're airing down for a trail, or would it need to be programmed from a computer the night before?
  12. May 10, 2016 at 4:54 PM
    #2092
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    Least common denominator would be something like the Baofeng plugged into aprsdroid. At which point all you really need to do it tweak the frequency on the HT to $Anywhere but 144.390mhz.
    I'd have a bit harder time since my Microtrak RTG requires a serial cable and laptop to program it's frequency, but I'll have all that crap in the truck with me anyway. :)
    Crom and ebbs15[QUOTED] like this.
  13. May 10, 2016 at 4:54 PM
    #2093
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    @Lars great timing... just got my Call Sign.
    KE0JBH :rockband:
    Crom and Lars like this.
  14. May 10, 2016 at 4:55 PM
    #2094
    O906
    Yes you could.
    It's rather technical to setup, the software he mentioned Xastir I have used it quite a bit but most certainly not plug and play.
    You could do this setup with APRSdroid running on an Android Tablet and the Moblinked TNC mentioned a few times before here also. Although this would be a much more basic setup than using Xastir and a laptop.
  15. May 10, 2016 at 5:02 PM
    #2095
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    That's why I was using "me" as the example. I've been working on a Raspberry Pi based APRS iGate/Receiver using an RTL-SDR as the receiver. You're exactly right about APRSdroid doing all the work out of the box.
    The Moblkind "box" isn't even really necessary, if you're willing to run a cable to the radio. APRSdroid functions as a software TNC, you just need to get audio to and from the radio into the 3.5mm jack on the phone. 90% of their device is effectively a bluetooth headset and battery, minus the speakers. :)
  16. May 10, 2016 at 5:03 PM
    #2096
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    APRSdroid will not transmit and receive APRS data though, it will only put it on the APRS-IS servers correct?
  17. May 10, 2016 at 5:05 PM
    #2097
    O906
    I built my own cable once when APRSdroid came on the scene and tried to get it working as a software TNC but it was buggy. I think it was more to do with the phone vs the software though.
    I might pickup the new version of the Moblinked TNC and setup APRS differently in this new Tacoma I just bought. My previous setup was a TX only using a hardware TNC from Argent data systems. I think I'd like to setup a 7" tablet riding in a RAM mount running APRSdroid.
  18. May 10, 2016 at 5:06 PM
    #2098
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    Not true at all, in the Connection Protocol I'm pretty sure if you put it into AFSK via Speaker/Mic mode it does EXACTLY what it sounds like.
    It also supports Bluetooth TNC, which is the mode used by the mobikind.
  19. May 10, 2016 at 5:06 PM
    #2099
    O906
    APRSdroid can be a complete software TNC. You can hook your smartphone directly to a radio with a VOX function and a special 3.5mm audio cable and it will send and receive APRS packets or just RX or just TX, or just act as an iGate. Whatever you want.
    Lars likes this.
  20. May 10, 2016 at 5:08 PM
    #2100
    gray223
    SE Missouri
    2014 Tundra Limited
    Oh cool. So really to use APRS you only need a radio plugged into my phone running APRSdroid?
