Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Jan 11, 2019 at 5:48 AM
    #4381
    BrotherBudro
    BrotherBudro Well-Known Member
    David
    Nashville
    2017 SR5 Access Cab, V6 4X4
    Leer 100XR, Dual Battery, Dog Platform, Sleeping Platform, Ham, CB, Light Bar, Rear Lights,
    Not a problem at all. I've got a CB antenna and ditch lights on the same bracket, no issues so far. I'm planning on mounting a ham antenna on the other ditch light bracket this weekend.
    Edit: My experience is on a 3rd gen, I can't speak for 2nd gens.
  2. Jan 11, 2019 at 6:12 AM
    #4382
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Since we're talking about different frequencies, shouldn't be an issue, but... We're also talking about a long steel whip 8" or so away from your (CB or HAM) antenna. If I were in your situation, I would consider a short rubber ducky style antenna for the AM FM radio.
    Hopefully someone will provide better insight on it.
    It's not the same issue. 2nd gens have a radio antenna mounted in/on pass side fender, 3rd gens have a shark fin on the roof
    05prerun82[QUOTED] likes this.
  3. Jan 11, 2019 at 6:29 AM
    #4383
    BrotherBudro
    David
    Nashville
    Oops, didn't realize he had a 2nd gen, ignore my previous post.
  4. Jan 11, 2019 at 8:13 AM
    #4384
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    So you're trying to say it's not legal for me to transmit on a legal ham frequency that I'm licensed to use? No unlicensed individuals are using a ham frequency. A non-ham licensed individual is transmitting only on GMRS and receiving on a 70cm ham freq. I'm transmitting only on 70cm and receiving on a GMRS freq.
  5. Jan 11, 2019 at 8:22 AM
    #4385
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    You are not communicating on the ham bands, you are broadcasting on the ham bands. The other guy is transmitting on a non type certified device.
    Both, uh, illegal.
    Edit, after further research I see that this cute loophole is something the Bro-Verlanding community conjured up 5 or 6 years ago for their "expeditions".
  6. Jan 11, 2019 at 8:23 AM
    #4386
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Nice! Finding loopholes FTW!
  7. Jan 11, 2019 at 8:37 AM
    #4387
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I'll concede that point, I hadn't considered that the one way transmissions could be classified as broadcasts rather than communication.
  8. Jan 11, 2019 at 3:19 PM
    #4388
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    This is not legal.
    Chipskip likes this.
  9. Jan 11, 2019 at 3:28 PM
    #4389
    k8md
    Bob
    Ham or CB? I'm not sure about CB. A 2m band ham antenna on a passenger side ditch light mount on a 2nd gen is going to couple an incredible amount of energy into the FM antenna. Best case is that you will de-sense FM broadcast stations, while you're in transmit. It's possible that you damage the FM broadcast receiver in the vehicle. CB is more MHz away and also less power. YMMV.
    I don't like ditch light mounts for ham tenners. You're brain and eyes are directly in the main lobe. I haven't done the math, but I'm concerned it violates FCC exposure limits. CB shouldn't be a concern though.
  10. Jan 11, 2019 at 3:30 PM
    #4390
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Thanks so mounting the antenna on the drivside probably a better option
  11. Jan 11, 2019 at 3:33 PM
    #4391
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Per the FCC website:
    "In response to concerns expressed over the commonly used rear-window mounted wireless antennas, a minimum separation distance of 1-2 feet has been suggested as a way to minimize exposure to vehicle occupants." I'd say a windshield mount puts me about 3ish feet away.
  12. Jan 11, 2019 at 3:46 PM
    #4392
    k8md
    Bob
    For ham or cell phones? Ham radios put out significantly more power then cell phones. Additionally, a rear window mount is at the top of the window with the main lobe above the metal roof. A ditch light mount blasts radiation right at your face.
    CO MTN Steve likes this.
  13. Jan 11, 2019 at 4:08 PM
    #4393
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I see you're quite strict on rules, which is OK with me. But violating limits? Exceeding, sure :p
    Calculator if anyone wants
    http://hintlink.com/power_density.htm
    Lifted from here INSTALLING AMATEUR AND CB RADIOS IN 2016 TACOMA
    You still didn't specify CB or HAM. CB, sure. HAM.... I wouldn't if planning on running high power. But that's me.
    k8md[QUOTED] and nats like this.
