Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Dec 28, 2017 at 11:16 AM
    #3321
    demo243
    demo243 Well-Known Member
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    Two radios
    lordetaco likes this.
  2. Dec 28, 2017 at 12:02 PM
    #3322
    lordetaco
    lordetaco Well-Known Member
    Tristan
    Lawton,OK
    2005 Toyota Tacoma
    You only need your technician lisence to run this radio, and it’s not hard to get just simple common sense question and some basic electrical/frequency spectrum understanding.
  3. Dec 28, 2017 at 4:55 PM
    #3323
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    You can get a HAM radio that can receive AM CB signals but I have yet to find one that will transmit AM.
    So 2 radios.
  4. Dec 28, 2017 at 5:34 PM
    #3324
    demo243
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    It can be done , but it’s not cost effective or legal. Most 10m radios can be mod’ed to tx on 11m (cb) frequencies, but it’s not ideal and it’s not legal...
    Looked into it a bit and decided it’s more cost effective to just do two radios . I’ve got a Yaesu 100dr for 2m/70 ham and will likely go with a Uniden cmx760 for cb now that I’m back east and most people seem to still run cb
    I also keep a baofeng in the center consol so I can take a radio with me if needed or someone can use it to spot me or whatever
    NotRed likes this.
  5. Dec 28, 2017 at 5:45 PM
    #3325
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    My radio will tx on cb frequencies but it's barely intelligible on a cb
    I think the problem is that it's transmitting an FM signal rather than the AM signal that CB uses.
    When you say 10m radios can be modded to tx on 11m are you just talking about unlocking the frequencies or can they actually be made to transmit an AM signal?
  6. Dec 28, 2017 at 5:52 PM
    #3326
    demo243
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    That’s a good question... I never looked into it enough and I’m not familiar enough with the HF frequencies...
    Also part of why I decided it would be better to just run to radios
  7. Dec 28, 2017 at 6:19 PM
    #3327
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Ok i guess i will be keeping the galaxy cb than. 2nd issue, just locked up a 2nd gen in the process of grounding all my metals is the roof 3 sections glued together. Just wondering if i should run a strap all across the roof or not. Its a 08 access cab.
  8. Dec 28, 2017 at 8:55 PM
    #3328
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    MARS frequencies is broadbanding. Can be done on almost all vhf,uhf, and hf radio's. So if you have yaesu 857D. All bands are open up.
    Sec. 97.403 Safety of life and protection of property
    No provision of these rules prevents the use by an amateur station of any means of radiocommunication at its disposal to provide essential communication needs in connection with the immediate safety of human life and immediate protection of property when normal communication systems are not available.
    G.T. likes this.
  9. Dec 29, 2017 at 4:35 AM
    #3329
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    I wouldn't worry about it. I have an antenna drilled into my roof for vhf and uhf and it the performance is incredible.
  10. Dec 29, 2017 at 4:37 AM
    #3330
    foy1der
    W1FOY
    2017 OR DCLB
    I say that but the real answer is that it depends. If you are going to put an HF antenna on the roof, grounding matters a whole lot more. But I'm assuming that you aren't going to put an HF antenna on the roof. Not many would put 10 feet of antenna on top of a 6 foot tall truck.
  11. Dec 29, 2017 at 5:31 AM
    #3331
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    You only have to worry about grounding/bonding your whole truck in you are adding An HF radio and antenna. For 2m and 70cm just a good ground between antenna and truck is needed.
  12. Jan 1, 2018 at 5:37 PM
    #3332
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    Just got a Kenwood tm d710ga. Planning on using my ditch light bracket mount that I used for my cb antenna. Should I have to worry about electrically grounding the mount? Also any tips/suggestions for this radio would be greatly appreciated.
    Chipskip likes this.
  13. Jan 1, 2018 at 7:35 PM
    #3333
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    Jckdnls likes this.
  14. Jan 5, 2018 at 5:33 PM
    #3334
    YDCtaco
    Alexandria, VA
  15. Jan 5, 2018 at 5:50 PM
    #3335
    demo243
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    @YDCtaco Was running a comet with a baofeng that did pretty well.
    I put a cap on the back not to long after and it hid most of the antenna.
    I bumped up to a diamond 770 nmo and it did even better, and even better when I put it on a Yaesu 100dr
    I believe the 770 doesn't need a ground plane... Would have to look back into it again to confirm.
    Never had any issues with tx or Rx.
    YDCtaco[QUOTED] likes this.
  16. Jan 5, 2018 at 6:01 PM
    #3336
    YDCtaco
    Alexandria, VA
    Awesome thanks. I have the tonneau cover on the back so I am looking at rago fabs tailgate mount. I am not drilling an nmo mount while there are still many payments. Tried using ditch mounts with cb but non of the brackets are stainless so it rusted pretty fast. Lastly, I hear the fender is quite thin for many L brackets.
  17. Jan 5, 2018 at 6:47 PM
    #3337
    demo243
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    Just check your tailgate to bed clearance- my bamf is pretty tight. I like the rago one but haven’t been able to find it for the passenger side
  18. Jan 5, 2018 at 8:42 PM
    #3338
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
  19. Jan 6, 2018 at 1:17 PM
    #3339
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Question for you guys,
    We hooked up a radio to a side by side and we’re having issues.
    The radio works fine both ways when the machine is off but the second we turn the key we can no longer hear anything coming in, but we can be heard.
    Any ideas on what the issue could be?
  20. Jan 6, 2018 at 1:58 PM
    #3340
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Does it have LED lights?
    Sounds like RF interference.
    rob1208 and Chipskip like this.
