Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Feb 27, 2020 at 6:54 PM
    #6681
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Glad I could help! I had a little bit of difficulty hitting the repeater myself so it was good to get some practice getting the settings right
    m603holden and Old Marine Cal like this.
  2. Feb 27, 2020 at 7:37 PM
    #6682
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Not at all. Run aprs on one side, chat on the other. KISS .
  3. Feb 27, 2020 at 7:57 PM
    #6683
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
    @m603holden is 9ne of the main reasons I purchased the TM-V71A as my first radio. The gigaparts guy told me I wanted the FTM-400 but I was leery. I like the option to run other data modes through the data port on the TM-V71A and it is a simple enough radio, I'm not overwhelmed. Simple to use while on the move. I don't regret it at all. I already had a cheap Samsung tab 3 for APRS and spend a couple dollars building my own mobilinkd with bluetooth. I don't use proprietary digital modes.
    m603holden likes this.
  4. Feb 27, 2020 at 7:58 PM
    #6684
    joshuajayg
    Moab
    And no, I don't find dedicating one side to APRS to be a hindrance. If I'm not running APRS, I shut the second side off anyway.
  5. Feb 27, 2020 at 8:11 PM
    #6685
    m603holden
    Marteeen
    New England
    They're neat to explore, but I'd still take a good Fm signal when push comes to shove and the conditions suck.
    The digital modes sound different, but I don't think they really sound better.
  6. Feb 27, 2020 at 8:19 PM
    #6686
    m603holden
    Marteeen
    New England
    BEAR_KNIFE_FIGHT likes this.
  7. Feb 27, 2020 at 8:26 PM
    #6687
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    this appears to combine two interests -- radios and gratuitous amounts of 18650 batteries (i can only assume)
    Cudgel likes this.
  8. Feb 28, 2020 at 12:04 AM
    #6688
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Oh boy does it.. at one time i had 5 V/Uhf radios some where in this thread i listed HF rigs ive had, thats not including Antenna trans match, power supplies, coax, meters, antenna analyzer or Antennas.... its a black hole once you get addicted
    Got amped up cause yall posting up about APRS i turned on the modem
  9. Feb 28, 2020 at 2:15 AM
    #6689
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    If you install a 2nd radio for VHF, it will de-sense the FM voice radio on 2m each time it transmits. Not a huge deal. I used to run a Motorola CDM1250 dedicated to APRS with a mobilinkd and ft-8900 for voice. It was a great setup.
    Nothing beats that tm-d710g. Even if you don't use the APRS, I love the control head.
  10. Feb 28, 2020 at 5:02 AM
    #6690
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Before we move on from APRS, I want to add that there are a lot of advantages to running an handheld APRS setup. Especially if you get out and hike (I know, exercise is not a topical HAM activity). I have a Kenwood TH-D72a that for a while I had hooked up to an AvMap GPS in my truck. Kept it in my center console, had an external antenna and plugged into power. Wasn't 50w transmit, but in my travels across my state, the 5w worked 98% of the time (less is more). The other benefit with the 72 (they have a 74 out now with color and more things) is taking it hiking, using it's built in GPS and digital compass. Got a furry friend or kid, put a cheap APRS tracker on them and use your radio to track them if they get lost. I like dual function things, use in truck on trail and trips, pull it out and use it on trails. Kenwood has the ability for some HTs to control their mobile radios.
    AvMap closed up it's N American ops (Except Farm and aviation) and I couldn't get any help from them. There are some models of older Garmin you can connect up to radios, I didn't go that route, so not sure what all is involved.
    You don't NEED a dedicated APRS radio, but I found it nice to have one. I volunteer with a HAM radio group and we often have traffic going on two nets. Also, I don't always want APRS turning on when I turn on my radio. For trails and stuff, I don't always travel with HAM only folks, so I set one side to the trail freq and the other to monitor the FRS freq that the none hams are using. Nice to have APRS doing it's thing out of the way).
    edit: I also use the HT APRS on my motorcycle and packed it on flights so I had it with me
    C41n and DaveInDenver like this.
  11. Feb 28, 2020 at 5:10 AM
    #6691
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    The advantages to digital modes such as Fusion, DMR, P25 and especially D-STAR and NXDN, is they use spectrum more efficiently. So 6.25KHz or the equivalent (e.g. time or frequency dividing a 12.5KHz channel for two information streams) of bandwidth is sufficient for nearly the same audio clarity as we use for 25KHz of analog FM. That's why it exists commercially. We don't have as much issue with needing narrowband to fit everyone like they do with public service and business radios so it's not as much of an advantage for us.
