Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Sep 15, 2016 at 10:53 PM
    #2521
    AZCFII
    AZCFII Well-Known Member
    2009 DCLB
    OME Susp.kit, ARB front bumper, Cooper AT3's, Alu-Cab canopy
    Going to do the tests for Tec and General this next week. Stopped and picked up an FT-857D while the factory rebate was still going. Trying to figure out my best option for mounting the control head.
    PeterVICEG, Chipskip and G.T. like this.
  2. Sep 16, 2016 at 1:58 AM
    #2522
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    WP_20160306_13_36_29_Pro.jpg I mounted the radio
  3. Sep 17, 2016 at 12:13 AM
    #2523
    2016BBP
    2016BBP Well-Known Member
    Southeast
    SR5 V6 Auto
    Method Wheels, WxTechGuards, TowPkg, KNDropn, 3M-Tint
    Congrats on Extra, I rarely use the Extra portion of the bands but it`s good to have if you ever want to go there, I mostly use the Extra portion frequencies on 20M.
  4. Sep 17, 2016 at 3:32 AM
    #2524
    O906
    O906 Well-Known Member
    They make an NMO mount for a 3/8" hole which is by far my preferred NMO mount over the larger 3/4" NMO. That's a 1/2" hole on your CB antenna mount and all you need is a 1/2" to 3/8" washer. Firestik already makes these for CB's but they're plastic. This should be okay because using it with NMO will still ground the outer conductor anyway. If the outer conductor doesn't end up grounding you'll need to use a metal washer instead of the plastic one.
    To make sure it grounds take off the o-ring on the underside of the NMO plate. You don't need it anyway for this application.
    https://www.amazon.com/WILSON-ELECTRONICS-905814-Mount-Connector/dp/B00LPELALI/ref=sr_1_3?ie=UTF8&qid=1474108299&sr=8-3&keywords=3%2F8+nmo
    https://www.amazon.com/FireStik-NW-...id=1474108322&sr=8-1&keywords=firestik+washer
    Crom likes this.
  5. Sep 17, 2016 at 5:07 AM
    #2525
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton/Charleston, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Great DX stations usually hide in the extra portion. For me it was the DX portion of 80m. Heard DF2BO the founder of OptiBeam Antenna, it gave me the DX bug. I had to get my extra privileges
    TXPROMAN, Chipskip and Crom like this.
  6. Sep 17, 2016 at 7:58 AM
    #2526
    zdauexs
    zdauexs Well-Known Member
    2017 QS Tacoma OR DCSB
    Thank you, exact info I needed!
  7. Sep 17, 2016 at 3:35 PM
    #2527
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    I been making alot of European contact on 20 meter extra class bands.
    2016BBP[QUOTED] likes this.
  8. Sep 18, 2016 at 1:56 PM
    #2528
    Chipskip
    Chipskip N7MCS
    Chip
    Phoenix
    07 Tundra
    Was out working an Ultra race on the Mogollon Rim. Four year, it's always a fun time. One of the only chances I get to use my mast. Here is a pic of my setup for today.
    Diamond X-50A antenna
    FT-8800 and remote speaker on a ram mount / panavise hybrid mount.
    llibrm, 2016BBP, zdauexs and 2 others like this.
  9. Sep 20, 2016 at 12:11 AM
    #2529
    2016BBP
    Southeast
    SR5 V6 Auto
    Yep, I`ve worked him many times from the base and mobile, he always has a good signal, he was on 3.794 tonight.
    BenMara[QUOTED] likes this.
  10. Sep 20, 2016 at 9:11 AM
    #2530
    dedmouse
    dedmouse Well-Known Member
    Dammit
    South Central Missouri
    2010 Black Tacoma Base, 6 spd manual tranny, V6.
    Yeah....I've held an Advanced Class license since the mid 80's...waaaayyyyyy too long. I need to shed that license for an Extra class license so I can work those parts of the bands.
  11. Sep 20, 2016 at 6:37 PM
    #2531
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    Forum Name: Phessor
    First Name: Daryl
    Call sign: KD7SIE
    Other call sign: KG4TM
    Radios: Kenwood TM-V7A mobile and Yaesu V-5R handheld.
    Frequency usually on: 2m/70cm
    phx13, G.T. and Chipskip like this.
  12. Sep 20, 2016 at 10:15 PM
    #2532
    AZCFII
    2009 DCLB
    Just and took my Technician, and General class tests tonight. Passed them both. Decided not to push my luck with the Extra.
    Chipskip, G.T. and llibrm like this.
  13. Sep 20, 2016 at 11:11 PM
    #2533
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    What did you use to study for the Technician class? id really like to ditch my CB for a 2m Setup but i have the worst time committing things to memory
    Chipskip likes this.
  14. Sep 20, 2016 at 11:29 PM
    #2534
    2016BBP
    Southeast
    SR5 V6 Auto
  15. Sep 20, 2016 at 11:32 PM
    #2535
    Gaunt596
    Matthew
    Central Maryland
    Crom and G.T. like this.
  16. Sep 20, 2016 at 11:41 PM
    #2536
    2016BBP
    Southeast
    SR5 V6 Auto
    Might as well get it, I did just because it was there for the taking.
    I personally wish the cw requirement was still in place, we have got some good operators since it was dropped but as you know we have got some not so good as well.
    The requirement was low enough at 5wpm, 5wpm can be accomplished with only a little effort in a month pretty easily. If I did it, anyone can.
  17. Sep 21, 2016 at 1:53 AM
    #2537
    2016BBP
    Southeast
    SR5 V6 Auto
    My son got his Tech in 8th grade and my wife got her Tech in one month, just get on their and take a few tests every day and you'll do just fine.
  18. Sep 21, 2016 at 3:43 AM
    #2538
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    I did all three test in five months. Technician, general, extra class.The first two were easy. Extra class a little tougher .
  19. Sep 21, 2016 at 10:31 AM
    #2539
    AZCFII
    2009 DCLB
    Used www.QRZ.com mostly, also got the books from Gordon West WB6NOA. I was already scoring in the mid 90% on the Technician before studying. Only spent about 6 hours studying for the General.
  20. Sep 21, 2016 at 6:43 PM
    #2540
    dedmouse
    Dammit
    The code requirement didn't keep out the lids very well. There were plenty in the eighties and nineties with many of them being extra class hams. In some ways, I feel we have a lot of great and smart savvy young hams doing lots of very interesting things.
    I worked at HRO in the nineties for eight years and saw my share of idiots that had no business being on the air. I took an 18 year hiatus from all ham radio because I got so burned out working in the hobby. I got back on the air about five years ago but still don't make a lot of contacts. I have too many hobbies it seems.
