Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Aug 10, 2019 at 4:06 PM
    #5461
    kpplume
    kpplume Member
    Northern Bay Area, California
    2016 TRD Sport 4x4
    •Icon Stage 4 Billet kit •Nitto Ridge Grapplers 285/75/17 •Relentless Fab Front Bumper •Baja Design Ditch Lights •Baja Design Fogs •BayAreaMetalFab Cab Mount Chop •Mountain Hatch Tailgate
  2. Aug 10, 2019 at 7:14 PM
    #5462
    HP11
    HP11 Well-Known Member
    NH
    2019 Cement Tacoma TRD Sport
    kpplume likes this.
  3. Aug 12, 2019 at 8:29 AM
    #5463
    cheuer
    cheuer Well-Known Member
    Utah
    2016 DCSB TRD OR 4x4 Blazing Blue Pearl
    Leer 100XR, Mobtown Offroad Sliders
    I took a piece of flat bar steel and made my own extension bracket off the ditch lights for my antenna. Easy solution for a few dollars from a home improvement store.
  4. Aug 12, 2019 at 2:33 PM
    #5464
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I suspect it not to be a power interference because if I disconnect the coax, the static stops
    Gunshot-6A likes this.
  5. Aug 12, 2019 at 2:56 PM
    #5465
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    RFI is horrible in my Gen3 tacoma. Sounds like fuel injectors to me.
    It comes through the antenna. Try torroids, and making sure all grounds are at the same potential.
  6. Aug 12, 2019 at 3:00 PM
    #5466
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Cortico- or anabolic-? Which will get me a lower SWR?
  7. Aug 12, 2019 at 3:02 PM
    #5467
    golfindia
    Yes.
    pickup truck
    LOL. Damned AI.
  8. Aug 12, 2019 at 3:11 PM
    #5468
    MatthewMay1
    Matthew
    Lone Star Republic
    What is a torroid?
    This is my issue.
    https://youtu.be/Bhv5sYNbIoE
  9. Aug 12, 2019 at 3:23 PM
    #5469
    golfindia
    Yes.
    pickup truck
  10. Aug 12, 2019 at 3:50 PM
    #5470
    MatthewMay1
    Matthew
    Lone Star Republic
    Makes no difference. It’s been doing this for a long time, just in the garage cause it’s boiling hot outside.
  11. Aug 13, 2019 at 6:57 AM
    #5471
    golfindia
    Yes.
    pickup truck
    Ok, different strokes I guess.
    K0BG has some good tips for RFI.
    https://k0bg.com/rfi.html
    I've done most of them, and still can't get rid of noise in my 2017. My antenna tip isn't even attached to my vehichle....
  12. Aug 13, 2019 at 7:08 AM
    #5472
    MatthewMay1
    Matthew
    Lone Star Republic
    I may have fixed it. I need to get it out of the shop and go drive around to see if it stays fixed. Think I need a better quality coax cable.
  13. Aug 22, 2019 at 9:33 AM
    #5473
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    18 LX570 on 35s, 06 Tundra DC beater
    Hey dudes, I just got my technicians license and am looking for a good mobile rig. I'm pretty sold on the FTM-400 but don't know much about antennas or placement. I'd like to start doing sweep team for rally up here in the PNW and want to do simple rig-to-rig mobile comms. Should I go for something fold down on my aluminum roof rack or put something on the hood? Shot of my truck for reference. Thanks in advance!
  14. Aug 22, 2019 at 9:37 AM
    #5474
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    ^ sweet truck
    I prefer hood mount especially if you actually use your roof rack, because then an antenna up there is always in the way. Hood mount is "good enough" ground to not have to run a ground strap and depending on your antenna needs can be pretty low profile and unobtrusive and doesn't occupy space used for anything else.
    Nimitz likes this.
  15. Aug 22, 2019 at 9:44 AM
    #5475
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    Thanks man! Good point, maybe I'll get one of the folding comet mounts or piggyback on the light pod mounts. I plan on getting light hoops for my bumper soonish, could I put a mast on there like the aussies do or is that a different type of comm system?
  16. Aug 22, 2019 at 4:35 PM
    #5476
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I mean, you could, but I feel like that's asking to get ripped off in the brush. I think they do a lot of open desert stuff which makes that more practical. Shit, I don't know. I only piped up because I run a hood mount!
  17. Aug 22, 2019 at 6:55 PM
    #5477
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    That does make a lot of sense. Honestly, I would 60% do it because it would look cool.
  18. Aug 23, 2019 at 5:48 AM
    #5478
    BrotherBudro
    BrotherBudro Well-Known Member
    David
    Nashville
    2017 SR5 Access Cab, V6 4X4
    Leer 100XR, Dual Battery, Dog Platform, Sleeping Platform, Ham, CB, Light Bar, Rear Lights,
    I've got my antenna on a mount that holds ditch lights and antennas (SOS makes them), but I think it's pretty easy to find (or make) an add on metal piece to hold the antenna. Good Luck!
  19. Aug 23, 2019 at 7:46 AM
    #5479
    Gunshot-6A
    Conner
    Everett, WA
    Roof Rack mount has gotten me plenty of range out here in the wide open deserts of Utah, but on the off times I go in the trees, it can get a little dicey.
    If you are living in the PNW, I would try a hood hinge mount. I think out on the bumper might be a little more risky, but def adds those #EAF point on the 'gram!
    @T.A.C.O.M.A and m603holden like this.
  20. Aug 23, 2019 at 9:03 AM
    #5480
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    Thanks man, sweet truck!
