Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. May 9, 2017 at 1:13 PM
    #2841
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Here for changes to Part 95 (CB, FRS, and GMRS) that the FCC will be putting in place soon.
    Chipskip, G.T. and foy1der like this.
  2. May 9, 2017 at 2:34 PM
    #2842
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Just looked at the FCC site and it's $70 for GMRS :anonymous:
    Chipskip likes this.
  3. May 9, 2017 at 2:44 PM
    #2843
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    I think part of extending the license is that they only have to charge the ridiculous fee every 10 years. It's just crazy that our ham license is 15 bucks and lasts 10 years. GMRS is just pointless.
    Sleipnir[QUOTED] likes this.
  4. May 9, 2017 at 2:46 PM
    #2844
    Cannikin
    Cannikin Well-Known Member Vendor
    Rob
    San Marcos, CA
    2012 TRD Offroad
    HOLY CRAP I don't remember it being that much when I applied!
  5. May 9, 2017 at 3:16 PM
    #2845
    G.T.
    G.T.
    CONUS
    Thanks guys. Still looking into it as an addition to her truck and if we like it, I'll add it to mine as well. The increased license fee doesn't bother me.
    Sleipnir likes this.
  6. May 9, 2017 at 3:21 PM
    #2846
    Cannikin
    Rob
    San Marcos, CA
    2012 TRD Offroad
    Do you guys already have UHF/70cm/440MHz radios in your trucks? Lots of them will receive in the GMRS bands already and some will even transmit with some modification. I have an Icom IC-5100 that I just modified to do that—you take off the bottom cover and remove two tiny diodes http://radioaficion.com/cms/icom-id-5100-rx-and-tx-mars-mod/ Lets me transmit anywhere from 400 to 470MHz (and 137 to 174MHz in the VHF/2m/144MHz band)
    Do a search for your radio model number and "extended transmit" to see if anyone has found a hack.
  7. May 9, 2017 at 4:52 PM
    #2847
    Cannikin
    Rob
    San Marcos, CA
    2012 TRD Offroad
    Just finished installing my Icom ID-5100! The faceplate fit perfectly in the pocket in front of the cupholders and with a glovebox organizer I was able to put in the body in there and not lose much room.
    The antenna:
    Here's where it's going:
    Got a sheet of aluminum from Home Depot (20 or 22ga I think) and after some test fits with a piece of cardboard I cut and bent it to fit, holding the faceplate at a nice angle:
    The faceplate has a couple magnets on back that grab onto the black plate attached to the aluminum.
    Since the body was going to be in the glovebox there was no way I'd be able to hear the speaker in there. I picked up an external speaker from Amazon and it fit perfectly behind the faceplate, bolted to my bracket:
    The sound is muffled a *little* being behind the faceplate, but I'm able to run the radio at about 50% volume with the windows down and still hear what's going on, so it's plenty loud.
    I drilled a hole in the back of the pocket (not pictured) and ran the cables through that and back over to the glovebox. I ran the power/ground from my battery distribution box through the main fusebox grommet and across to the glovebox. I ran the antenna cable through a little unused grommet on the passenger firewall. I've the mic coming up out of the pocket and sitting in the little change holder thing to the right of the steering wheel:
    And the body in the glovebox:
    I've only had it in there for a day but so far I'm loving it. The display is fully visible from the driver's seat and the controls are reachable with just a little bit of lean. Most of the controls are actually available on the mic itself so most of the time I don't need to even reach.
    The faceplate has a GPS antenna built in and still gets a great signal down in the pocket.
    All the stuff:
    Icom ID-5100: https://www.amazon.com/Icom-ID-5100A-Amateur-Transciver-Internal/dp/B00K5BNHT0
    Diamond NR770HB Mobile Antenna: https://www.amazon.com/Diamond-Original-NR770HB-Dual-Band-Antenna/dp/B00MANF3L6
    Diamond C101 Antenna cable: https://www.amazon.com/C101-Antenna-mount-cable-assembly/dp/B00AR09284
    Relentless CB/AUX Mount: https://www.relentlessfabrication.com/products/05-tacoma-hood-hinge-cb-aux-mount
    CB Speaker: https://www.amazon.com/gp/product/B000ZIC18Q
    Jeremy M., Bastek, the glen and 4 others like this.