  14. Jan 11, 2019 at 4:21 PM
    #4394
    nats
    nats Well-Known Member
    Lakewood, CO USA
    '10 TRD Sport DCSB
    (this will change)
    The context for this statement from FCC.gov is aimed at the consumer cellular market (so 700MHz to just above 1.2GHz); the statement specifies installations of this type where TX power levels are "3 watts or less".
    this is the FCC.gov statement with context ---> https://www.fcc.gov/consumers/guides/human-exposure-rf-fields-mobile-vehicle-mounted-antennas
    In the CB world (wasn't that Class D?) you'd see like 4W in a less bio-reactive band, so a hood / ditch-lamp mount may be fine (and a lot of the fiberglass whips popular for off-roading are top loaded anyway, so that radiation may still be above the cab). In a 2M world where output can be several orders of magnitude higher (and frankly, I'll prolly run a co-linear array with appreciable gain), I would not look to ditch-lamp mount that, as a mater of personal opinion, if not as a matter of better radiated pattern. Just think of it as a whole new way to "expose yourself", I guess.
    Gunshot-6A[QUOTED] and Bastek like this.
  15. Jan 11, 2019 at 4:25 PM
    #4395
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I have a feeling that I I should have stfu with my advice, especially that now I'm going to ask newb question... Oh well, here it goes.
    Because of radiation exposure I've decided not to install HAM antenna on the hood bracket. I'm not quite ready to drill the roof just yet, using mag mount temporarily. I want to move my antenna onto my bedrack, behind the cab. Not sure if good enough idea? Any opinions?
    Also, I have a sunroof which unfortunately takes a bunch of roof's real estate. Since there is way less metal surface, does that affect antenna's performance?
  16. Jan 11, 2019 at 4:57 PM
    #4396
    nats
    Lakewood, CO USA
    '10 TRD Sport DCSB
    (this will change)
    I think you should just scrap the whole thing, keep the antenna, and gimme your truck! :crapstorm:
    Really, the best antenna is always a compromise and yes, anything less than a good counterpoise running in all directions from the mounting point is a compromise (sunroof hole, hood bump, body contour) and will impact feedpoint impedance and the radiation pattern; it just won't be perfect.
    In my distorted little world (we talked safety above) performance and convenience are the toughest to balance. That mag mount gets you above the rest of your metal, and has the added bit of protection for getting knocked over to help avoid low-hanging tree damage. A drilled mount up there would have a tougher time with the tree branch. Even with your sunroof, there's still more flat steel to use as a counterpoise there there will be a the center front of your rack.
    One of my concerns with a rack mount would be just the damned antenna sticking-up where you wanted to load something. I mean... you bought the rack to put stuff on top of it, and if you add something that makes some of the front rack-rail unusable, then -- that part is unusable. Again very much MY PERSONAL OPINION here, but, I do like the thought of a permanent mount on the rail; for me, it'd have to be center on the front-most rail. seems like a good compromise with being in the way and best performance. However, I would add (likely weld) a mounting surface to that area of the rail to lift the mounting point of the antenna above the rail surface by a few inches (level with the cab roof might be the most aesthetically pleasing). This little "extra" steel would help protect the antenna mounting from anything sliding along the rail as well as offer a clean way to get your coax in/out of the mount. By lifting the antenna feedpoint slightly above the rail, the radiation pattern would be a little less impacted (18" wold be nice, but Soooo UGLY and fragile); so a little bonus in the performance area provided that you can get the antenna to tune 'up there'. It kinda looks like you have a center-loaded antenna with no loading in the base, so that should work nicely without much change in feedpoint reluctance.
    If everything on your rack is well connected and chassis grounded, I don't see that as too much of a problem -- 50W on 2M may leave you close to uncontrolled exposure limits, BUT with a center load and a little lift above the rack, all that heat will be on the far side of your roof steel.
    Just a few thoughts from here.
    Chipskip and Bastek like this.
  17. Jan 11, 2019 at 5:36 PM
    #4397
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Thank you for your thoughtful response. That's exactly what I was afraid of... OK, so where do I send keys and the title?
    Nice try :D .
    But yes, that what I was thinking about, except not welded but drilled and bolted to the rack. Rack is slightly lower than the roof line, was designed as off-road fixture, but it's too much of pita to take off / put on so it just stays there, so no issues with loading stuff on it.
    Anyways , thanks again :thumbsup:
    nats[QUOTED] likes this.
  18. Jan 11, 2019 at 5:49 PM
    #4398
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Oh well. I haven’t run into a ham up here who cares. It probably helps that my state is 15 times the size of yours with 24000 fewer licensees.
  19. Jan 11, 2019 at 6:11 PM
    #4399
    Sand Dog
    Sand Dog Well-Known Member
    2018 SR, 4x4 DCSB MGM
    Any thoughts on mounting a glass-mount antenna for 2m/440 on either the rear window of a DCSB or on the side window of a cap?
    in either case, it would be my preference that the top of the antenna not be higher than a couple of inches above the roof line.
    any thoughts would be most appreciated.
  20. Jan 11, 2019 at 7:12 PM
    #4400
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    ARB bumper has mounting brackets for a better antenna... :rofl:
    Joking aside, I think you'll get better range and a cleaner setup if you toss a larger antenna on a bolt-on ditch light bracket.
