Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Nov 2, 2019 at 9:06 PM
    #5821
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Nice rig, pics?
    That’s what I run due to clarity an reliability.
    Halffast555[QUOTED] likes this.
  2. Nov 3, 2019 at 3:03 AM
    #5822
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    If i go mobile ill be using my KX3, with a screwdriver antenna
    uncleelihu and Halffast555 like this.
  3. Nov 3, 2019 at 4:00 AM
    #5823
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I just got mine the other day too. I really have to work on my remote PTT switch. I had one on the 6sd shifter but it started to cut out. Too hard, at times, to shift, steer, talk, and work the pedals at the same time. I don't think I could do HF in a mobile and run it when driving on a screwdriver. 2M off the repeater takes enough effort as it is...
    One of these days, I have to get a pc connected to my base station (FT-847) and try FT-8 or similar. A friend that I talk to got into it and is making all sorts of contacts on the upper ends of HF. Maybe a winter project...
    m603holden[QUOTED] likes this.
  4. Nov 3, 2019 at 5:14 AM
    #5824
    Halffast555
    Halffast555 Half-Assed
    Jacob
    Gallatin Valley, MT
    2012 Tacoma TRD Off-Road
    Yeah I’ll post some later today. My transceiver is under my seat and my head unit is being ran from my cup holder
    Cudgel[QUOTED] likes this.
  5. Nov 7, 2019 at 11:12 AM
    #5825
    looking
    looking Well-Known Member
    Doug
    Lancaster, Ohio
    2014 Sport DCLB 4x4 Barcelona Red
    Somewhere on the Tacoma forum I saw a few posts about someone wiring a folding 90 degree antenna mount with switch inside the cabin.
    Would anyone know where that post might be?
    Thanks so Much!
    Doug N8EKL in Ohio
    Gunshot-6A likes this.
  6. Nov 7, 2019 at 11:45 AM
    #5826
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    @Cudgel and eventually me.
  7. Nov 7, 2019 at 11:51 AM
    #5827
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Hi N8EKL...here is info from my electronics build threads on the power antenna I used:
    https://www.tacomaworld.com/threads/cudgels-build-thread.600420/#post-20174395
    I'm happy to provide more details as well.
    73
    Thanks @Gunshot-6A
    m603holden and Gunshot-6A like this.
  8. Nov 7, 2019 at 11:55 AM
    #5828
    Gunshot-6A
    Conner
    Everett, WA
  9. Nov 7, 2019 at 11:59 AM
    #5829
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    In order for it to reverse, you need to cross both the + and the - poles...this cannot be accomplished with a single pole.
    1 2 (leads out) +/-or -/+
    3 4 (line in) +/-
    5 6 crossed with 2, 1
    Gunshot-6A[QUOTED] likes this.
  10. Nov 7, 2019 at 12:00 PM
    #5830
    Gunshot-6A
    Conner
    Everett, WA
    ah, that makes sense since its a rotary motor you need to turn both ways.
    m603holden and Cudgel[QUOTED] like this.
  11. Nov 13, 2019 at 8:13 AM
    #5831
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Anyone have any fun home brew HF antenna projects they can suggest? Looking for some more gain at a lower take off angle. Could even be monoband
  12. Nov 13, 2019 at 9:00 AM
    #5832
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
  13. Nov 13, 2019 at 2:00 PM
    #5833
    Gunshot-6A
    Conner
    Everett, WA
    Maybe a 10m Slim Jim?
  14. Nov 13, 2019 at 3:11 PM
    #5834
    nats
    nats Well-Known Member
    Lakewood, CO USA
    '10 TRD Sport DCSB
    (this will change)
    What kinda stuff have you tried so far?
    • Verticals can give nice low angles
    • Have you tried a quad
    • Add a director element for an existing antenna (horizontal wire dipole, etc)
    • CobWebb can do like 15° for a main lobe at reduced height
    • Co-phasing can be a trip as well
  15. Nov 13, 2019 at 11:44 PM
    #5835
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    I setup an 80m vertical on the back of my taco. Mast is a 18m spiderbeam fiberglass stuck into a hitch flagpole mount. Used a piece of wire as the driven element with 3 ground radials. Sets up in about 5-10 min and has a wonderful takeoff angle. I'd like to measure and cut some additional radials.
  16. Nov 14, 2019 at 3:10 AM
    #5836
    m603holden
    Marteeen
    New England
    I've been warned that if you live near a large population that verticals can be "noise sticks". Any merit to this?
    I was looking at a cobweb too! Although if I read correctly it's only a minor increase of gain over a dipole.
  17. Nov 14, 2019 at 8:48 AM
    #5837
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    its true about verticals, thats why i have a myriad of different antennas. When i get get all my antenna projects done i will have the following. 80m dipole fed with ladderline, hexbeam, OMTA ( Offset Multiband Trapless Antenna), 10m vertical, MIDI magnetic loop and VHF vertical.
    Different antennas for different bands for different settings.... NOT ONE antenna can do it all.....
    m603holden likes this.
  18. Nov 14, 2019 at 8:56 AM
    #5838
    Gunshot-6A
    Conner
    Everett, WA
    @m603holden needs to get on the high angle SATCOM train!
    nats likes this.
  19. Nov 14, 2019 at 10:41 AM
    #5839
    m603holden
    Marteeen
    New England
    Yep I've got an 80m ocf at a low height for 80/40 NVIS and North/south lobes for 20, and my 40m ocf at a good height for east west lobes.
    I'll probably run a true 80m nvis, eventually a hex beam, and a cubical quad at some point.
    I did see some cool plans for a 2 element field 40/20 yagi. Might give that a go in the backyard.
    BenMara likes this.
  20. Nov 15, 2019 at 9:22 AM
    #5840
    tex.proud
    tex.proud Jesus Christ It's Midnight!
    Huntsville, TX
    2018 White SR5 4X4
    3" OME lift with SPC UCA's HD Dakars Shrockworks Sliders KO2's 165/75/16 Decked bed system CaliRaisedLED mount for Everhardt CB Antenna President Bill FCC CB Yaesu FTM-400 HAM radio and Larsen antenna through roof. TVD Vinyl Decals for the tailgate (Black Reflective) and U.S. Flag decals SofTopper (Black) Empyre Offroad Grill Blacked out badges (PlastiDip)
    Gave me a laugh!
    DaveInDenver, nats, BenMara and 2 others like this.
