Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Jan 20, 2020 at 1:01 PM
    #6201
    Dyingyak
    Dyingyak Well-Known Member
    Brandon
    Baldwin County, Alabama
    2019 DCSB 4x4 TRD Sport
  2. Jan 20, 2020 at 1:13 PM
    #6202
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    If you get your ticket we can help you look for used gear too if you'd like to keep it affordable. Not sure what your budget is. Another good resource are the VE's you'll take the test with. Chances are they'll be part of a local club and they might even have something to lend you while you get into it. They'll most likely be very nice people.
    It's a weird test. It's nice because everyone there wants you to pass. If you need any help or have questions don't be shy about asking.
    Especially with a dope username like yours. Love me some corgi butt.
    Typical mobile set up you're looking at
    -Radio
    -Coax cable
    -Antenna (+how you'll mount it)
    Really you can get into it for under $80 with a handheld radio, mag mount antenna, and cable.
    My man
  3. Jan 20, 2020 at 1:18 PM
    #6203
    m603holden
    Marteeen
    New England
    I used this. But also watch some YouTube videos. Ham Radio crash course is another OK one.
    Tons of views on how to study. I'm in the camp of studying the answers to pass the test. The real learning came for me when I started to use my license. I knew where to refer to in the books and applied it. Before it was just text. When you're using the info it becomes a bite more tangible.
    Gunshot-6A likes this.
  4. Jan 20, 2020 at 1:31 PM
    #6204
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Thanks for the responses.
    I think I will get the book. I want to know some of the theory in addition to the test questions.
    But, as @m603holden said, it is just text until you start using it.
  5. Jan 20, 2020 at 1:34 PM
    #6205
    m603holden
    Marteeen
    New England
    Yup. Don't get me wrong. Still read through it. But more so do it so it becomes familiar and when you need it you'll know where to look.
  6. Jan 20, 2020 at 2:04 PM
    #6206
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
    When installing my radio, programming it, and looking into other functions (satellites, APRS, SSTV, I learned a lot about what I was reading. I got active before I was licensed. I built a TNC and started a dual band yagi before I tested. Made sense when I started playing with the hardware.
    m603holden likes this.
  7. Jan 20, 2020 at 3:14 PM
    #6207
    HP11
    HP11 Well-Known Member
    NH
    2019 Cement Tacoma TRD Sport
  8. Jan 20, 2020 at 3:28 PM
    #6208
    Tacoma_NC
    Tacoma_NC New Member
    Andy
    Wallburg, NC
    2017 Gray DCSB TRD Off Road
    Quick intro - Newbie to Tacomas but have been in the commercial two way business / licensed ham for 30+ years, callsign is NC4AB.
    I managed to skim all 313 pages of this thread over the past couple of days looking to pick up some ideas for mounting an ICOM 7000 and now have some things to try when I get my truck this week.
    Thanks to all the contributors for the many ideas !!!
    Andy
  9. Jan 20, 2020 at 3:46 PM
    #6209
    m603holden
    Marteeen
    New England
    Solid second post! Welcome!
    Tacoma_NC[QUOTED] likes this.
  10. Jan 20, 2020 at 4:41 PM
    #6210
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    So if I’m hooking up the d710 to my blue sea can I eliminate the fuses at the terminal connectors and just keep the other fuse closest to the radio? The blue sea is fused but didn’t know how that would work. There would basically be 3 fuses in Line if I didn’t. Also does the d710 have to be turned on or is it possible to put it on a switched circuit with one of my relays?
    k8md likes this.
  11. Jan 20, 2020 at 4:54 PM
    #6211
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You want the fuse at the blue sea as it is closest to the battery
    I have also heard that the fuse at the radio is good to keep and can prevent you from blowing your radio.
    Im keeping both fuses
  12. Jan 20, 2020 at 5:01 PM
    #6212
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Correct but the wires I’m seeing on some of the videos it has a fuse at the battery connection (they aren’t using blue seas they are just connecting straight to the battery. In theory I should be able to cut that one out right ?
  13. Jan 20, 2020 at 5:55 PM
    #6213
    anthony250f
    Anthony
    San Diego, CA
    If you are connecting it at the blue sea then that will be your replacement for the fuse that you are seeing right at the battery post.
  14. Jan 20, 2020 at 6:58 PM
    #6214
    joshuajayg
    Moab
    For any of you that are into building your own stuff, I found a voltage sensitive relay circuit. I plan to use this to turn off the TNC I will have connected to my radio under the seat. I may also look at how to make a time delayed voltage sensitive relay.
    For those of you with a dual battery setup and auto disconnect relay, this is the same circuit you use. Or if you have a simple time delay relay, it's the same idea still. I don't have another battery wired in but that may come in time.
    http://www.easymades.com/2019/01/dual-battery-system-part-01-diy-voltage.html
    BenMara and MonkeyProof like this.
  15. Jan 20, 2020 at 7:02 PM
    #6215
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Found the antenna and ordered so for a complete mobile setup I’m in it for just north of 600.00 I just about threw up.
    Also incase anyone was in the market for a new radio but not in a hurry. I was so torn between the d710 ga and the 400xdr I added both to my cart @ gigaparts.comband let them sit there flip flopping back and forth between two. After letting them sit there over night probably about 16 ish hours or more I get an email from gigaparts. “You’ve got great taste” “but hesitant on placing your order? This might entice you” and it was code for almost 25% off. So I deleted the 400xdr and it dropped the price of the d710 down to 479.99 so I took the chance and ordered the d710. Now we wait.
    Kheiron, Gunshot-6A, k8md and 3 others like this.
  16. Jan 20, 2020 at 7:07 PM
    #6216
    joshuajayg
    Moab
    I did a similar thing. They sent me an email with a discount. 10% off. I waited still because I wasn't ready to buy. Got another email; 15% off. Later I got a third back to 10% off. I used the 15% off code. My total bill came in at $425.82.
  17. Jan 20, 2020 at 7:09 PM
    #6217
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Yep. It seems they are the best when it comes to it for me. I couldn’t deal with hro’s website it’s so damn hard to search on there so I said screw it
    Gunshot-6A, stu8319 and BenMara like this.
  18. Jan 20, 2020 at 7:14 PM
    #6218
    joshuajayg
    Moab
    I also liked the customer support at gigaparts.com. I used their chat and the guy was helpful. I think you said you also chatted with a lady who was trying to help you decide on what to get.
    Newlife likes this.
  19. Jan 20, 2020 at 7:51 PM
    #6219
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Yep. She was leaning me more towards the 400xdr but she did tell me whatever I buy as long as I don’t trash it they have a 30 day return so I can swap it out. I just hope that doesn’t happen lol.
  20. Jan 20, 2020 at 7:59 PM
    #6220
    Atomic
    Atomic Master Cylinder
    New Mexico
    13 TRD Sport Double Cab Long Bed
    I am just starting to study for technician level. Looking at the Any Tone Tri-band DMR radio model: AnyTone AT-D578UVIIIPRO.
