Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Mar 11, 2020 at 7:41 AM
    #6941
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    That sounds like a fairly typical construction technique. Start with one very long piece of magnet wire that you fold hard at what will become point 1 and then twist enough to make wraps 1 and 2, leaving one long and one short tail. The short tail hanging out becomes the center conductor on the SO239. The long tail continues wrapping to make turns 3 through 14 and becomes the long wire feedpoint. You go back, nick, strip and tin where you folded the wires to make the common. You could wrap a string around the cores to measure how much length needs to be twisted. Or wrap the twisted length backward, the underside of winding 2 as your starting point.
    BTW, when I refer to wraps 1 and 2 it's from your graphic since WA7ARK appears to have used 3 primary windings on the core and 21 secondary.
  2. Mar 11, 2020 at 7:48 AM
    #6942
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Yes.
    Was just wonder if in reality there's a difference between a set up that's folded vs one that's soldered together.
    I assume not. But I figured in passing curiosity I'd ask.
  3. Mar 11, 2020 at 7:51 AM
    #6943
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    You could leave a loop instead of folding it. Burn off some enamel and just put the loop under the common screw head, if that's what you're thinking. There's no difference electrically, just mechanically. Soldering on a ring terminal might be slightly more robust is about all that comes to mind. You'll need an exposed section of bare wire for the cap lead, too.
  4. Mar 11, 2020 at 7:55 AM
    #6944
    m603holden
    Marteeen
    New England
    Yeah that's how I have my other one set up, is with a ring terminal. I've got a smaller one being set up for qrp and the wire broke while winding it right at the fold. That's what sparked the whole "I wonder" spin. Lol
  5. Mar 11, 2020 at 7:57 AM
    #6945
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    You're correct, won't matter as long as you keep the construction tidy.
  6. Mar 11, 2020 at 7:58 AM
    #6946
    m603holden
    Marteeen
    New England
    @DaveInDenver I think the plan is this spring to go out and test a whole bunch of antennas on the mtn top just for kicks and giggles and to see how our handle built antennas really match up. Both at 100w and qrp. Should be fun.
    krandolp, ETsemaj and DaveInDenver like this.
  7. Mar 12, 2020 at 5:42 PM
    #6947
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    I like fun. I make antennas.
  8. Mar 13, 2020 at 4:59 AM
    #6948
    m603holden
    Marteeen
    New England
    Could set the pole up....
  9. Mar 13, 2020 at 5:11 AM
    #6949
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Is that ice?
    F- that.
    Kheiron likes this.
  10. Mar 13, 2020 at 5:14 AM
    #6950
    medic2230
    Murph
    Bama! Roll Tide
    I think that’s a frozen lake.
    m603holden likes this.
  11. Mar 13, 2020 at 5:18 AM
    #6951
    m603holden
    Marteeen
    New England
    Yep. Super easy to set up. Popped a couple ice anchors, guy lined them up, had a pulpy set up for the antennas.
    Maybe 15 minutes to set up Tim once I got everything over there and unpacked? With a second and set of hands of course.
    @foy1der
  12. Mar 13, 2020 at 5:49 AM
    #6952
    m603holden
    Marteeen
    New England
    Haha not anymore. Been having 60* days up here
  13. Mar 13, 2020 at 6:47 AM
    #6953
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    This is why I love Ohio NVIS day. We typically setup 4-ish antennas with an antenna switch on one rig. Every contact we will switch through the antennas and ask for a signal report and ask the other station to rank the antennas and let us know which was best. We keep a log of it all. Testing NVIS primarily on 40m and 80m.
    Turnstile dipole is usually the big winner. Although an 80m full wave horizontal loop does just a little better, it's more complex to setup portable.
  14. Mar 13, 2020 at 4:04 PM
    #6954
    foy1der
    W1FOY
    2017 OR DCLB
    What a damn fun weekend
    m603holden and medic2230[QUOTED] like this.
  15. Mar 13, 2020 at 4:22 PM
    #6955
    golfindia
    Yes.
    pickup truck
    I've never seen a frozen lake in person. And I don't want to.
    Hemibee and m603holden like this.
  16. Mar 13, 2020 at 4:46 PM
    #6956
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Cheapest route is the mag mount but I, like you, didn't want a mag mount because I enjoy my paint too much.
    Nagoya RB-700N Heavy Duty NMO Lip Mount , NMO antenna I got a nice 1/4 wave because parking garage life, then a SMA male to SO-239 adapter like one of these
    I have the antenna mounted on my hood, driver side. Then I have my Radio mounted to my dash via ram ball mount and custom tray.
  17. Mar 13, 2020 at 6:03 PM
    #6957
    golfindia
    Yes.
    pickup truck
    Hood lipmount here too.
    Diamond SG7900 and diamond K400 mount.
    No RF exposure lessons thanks. I never use more power than necessary to complete communication.
    czach, tex.proud and m603holden like this.
  18. Mar 13, 2020 at 6:08 PM
    #6958
    m603holden
    Marteeen
    New England
    @foy1der Merrill calls that his ______ curve for 500.....
  19. Mar 13, 2020 at 6:09 PM
    #6959
    m603holden
    Marteeen
    New England
    It's a blast when there's water, frozen water, and 4 more inches of water on top of that frozen water.
    But hey, they got a satellite pass!
  20. Mar 13, 2020 at 6:45 PM
    #6960
    tex.proud
    tex.proud Jesus Christ It's Midnight!
    Huntsville, TX
    2018 White SR5 4X4
    3" OME lift with SPC UCA's HD Dakars Shrockworks Sliders KO2's 165/75/16 Decked bed system CaliRaisedLED mount for Everhardt CB Antenna President Bill FCC CB Yaesu FTM-400 HAM radio and Larsen antenna through roof. TVD Vinyl Decals for the tailgate (Black Reflective) and U.S. Flag decals SofTopper (Black) Empyre Offroad Grill Blacked out badges (PlastiDip)
    That is on outstanding performing antenna! I've used it on 2 vehicles in different locations, and always has incredible ears, and great get-out.
    golfindia[QUOTED] likes this.
