Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Jan 24, 2020 at 7:30 AM
    #6261
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    “Antenna Gain Patterns” attempt to predict what direction in space (3D) a particular configuration will produce. They are not absolute, as they are data points measuring some gain at certain frequencies. For your goals these are “examples”, with the takeaway being it is typical to see a trend of a more symmetrical pattern when the reflective plane is also more symmetrical. Or, center of roof is more even than on the bumper.
    Just because it can be measured, doesn’t mean it is true, or that it matters. And small moves towards center of mass can help if you have drop outs or truly one direction bias. Most old timers have their transmitting antennas high and centered, because it both theoretically and for the most part in the field works well. Some CB drivers (long haul) will keep it off to one side as it may give them more distance along the path of travel.
    The phrases “ground plane” and “ground” are often confusing and hotly debated (in a jovial and fun way as is the norm of hams, not like the debates over oil change intervals)...I digress, for the gain patterns (remember that was the question I’m answering!), consider your whole truck the “ground plane”, not just a space like the roof. Think “center of mass”, then tighten you radius from you antenna to 3x your wave length, and 2x and 1x etc...the further away inside these concentric circles you have stationary interference (vertical metal shit), the less likely it will couple (fuck up) your transmit signals...so for 462Mhz, try not to have vertical metal surfaces within two feet for 1x.
    GMRS 462+ Mhz FM benefits from a vertical antenna as high as possible (FM) that is tuned to typically a 1/4 wave. (About a smidge over 6 inches), so they are popular with recreational/family usage.
    These are line of sight transceivers, so yes trying not to block the antenna on the horizontal is good practice.
    Hopefully others will comment, as these are really my opinions.
    llibrm and Naveronski[QUOTED] like this.
  2. Jan 24, 2020 at 7:37 AM
    #6262
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Thank you!
    These posts really are helpful. I never would have expected that a 6” antenna in the middle of the truck would be better than a 32” mounted on the rear. It’s just so counterintuitive; I expected the longer antenna to be much better, particularly based on Midland’s marketing: “This 32-inch whip antenna quadruples signal output... maximum range... 6db gain.”
    k8md and Gunshot-6A like this.
  3. Jan 24, 2020 at 8:08 AM
    #6263
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Well they aren't wrong...just that you need to mount it in an optimal spot to get those figures.
    k8md, Naveronski[QUOTED] and Cudgel like this.
  4. Jan 24, 2020 at 9:00 AM
    #6264
    Naveronski
    Fort Worth
    Also, my main concern is receiving signal.
    I don’t seem to have any issue transmitting.
  5. Jan 24, 2020 at 9:00 AM
    #6265
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    The above is the correct theory, its just that
    The below makes more of difference
    Do both!
  6. Jan 24, 2020 at 10:24 AM
    #6266
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    One more thought - the vehicle can block some of the effective antenna length.
    Think about a bumper mounted antenna - the length of antenna from the base to the top of the vehicle is essentially not effective, due to (I believe) the absorption of the signal by the body of the vehicle.
    A shorter antenna on the roof will be (potentially) more effective than a longer one on the bumper. Yes, there is a lot of theory/physics I am glossing over.
    For simplicity, I have always mounted antennas on the roof - high and centered in the vehicle.
    Naveronski likes this.
  7. Jan 24, 2020 at 1:59 PM
    #6267
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    Red Baron likes this.
  8. Jan 24, 2020 at 6:15 PM
    #6268
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    When you realize how much RF is capacitive, then it starts to click.
    Cudgel likes this.
  9. Jan 24, 2020 at 6:17 PM
    #6269
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
    Got my call sign today. KJ7LVZ. No one to talk to :( And my TNC and radio aren't clicking yet. Tomorrow is play day, now I can figure things out.
    CO MTN Steve and k8md like this.
  10. Jan 24, 2020 at 8:26 PM
    #6270
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Just made my first call. Hit a repeater about 35 miles from my location and got a confirmation from a guy about 75 miles from my location.
    cosmicfires, m603holden, k8md and 5 others like this.
  11. Jan 24, 2020 at 8:27 PM
    #6271
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    That’s always a good feeling.
    Congrats!
    m603holden and Newlife[QUOTED] like this.
  12. Jan 25, 2020 at 7:51 AM
    #6272
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I'm just over in GJ, let me know if I can help.
  13. Jan 25, 2020 at 9:27 AM
    #6273
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I cannot say enough good things about that rt systems software. It took about 20 minutes to get everything loaded into it and set up the way I wanted it then about 5 minutes to go out to the truck with my tablet and program the radio.
    CO MTN Steve, Sand Dog and Kheiron like this.
  14. Jan 25, 2020 at 11:49 AM
    #6274
    brentw59
    brentw59 Well-Known Member
    Brent
    Clovis CA
    2017 Tacoma 4x4 DCSB Manual Inferno
    Basic Shit. Floor Mats, Seat Covers
  15. Jan 25, 2020 at 1:04 PM
    #6275
    medic2230
    Murph
    Bama! Roll Tide
    We’re going to be here all night for Winter Field Day. Working some sat’s in about an hour.
  16. Jan 25, 2020 at 1:10 PM
    #6276
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I have the same travel trailer! We are currently putting ours up for sale.
    medic2230[QUOTED] likes this.
  17. Jan 25, 2020 at 1:11 PM
    #6277
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    So on the drive to work I was scanning through my saved frequencies. Somehow I accidentally programmed several gmrs frequencies in. From my understanding I can listen and still be perfectly legal right? I just can’t transmit.
  18. Jan 25, 2020 at 1:32 PM
    #6278
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    You are only allowed to transmit in the frequencies for your license. The ARRL has a handy bend chart that lists the frequencies for each ham license level.
  19. Jan 25, 2020 at 1:35 PM
    #6279
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Correct I know that. I’m asking if i need to remove that from my programming or am I good to just listen on it.
  20. Jan 25, 2020 at 1:35 PM
    #6280
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    you can listen, just not transmit
    Newlife[QUOTED] and Cudgel like this.