    It handles fringing a bit better, e.g. it doesn't audibly fade at the margin. Although when the bit error rate gets high enough the audio goes from clear to garbled so it's far from perfect. But there's a region where analog gets noisy that digital remains clear until it just stops working.
    The main reason I think people like tinkering with digital (I'm a DMR user) is the ability to network repeaters over the Internet. Analog can do it with IRLP and Echolink and D-STAR has always had this but Motorola IPSC and C-Bridge made it relatively simple with their DMR repeaters and of course Brandmeister with all brands has created tons of talk groups.
    Another reason I run it in mobile is so that I can use DMR HTs. The good thing about that is the battery lasts considerably longer, digital modes use the transmitter more efficiently.
  12. Feb 28, 2020 at 5:20 AM
    #6692
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I find having dedicated APRS stations better.
    rob1208 and Chipskip[QUOTED] like this.
  13. Feb 28, 2020 at 5:33 AM
    #6693
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    I truly feel sorry for the non hams. Kinda like a bad lift or changing oil too often.
  14. Feb 28, 2020 at 5:35 AM
    #6694
    m603holden
    Marteeen
    New England
    Yep. Once again though I think it's community and location based.
    To pair a feature that requires internet, repeaters, (<~~~~~2 features mostly found in populated areas) or other users to have the same brand radio as you with a feature (APRS) that is best utilized In Remote areas or with grid down / emergency situations (Ares, traditionally require external tnc access) has always just been a bit of a questionable move for me with the ftm line.
    Digital is nice, but it's very conditional. I'm a DMR guy as well and it's great as a stand alone feature like in A HT as I mentioned above, just not sure I'd ever want it paired with a mobile.
  15. Feb 28, 2020 at 5:43 AM
    #6695
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Mobile DMR (really any digital mode) only becomes useful if there's on the air DMR repeaters with a network bridge. I use a local DMR repeater (I'm in western Colorado, about 200 miles west of Denver now) to kick on a talk group that's been linked across several others with various modes (even analog). It lets me keep in touch with some ham friends back over in Denver.
    http://skyhublink.com
    Basically I just dislike hot spots and streaming over your cell phone. What's the fun in that? An HT is essentially just a wireless mic for a computer. Meh.
    golfindia and m603holden[QUOTED] like this.
  16. Feb 28, 2020 at 5:56 AM
    #6696
    m603holden
    Marteeen
    New England
    Brandmiester.
    I can be driving with my HT in NH getting into the net and coming out the repeater in Alabama to my buddy @medic2230 as he drives around In his truck. That's probably the biggest advantage of a hot spot. And also large groups coming together for an event can all hop on one Tac channel (dmr).
  17. Feb 28, 2020 at 6:16 AM
    #6697
    m603holden
    Marteeen
    New England
    They get the bubble pack treatment. Haha. Sucker sits right in my cup holder.
    I roll with the ham mobile, the cb, and a bubble pack ht in the back of cubby cup holder.
    9/10 I respond on the cb radio after my name it called for the 5th time and I catch it with the volume at 20% :rofl:
  18. Feb 28, 2020 at 6:29 AM
    #6698
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    My local repeater (W0BX) is a node on Brandmeister. I understand why people use hot spots, I'd just rather not. It's a finessed distinction since a DMR repeater is just a hot spot on steroids but I like the idea that others around town can hear and we could chat locally if no one else happens to be in the wide area talk group.
  19. Feb 28, 2020 at 6:43 AM
    #6699
    m603holden
    Marteeen
    New England
    I guess my point is that most places that have digital repeaters also have cell phone service. So unless you're specifically looking for a digital mode radio that you can use at over 20 miles out, I'd argue looking at other mobile radios with other features, and that pairing digital with a locked aprs rig was a terrible idea haha.
    DaveInDenver likes this.
  20. Feb 28, 2020 at 6:48 AM
    #6700
    m603holden
    Marteeen
    New England
    We need a ham green room to not scare newbies away with tec talk. Haha.
    Hope everyone understands these are all great radios and it's 100% preference and opinions.
    jkcashin, Gunshot-6A and DaveInDenver like this.
