Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Jul 19, 2017 at 1:47 PM
    #3001
    Sistema1927
    Sistema1927 Well-Known Member
    Jerry
    The Land of Enchantment
    2007 Tacoma TRD Off Road
    And there you are on FindU, 2.2 miles NE of Fairbanks. Maybe you have some RFI at the house that is keeping the squelch open.
    Chipskip likes this.
  2. Jul 19, 2017 at 1:51 PM
    #3002
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Sent a test email via APRS that took about two seconds between hitting send on the radio and my phone receiving it.
    llibrm and Chipskip like this.
  3. Jul 19, 2017 at 2:19 PM
    #3003
    jim532
    jim532 .
    SoCal - 818
    2014 Prerunner V6 double cab
    It works! I sent you a message via APRSDROID
  4. Jul 19, 2017 at 2:35 PM
    #3004
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    I'm guessing that you are littered with RFI around the house. Time to break out the HT and go hunting for offending wall warts.
  5. Jul 19, 2017 at 2:37 PM
    #3005
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Probably. Thinking about it, where my truck was parked there was probably only 15 feet between the antenna and my wireless router in the house. Not sure if that's the cause but I'll play around with parking in different areas and see what happens.
  6. Jul 19, 2017 at 2:39 PM
    #3006
    foy1der
    W1FOY
    2017 OR DCLB
    For me it's the power supply for my Roku. The thing basically takes over all of 2m. I can't scan the band at all, it stops every 2.5k just to listen to that glorious static. I haven't found a real good solution for dealing with them.
  7. Jul 19, 2017 at 6:10 PM
    #3007
    jim532
    jim532 .
    SoCal - 818
    New wall wart
  8. Jul 19, 2017 at 8:39 PM
    #3008
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Have you tried ferrite beads?
    Also, contact Roku, I believe to be FCC compliant they can’t let off that kind of interference. I could be wrong.
  9. Jul 19, 2017 at 8:42 PM
    #3009
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    KJ6TXN checking in!
    Haven't read the whole thread but screw In type fluorescent bulbs have caused me RFI issues in the past.
  10. Jul 19, 2017 at 8:49 PM
    #3010
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Looks good. I've been wanting that radio for a while but just can't drop the coin yet. Other truck mods are taking priority
  11. Jul 24, 2017 at 7:51 AM
    #3011
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    FYI- @Gramps here got a similar model from ToyTech I believe (He can confirm) from some AUS company, modification was required but again, he can confirm. Hope you don't mind Eric :thumbsup:
    cllowe24 likes this.
  12. Jul 24, 2017 at 12:47 PM
    #3012
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    I need that console :yes:
  13. Jul 24, 2017 at 1:28 PM
    #3013
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Outback roof consoles I believe was the name. I will have to look when I get home.
    CO MTN Steve likes this.
  14. Jul 24, 2017 at 10:35 PM
    #3014
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Some ideas to run past you guys....
    The 710G is capable of crossband repeating. Mine is connected to my secondary battery so I can run it easily for days before power consumption becomes an issue. What I'm thinking about trying is setting up the 710G to repeat from a UHF frequency to the commonly used local VHF repeater in order to extend the range of a dual band HT (which I haven't bought) when I'm away from the truck. I figured if I used a UHF simplex frequency programmed with a DCS tone it would limit the chance of any other random users from being retransmitted to the repeater accidentally. I can lock the 710G to retransmit the UHF signal one way, from myself to the VHF repeater only. The repeater transmission should make it to the HT without issue and not need to be repeated by my truck.
    Any try this before?
    What HTs can transmit on UHF while still monitoring a VHF frequency?
  15. Jul 25, 2017 at 6:50 AM
    #3015
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    What you described is called Tx boost. It is a very common. Full cross band repeating can be annoying and a lot of repeaters will actually ban that. Transmission Boost was setup to be a viable alternative.
    Several HTs will monitor both, I have done it with a FT-60 and TH-D72A.
    Crom likes this.
  16. Jul 25, 2017 at 6:55 AM
    #3016
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes. I used to do this four years ago. Cross band repeat one way. A side or B side on the Kenwood. It works. on the HT I just had to program it using software, because the freq. split was like 300 Mhz! lol
  17. Jul 25, 2017 at 7:16 AM
    #3017
    Sistema1927
    Jerry
    wsurunner and CO MTN Steve like this.
  18. Jul 25, 2017 at 7:58 AM
    #3018
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
  19. Jul 25, 2017 at 3:08 PM
    #3019
    Sistema1927
    Jerry
    And the need to ID. If your radio is transmitting, then you need identification:
    "The unattended station must be identified on all frequencies it transmits on. Since this is a form of remote base, the user's ID over the UHF uplink to the dualband radio also serves to ID the VHF output of the mobile rig. In the other direction, however, there is no way for the control operator to ID the UHF downlink from the mobile remote base, so some form of automatic ID must be employed [97.119]. Unfortunately, few manufacturers include the capabilities listed above in their rigs. Hence, to be fully legal, some form of add-on controller may be necessary."
  20. Jul 25, 2017 at 3:58 PM
    #3020
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    My plan was to have the radio only retransmit my transmissions with my callsign. The HT would receive direct from the repeaters.
