Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Jan 26, 2020 at 8:48 AM
    #6301
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Honestly if I ever come into money I think the IC-7300 is the radio I'd buy. I already have an AH-4 (used to have an IC-7000 that I stupidly sold). I still have a FT-857 and that's another proven radio, although long in the tooth technology wise but still a solid analog radio when you put in a couple of decent Collins filters. I have an ATAS-120 to use with it. Not the best performance but the interface is seamless at least. Mainly they can be found pretty reasonable used, half the price of a FT-991.
    Kheiron[QUOTED] likes this.
  2. Jan 26, 2020 at 12:52 PM
    #6302
    medic2230
    Murph
    Bama! Roll Tide
    I’ve really been digging my 991a.
    gixxerphil, HP11, BenMara and 3 others like this.
  3. Jan 26, 2020 at 1:45 PM
    #6303
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    They are neat radios. If I didn't already have plenty of VHF and UHF radios and needed a complete shack-in-a-box solution it would top of the list, no doubt. I've always liked Yaesu radios.
  4. Jan 26, 2020 at 2:11 PM
    #6304
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I'm not really sure what you mean by that, but I'll go with it.
    I'm shopping for an antenna for my roof:
    1/4 wave
    NMO mount
    Spring to survive accidental contact with trees?
    Ability to fold down when not in use to keep it out of the way/avoid parking garages.
    Any other criteria I should add?
    Any brand recommendations that are good or over rated?
  5. Jan 26, 2020 at 2:12 PM
    #6305
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    So, you’re suggesting an IC-7300 in a pelican or something to operate out of the truck with, but not use like I would my d710?
  6. Jan 26, 2020 at 2:15 PM
    #6306
    Kheiron
    Kevin
    Powell, WY
    2017 OR DCSB QS
    I put a 48” comet 2x4sr on a ditch light bracket and I was able to fold it down (the antenna folds) in garages. It worked pretty well there. It is now on my bumper.
  7. Jan 26, 2020 at 2:34 PM
    #6307
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    How'd you guys do Murph?
  8. Jan 26, 2020 at 3:05 PM
    #6308
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    W1FOY, js8 would have been a new one for me. Had a great time this weekend. Stayed mostly dry, @m603holden brought an ice fishing shack. Kept three dudes dry and warm. 10/10 would do again.
  9. Jan 26, 2020 at 4:04 PM
    #6309
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    FT-991A can be mounted in a Shack in a Box....
  10. Jan 26, 2020 at 4:32 PM
    #6310
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Depends on what you're after. The IC-7300 looks to me like a pretty good direct sampling HF radio. It's fairly small and light, too. Would be useful for portable, like in a go box or just carrying to Field Day.
    But it doesn't have 2m or 70cm, only has one tuner and the case isn't design for mobile, face doesn't separate or anything. So I don't think it really overlaps the use case of a TM-D710 with dual band 2m & 70cm, wide band receive of VHF and UHF, ability to do APRS.
    If you need a single radio that can do just about everything the FT-991 might work. Icom's competition to the FT-991 is the IC-7100, which does most of the same things but does not have a digital mode (the FT-991 can do Fusion).
  11. Jan 26, 2020 at 4:36 PM
    #6311
    Kheiron
    Kevin
    Powell, WY
    2017 OR DCSB QS
    I have a 710 so I could roll with both. How often are guys using HF while driving or while passengers in their vehicle? It seems like it might be easy to just run the 7300 or something similarly sized portable.
  12. Jan 26, 2020 at 4:41 PM
    #6312
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Do you mean IC-7100 or TM-D710?
    As far as mobile HF, that's why I bought the FT-857 originally. I find it difficult to do much more than roll through a few memory channels while driving so I didn't really do much actual mobile operation. Then I found when I got to camp having the radio mounted in the truck wasn't any good. Much preferable to sit at a table or at least use the tailgate as a table than sit in the cab. Plus the limitation of mobile antennas, it was pretty much meh. Just not for me, it was mostly just a fancy VHF/UHF radio with only one VFO. I'd rather have a portable HF station with a decent tuner and wire antennas.
  13. Jan 26, 2020 at 4:48 PM
    #6313
    Kheiron
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Copy. I have the D710Ga.
    I am looking at a job at Mount Rainer National Park. There isn’t much going on out there outside of work. There is a 1.25m repeater out there which may force me into that band.
    But, it would be stupid to waste all of that time at that elevation and not play with radios.
    DaveInDenver[QUOTED] likes this.
  14. Jan 26, 2020 at 5:01 PM
    #6314
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Well, 1.25m is 220MHz and not a lot of options for that. I'd probably suggest getting a Yaesu VX-6R while they are still being made. It's down a little on 1.25m only doing 1.5W compared to 5W on 2 and 70 but at least it does it and is a pretty good HT in general.
    If you're thinking maybe day hikes to activate peaks (SOTA, Summits On The Air) or something like you have lots of options depending on your budget and what you want. For hiking the FT-818, KX2 or KX3 or the new IC-705 are options. I had a FT-817 and ended up selling it because the FT-857 doesn't burn all that much more power at 5W TX (the FT-817 is pretty inefficient even on RX) but eliminated the need to carry around a linear amp since the FT-857 can be dialed up to 100W. The Elecraft radios are nice full featured radios, if you have the budget.
    Personally I think a true QRP radio, like a 1W 20m or 40m CW radio in an Altoids can makes a better backpacking outfit that you bring along for trips lasting days. Then have a reasonably compact station that can be packed up and carried a couple of miles if you want to do an all day operation. That's what my FT-857 has become. I have it in a small soft case with a LDG Z-11pro, a 5A-hr battery and some wire antennas. All of that plus regular stuff like a couple of Nalgene bottles, my Crazy Creek and a jacket fit in a large daypack.
    The IC-7100 or FT-991 (or FT-891 if you don't need 2/70) could be all in one, except 1.25m. But they are not quite light enough to more than carry a little bit. They could be built like a manpack radio, though.
  15. Jan 26, 2020 at 5:26 PM
    #6315
    Kheiron
    Kevin
    Powell, WY
    2017 OR DCSB QS
    So
    Many
    Options
    I had never heard of SOTA. And I really never thought I would be into portable use either. Now I want like 6 radios. Thanks for that, lol.
    @koditten?
  16. Jan 26, 2020 at 6:02 PM
    #6316
    medic2230
    Murph
    Bama! Roll Tide
    Pretty good. Managed to get 2 sat contacts this morning around 6:30.
    I wasn’t present for it though. We spent too late sitting around the campfire sipping on spirits so we were still in the bed at that time. :anonymous:
  17. Jan 26, 2020 at 6:11 PM
    #6317
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    Pics or it didn't happen.
  18. Jan 26, 2020 at 6:14 PM
    #6318
    m603holden
    Marteeen
    New England
    cosmicfires, Cudgel, HP11 and 6 others like this.
  19. Jan 26, 2020 at 6:14 PM
    #6319
    k8md
    Bob
    Do you need a spring on a 6" antenna? I wouldn't think so. 1/4 wave whips are pretty flexible. If you're really concerned about it, I'd get a nitinol whip from stico. More durable then a typical stainless whip.
    Gunshot-6A likes this.
  20. Jan 26, 2020 at 6:14 PM
    #6320
    m603holden
    Marteeen
    New England
    Ft-891
    DaveInDenver likes this.