  8. May 9, 2017 at 4:59 PM
    #2848
    foy1der
    W1FOY
    2017 OR DCLB
    I really like the way that looks in front of the cupholders. I wouldn't think that a speaker would fit in there. It seems that I need to start rethinking how I mount the face of my v71a.
  9. May 9, 2017 at 5:06 PM
    #2849
    Cannikin
    Rob
    San Marcos, CA
    2012 TRD Offroad
    Added a photo from a little farther back so you can see it with the whole dash. Looks great down there. If the pocket isn't deep enough for the v71a you might be able to cut out some of the back to make a little room. I think the airbag controller is down there somewhere, but there's room at the top-back of the pocket.
  10. May 9, 2017 at 6:35 PM
    #2850
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    I hope you didn't have as much fun as I did enlarging that hole to fit an SO239 base for the antenna? That steel is work hardened and must be softened before enlargement is attempted. Ask me how I know.......I have a 27" Comet version mounted there. Mine works great there!
  11. May 9, 2017 at 7:29 PM
    #2851
    Cannikin
    Rob
    San Marcos, CA
    2012 TRD Offroad
    HA! I was able to cheat: that cable that I got has the body of the connector as a separate piece that be unscrews from the pin. When it's disconnected the fitting is only about 1/4" wide:
    I removed the grommet and then sliced a little notch into it that hugs the 1/8" cable and (hopefully) keeps things water tight still.
  12. May 9, 2017 at 7:39 PM
    #2852
    45longcolt
    DFW Area
    2020 Off Road
    I had to enlarge the mount base from 1/2" hole for a CB type 3/8" mount to 5/8" hole for a 239 type Amateur base. If anyone uses this Hood Hinge mount and you need to drill on it, soften it first. I ruined a perfectly good 5/8" drill bit and those are not cheap. After softening it enlarged no problem.
  13. May 9, 2017 at 8:27 PM
    #2853
    Cannikin
    Rob
    San Marcos, CA
    2012 TRD Offroad
    Oh the MOUNT you had to open! I thought you meant the firewall hole. I did have to widen my mount hole to 5/8" as well, but I used a stepped sheet metal bit and it drilled like butter, I couldn't believe it. I just added a couple drops of 3-in-1 oil and set my drill press to about 600 rpm.
    https://www.amazon.com/dp/B000FZ2UOY/ref=cm_sw_r_cp_api_AHOezbQJ909F3
    G.T. likes this.
  14. May 11, 2017 at 10:06 AM
    #2854
    jim532
    jim532 .
    SoCal - 818
    2014 Prerunner V6 double cab
    have any of the operators here tried the BitX40 QRP kit? looks like it could be fun.
  15. May 12, 2017 at 3:55 AM
    #2855
    foy1der
    W1FOY
    2017 OR DCLB
    I have one sitting on my desk. I haven't had time to build it yet. For $60, why not try it, right?
  16. May 12, 2017 at 11:51 AM
    #2856
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    Where did you get this keystone? I want to do just this. Is it a RJ-12 or did you use a RJ-45? Can you even do a RJ-45 and only punch 6 to make it a RJ-12?
  17. May 12, 2017 at 2:54 PM
    #2857
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    The keystone is a cat3 female to female. The keystone mount is a 3D printed part I have up on Shapeways. Not sure if I actually have the part listed for sale or not but I'll check later when I'm not mobile and link it here.
  18. May 12, 2017 at 4:07 PM
    #2858
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    @forty2 i already bought that cubby to 3 switch replacement on shapeways. If you are the guy behind that also then you are the man. I have a cat3 to cat3 but I need that fancy thing right thar...
  19. May 12, 2017 at 10:42 PM
    #2859
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I am in fact that guy. Here you go.
  20. May 13, 2017 at 7:08 AM
    #2860
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Damn you, something else that I have to buy! That looks awesome and fun.
