Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. May 10, 2016 at 5:09 PM
    #2101
    O906
    O906 Well-Known Member
    Yup and a special made 3.5mm cable.
    gray223[QUOTED] likes this.
  2. May 10, 2016 at 5:14 PM
    #2102
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    minor correction..... a radio with VOX.... but otherwise 100% accurate.
  3. May 10, 2016 at 5:17 PM
    #2103
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    do you know if the yaesu ft270 have VOX
  4. May 10, 2016 at 5:20 PM
    #2104
    O906
    99% of all radios have VOX. Vox is just TXing automatically when the radio hears audio.
  5. May 10, 2016 at 5:21 PM
    #2105
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    doesn't look like it, but I could be wrong.
  6. May 10, 2016 at 5:22 PM
    #2106
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    there's an optional Yaesu VOX Headset (VC-24) according to the manual, so maybe it does.
    gray223 likes this.
  7. May 10, 2016 at 5:36 PM
    #2107
    O906
  8. May 10, 2016 at 5:44 PM
    #2108
    O906
    And here you can see the map of APRSdroid and how just standing out in my front yard I was able to map another APRS user.
  9. May 10, 2016 at 6:00 PM
    #2109
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    I just ordered a cable from mobilkinkd for my VX-7R, as well as a magnet mount 2m SMA antenna from Byonics.
    This coupled with the One+ Android Phone I've got (with no SIM) should make a good loaner APRS rig. In addition to being able to pretty easily put it in my wife's car (KC9QKY) if/when we take that on road trips.
  10. May 10, 2016 at 6:02 PM
    #2110
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
  11. May 10, 2016 at 6:08 PM
    #2111
    O906
    Yea a few years ago when APRSdroid was first released. I don't remember the exact pinout but it's very simple.
    Radio audio out -> Phone min in
    Phone audio out -> Radio mic in
  12. May 10, 2016 at 6:24 PM
    #2112
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Thought you had to add resistors and a capacitor to make it work?
  13. May 10, 2016 at 6:26 PM
    #2113
    O906
    I don't see how a capacitor would do anything but I could see how a resistor might lower the audio DB but it's not needed.
  14. May 10, 2016 at 6:34 PM
    #2114
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
  15. May 10, 2016 at 6:39 PM
    #2115
    O906
    Yea the cable works as it should.
    On the site the author says
    "The idea is to mute the audio slightly because amplified earphone output being wired straight into amplified microphone input is a surefire way to transmit nothing but distortion."
    APRSdroid has the ability to use your phones audio demodulator to clean up the audio output so building a cable with the resistors in it isn't always a necessity.
    Also on the simple side of things you can just turn down your volume on your phone... I seem to remember when I first tried it using an older motorola X I had to lower the volume quite a bit to get it to work.
  16. May 10, 2016 at 7:49 PM
    #2116
    gray223
    SE Missouri
    2014 Tundra Limited
    Google isnt showing anything that says it does. And i though it was a dual band radio... its a 2m band only. Now I don't know what to get. Any other good waterproof handhelds out there that arn't crazy expensive?
  17. May 10, 2016 at 7:51 PM
    #2117
    O906
  18. May 10, 2016 at 7:53 PM
    #2118
    gray223
    SE Missouri
    2014 Tundra Limited
  19. May 10, 2016 at 7:59 PM
    #2119
    G.T.
    G.T.
    CONUS
    Yeas FT-857D is backordered until sometime in June... :mad:
  20. May 10, 2016 at 7:59 PM
    #2120
    O906
    I have a few different models of the Baofeng's and they all work exactly like you'd expect a HT to work. After using them you'll never even need or want to buy a more expensive HT. The newest baofeng's are even better than the old ones.
    gray223[QUOTED] and G.T. like this.
