Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Apr 10, 2020 at 10:59 AM
    #7081
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Good old 9913 has lower loss than LMR240 @150 and at 450 megs it significantly better That's what is on my personal tower for the VHF/UHF sticks. Yep it's a larger diameter that has a lot to do with it's lower loss (a good bit cheaper too). In short runs there is not a lot of difference between RG8X and LMR 240. We have had issues with LMR at repeater sites with water intrusion.
  2. Apr 10, 2020 at 11:14 AM
    #7082
    btreible90
    btreible90 Well-Known Member
    Bryan
    New Hampshire
    2017 White Tacoma TRD Off-Road
    Yeah I got my fingers crossed especially if this continues on. Going to keep an eye out for it
  3. Apr 10, 2020 at 11:33 AM
    #7083
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    An S-unit is 6dB, or supposed to be. Path loss (e.g. range) is very approximately the square root of the power ratio. Double the power you get 1.414 times the range. So losing 2 watts of 5 watts in feed line means you have roughly 3/4 of the range. It's not catastrophic but in this case using RG-174 probably negates any antenna gain you might have. In the case of the 60 feet of RG-8 I mentioned just means my antenna having 5.5 dB rated UHF gain really only has 4 dB. Just trade-offs. I would not worry about 10 feet of RG-174 either, so it's just reality vs theory.
  4. Apr 10, 2020 at 4:34 PM
    #7084
    Atomic
    Atomic Master Cylinder
    New Mexico
    13 TRD Sport Double Cab Long Bed
    Realized it was was too fat of a cable...Just ordered a J-pole from Arrow antenna; More like going with RG-8x and I need 100 ft not 10ft...that was a typo.
    Thanks everybody.
    DaveInDenver and m603holden like this.
  5. Apr 10, 2020 at 5:08 PM
    #7085
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Way more flexible. I really like the stuff I listed. Flexible. Decent numbers. Affordable.
    DaveInDenver and Atomic[QUOTED] like this.
  6. Apr 10, 2020 at 5:19 PM
    #7086
    m603holden
    Marteeen
    New England
  7. Apr 10, 2020 at 5:20 PM
    #7087
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    what band?
    Chipskip and BenMara like this.
  8. Apr 10, 2020 at 5:50 PM
    #7088
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    RG-8X is more durable, a higher quality coax.
  9. Apr 10, 2020 at 6:30 PM
    #7089
    m603holden
    Marteeen
    New England
    Maybe a 40m net in the evening?
    DaveInDenver and BenMara like this.
  10. Apr 10, 2020 at 6:32 PM
    #7090
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    That might work. I’ve been on a local 17M net at 7 each night.
    m603holden[QUOTED] likes this.
  11. Apr 10, 2020 at 6:35 PM
    #7091
    m603holden
    Marteeen
    New England
    Did you see that AU and NZ was getting into the east coast tonight? 17 and 20. I had about 30 seconds of full copy at greyline. Then poof. Gone.
    BenMara likes this.
  12. Apr 10, 2020 at 6:39 PM
    #7092
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Greyline is best time to get into Asia Islands... Aarg... want my HF antennas up so bad... Have my V/Uhf assembled, just needs coax. Need a calm wind day to put Dipole in air then ill have some HF fun. Hex would be next to assemble, Vert 40m antenna is another story...
  13. Apr 10, 2020 at 6:41 PM
    #7093
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    We’ve had quite a bit come in. Argentina, Brazil, etc... My G5RV is laid out E-W so they tend to come in pretty clear for me when conditions are good. We’ve also been on 80 and have covered NH to PA on, what I believe is, ground wave.
  14. Apr 10, 2020 at 6:44 PM
    #7094
    m603holden
    Marteeen
    New England
    Should check in on the 80m net on Sundays!
  15. Apr 10, 2020 at 6:45 PM
    #7095
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    time and Fn?
  16. Apr 10, 2020 at 6:59 PM
    #7096
    m603holden
    Marteeen
    New England
    If you have netlogger it's under Dave's dork den. 8am. No set freq. We hunt for what's available in the general portion
    vssman[QUOTED] likes this.
  17. Apr 11, 2020 at 7:22 AM
    #7097
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    If you are EXTRA special, we start at 3.650MHz then move to a more General area.
    nats, vssman[QUOTED] and BenMara like this.
  18. Apr 11, 2020 at 2:17 PM
    #7098
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    More likely it is NVIS
  19. Apr 14, 2020 at 1:04 PM
    #7099
    NotRed
    NotRed Well-Known Member
    Best to use quality compression connectors if you are not already for LMR400
    http://www.rfcoaxconnectors.com/product-family-COMP-Pro.php
    Old Marine Cal likes this.
  20. Apr 14, 2020 at 5:09 PM
    #7100
    m603holden
    Marteeen
    New England
    Well. Just worked Tokyo from NH.
    foy1der, DaveInDenver, k8md and 5 others like this.
