Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Jun 6, 2020 at 12:38 PM
    #7361
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Congratulations on passing the exam. In a couple of weeks you’ll have your call sign
  2. Jun 6, 2020 at 12:49 PM
    #7362
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Thanks! Should be posted Monday they said.
    Shout out to the ARC for giving online remote testing!
    m603holden and BenMara like this.
  3. Jun 6, 2020 at 8:41 PM
    #7363
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
    Flrig, fldigi, and JS8CALL installed. Can I get a scope sweep on fldigi?
  4. Jun 7, 2020 at 4:07 AM
    #7364
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Do you have a soundcard for your 891 yet?
  5. Jun 7, 2020 at 7:42 AM
    #7365
    joshuajayg
    Moab
    Yes, but I haven't built my data cable yet so it isn't connected to the radio.
    m603holden[QUOTED] likes this.
  6. Jun 7, 2020 at 7:44 AM
    #7366
    m603holden
    Marteeen
    New England
    What will you be using for a soundcard?
  7. Jun 7, 2020 at 8:15 AM
    #7367
    joshuajayg
    Moab
    Per the suggestion of KM4ACK, I have the Sabrent sound card. I have 3.5mm TRRS plugs and a 6-pin mini DIN cable I chopped up for my TM-V71A. All parts are on hand, I just need to assemble.
    I'm also thinking about my power source still I'm using a 100AH SLA battery right now since I already own it but considering a LiFePo battery or Li-Ion.
    m603holden likes this.
  8. Jun 7, 2020 at 8:31 AM
    #7368
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    I *think* this is the one I ordered. You'll need to double check the dimensions though:
    https://www.ebay.com/itm/CB-UHF-Bla...rand=Unbranded&_trksid=p2047675.c100008.m2219
  9. Jun 7, 2020 at 8:33 AM
    #7369
    m603holden
    Marteeen
    New England
    Nice. Was going to say if you didn't have the supplies there's this
  10. Jun 7, 2020 at 9:30 AM
    #7370
    m603holden
    Marteeen
    New England
    Sorry. Never answered this. When you connect the data cable the 3kw scope will appear
    Now if you want a panadapter you can get an rsp1a and put it in a switch to disconnect when you TX.
  11. Jun 7, 2020 at 10:27 AM
    #7371
    joshuajayg
    Moab
    Jibberish. Panadapter?
  12. Jun 7, 2020 at 11:05 AM
    #7372
    binge_stinker
    binge_stinker Well-Known Member
    2005 4X4 MT6 DCSB
    Power sliding rear cab window retrofit
    Looking to buy a setup capable of APRS. Is it worth getting the Kenwood 710G over the V71, is it that much more work to make the V71 APRS compatible? After doing so, is the price point comparable between the two anyhow? Do I need a tablet to view APRS data/send messages regardless of which radio I choose? I thought I'd read something about swapping the 710 face onto the V71, is that an economical solution? I am absolutely new to this but I know I want to have APRS functionality and transmit at the same time.
  13. Jun 7, 2020 at 11:07 AM
    #7373
    m603holden
    Marteeen
    New England
    Piece of cake. It's just time or money. Not much of either I might add
    binge_stinker[QUOTED] likes this.
  14. Jun 7, 2020 at 11:10 AM
    #7374
    m603holden
    Marteeen
    New England
    I'll see if I can't find the switch for you. My buddy Dave put one into his and it works great. Instead of hacking up the radio and soldering a tap, you can just get an rsp1a and have it switch. Pretty clean.
  15. Jun 7, 2020 at 11:13 AM
    #7375
    binge_stinker
    2005 4X4 MT6 DCSB
    I had just read this post, seems like you're a fan of the 71 over the 710? Tablet/phone is only necessary for either radio to view APRS data, correct?
  16. Jun 7, 2020 at 11:20 AM
    #7376
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Beat me to it! Over great distance doesn't much matter but local a 90* tilt would be an asset!
  17. Jun 7, 2020 at 11:26 AM
    #7377
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  18. Jun 7, 2020 at 11:30 AM
    #7378
    medic2230
    Murph
    Bama! Roll Tide
    Only need it if you want to see the APRS data on a map. You can send and receive APRS on the d710 and see location and direction on the d710 screen. Messages also come in on the screen.
    AF155D35-DDCF-4FF8-9524-A323B60D6CAC.jpg 7675A6F7-B865-45AD-9CCF-881DE2A2D3B4.jpg
  19. Jun 7, 2020 at 11:32 AM
    #7379
    m603holden
    Marteeen
    New England
    You'll need a device to generate the signal, it gets sent to a tnc device, then the device triggers the ptt and uses the radio to transmit its signal.
    I have nothing against the D710. I wish I had one. But I'd still have to add to it so I could use with with a screen, which is my preferred method.
    I couldn't care less about selecting a call sign and having my radio "automatically" switch the vfo to it.
    It's a feature I'd never use even if I had it. But the screen interface I use daily.
  20. Jun 7, 2020 at 11:33 AM
    #7380
    m603holden
    Marteeen
    New England
    The bottom section
