Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Aug 9, 2016 at 8:08 PM
    #2441
    O906
    O906 Well-Known Member
    That's rough!
  2. Aug 9, 2016 at 8:21 PM
    #2442
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    How did I miss this thread? VA3JME here.... 73's!
    Chipskip, CO MTN Steve and BenMara like this.
  3. Aug 9, 2016 at 8:23 PM
    #2443
    O906
    The volume will only affect packets received by your TNC.
    I still think the packets leaving your radio aren't making it to the iGate whole. With packets they go from A to Z (metaphor) and if any letters in between are missing the whole packet fails.
    Wish I could help more but I've never had one of those moblinkd setups in my hands. I use a one way tracker paired with a HT and amplifier for APRS in my last truck and I'll be installing it in the taco soon.
    This is what I use, not as slick as mobilinkd but a lot simpler.
    https://www.argentdata.com/products/otusb.html
  4. Aug 9, 2016 at 9:40 PM
    #2444
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    So how do you know if you are reaching a repeater? I have one typed in and the radio isn't going into RX. But when I transmit for a second, right after the radio is RXing for just a split second. So am I getting to the repeater? Is it getting to me?
    And when I'm looking up a repeater and it has a PL tone or a CTCS, do I put that frequency in both my transmission CTCS and my receiving CTCS.
  5. Aug 9, 2016 at 9:42 PM
    #2445
    O906
    Repeaters will give you a squelch back or if they haven't been keyed up for a few minutes they will respond with a per-programed message. Usually the call sign of the repeater or it's owner.
    If you try to key up a repeater and after you release your mics button you hear nothing but silence you aren't reaching it or do not have the right tone to activate it.
  6. Aug 9, 2016 at 10:17 PM
    #2446
    gray223
    SE Missouri
    2014 Tundra Limited
    Sweet! Thanks! So I guess I am reaching it. Didn't think this little baofeng would go that far from in the house.
    Our and I see you can program the radio? What does that do exactly? Like could I name my frequency's in my memory channel and stuff?
  7. Aug 10, 2016 at 8:43 AM
    #2447
    O906
    Say that again I don't understand :rofl:
  8. Aug 10, 2016 at 8:44 AM
    #2448
    O906
    No problem man, I'm a IT in the Coast Guard but have worked with and done a lot of cross training with the radio techs and working with them got me started in the world of radio and the reason I understand as much as I do.
  9. Aug 10, 2016 at 11:50 AM
    #2449
    gray223
    SE Missouri
    2014 Tundra Limited
    Sorry lol not sure what happened. I was asking what exactly is programming the radio?
  10. Aug 10, 2016 at 12:06 PM
    #2450
    O906
    That generally means to store pre-set frequencies in the radio so you don't have to manually have to input them all the time.
    Most HAMS will program their local repeaters as well as the national calling frequencies for 2m and 70cm.
  11. Aug 10, 2016 at 12:07 PM
    #2451
    gray223
    SE Missouri
    2014 Tundra Limited
    Ok thanks. That what I was hoping. Cause manually doing all that would really suck lol
  12. Aug 11, 2016 at 1:38 AM
    #2452
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Very possible, find another igate... road trip!
  13. Aug 11, 2016 at 3:09 PM
    #2453
    jim532
    jim532 .
    SoCal - 818
    2014 Prerunner V6 double cab
    Are you doing this
    I may be wrong but I don't think you will show up on the APRS.fi website if your APRS password is wrong.
    I'm using mobilinked on a baofeng, I struggled and finally got it to work when I stopped using that stock antenna and switched to the mobile antenna on my truck.
    After you get a different antenna set it up exactly like the instruction manual says to do it.
    There's quite a few on here that have a mobile radio dedicated to APRS. the other option is your baofeng drive a a 30 of 50 watt amplifier to get the signal out.
  14. Aug 11, 2016 at 4:47 PM
    #2454
    O906
    I'm curious how are you interfacing the TNC with the kenwood in the truck?
  15. Aug 11, 2016 at 5:32 PM
    #2455
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    Well not sure if this is obvious, but you have two radios, right? you should check to see if you're over or under modulating. Run your TNC + radio and monitor on the unused radio. If you're not hearing a clear signal that's distinguishable from the other radio, you've got a problem.
    1) verify you're transmitting
    2) verify you're audible
    3) verify frequencies
    4) verify your igate
    5) change your settings
    6) delete the app and reset to default settings by reinstalling
    7) reset your phone
    I'm almost 100% sure it's a configuration issue, and there is a finite combination of settings on your phone. So map all the configurations and settings, then try them one by one.
  16. Aug 12, 2016 at 3:01 PM
    #2456
    O906
    I'm sure it'd be easy to find the email of the owner of the iGate and shoot them an email.
  17. Aug 12, 2016 at 3:06 PM
    #2457
    O906
    You said that is worked with the normal version of APRSdroid but not the OSM version. Have you tried reverting back to that and tested?
  18. Aug 12, 2016 at 3:35 PM
    #2458
    O906
    Alright so we can rule out APRSdroid as the problem. That leaves really just a few things.
    TNC settings
    TNC interfacing with the radio
    Radio's ability to reach iGate.
    Have you listened to the packets being transmitted on your second radio? You should be able to audibly tell if the packets are complete and sound undistorted.
    Chipskip and kalieaire like this.
  19. Aug 16, 2016 at 3:08 PM
    #2459
    jim532
    jim532 .
    SoCal - 818
    when you look at aprs.fi are there other stations nearby? If so, drive to those locations and transmit to see if you are reaching an igate.
    Are you by any chance transmitting a PL?
  20. Aug 21, 2016 at 6:53 AM
    #2460
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
