Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Feb 21, 2021 at 7:49 AM
    #8481
    tacocart762
    tacocart762 Well-Known Member
    desert55gr
    Santa Clarita Valley
    2017 Tacoma TRD Offroad Dbl Cab Long Box
    1.5in Bilstein 6112 Front,1in Alcan Leaf Rear with Bill 5100's. Battle Armor side step,bull bar, and rear step.
    Awesome radio stick with it!!
  2. Feb 21, 2021 at 7:52 AM
    #8482
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    I have been thinking about the same thing. I'm looking into the KG-UV9D instead. Easier to get and also full duplex.
    BaywatchDV[QUOTED] likes this.
  3. Feb 21, 2021 at 9:19 AM
    #8483
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Baofeng Magnetic Car Vehicle Mounted Antenna UHF VHF Dual Band for BAOFENG UV5R Plus UV5RA Plus UV3R Plus https://www.amazon.com/dp/B00W6TJOO...abc_6BXTC39YQ2AD9KJDBCNE?_encoding=UTF8&psc=1
    S&G think it’s worth it? I’m contemplating setting up this and a mic, stuffing everything in my center console. I really only use my radio(s) for road trips and off roading. I have a 3ft fire stick off tail light mount for CB which, if this road trip in March proves that to be worthless then I’m probably pitching the whole system. Just want something a little bit more intricate without going over the top for the baofeng/future actual gmrs radios.
  4. Feb 21, 2021 at 9:34 AM
    #8484
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Nagoya UT-72 mag mount with sma adapter works great. I still use it with my TM-V72A actually.
    GarlicFarts[QUOTED] likes this.
  5. Feb 21, 2021 at 12:23 PM
    #8485
    BaywatchDV
    BaywatchDV Well-Known Member
    2015 Tacoma TRD Sport
    I ended up ordering a UV9D after watching Ham Radio Concepts on YouTube successfully work several satellites with one. Can’t beat saving money and availability.
  6. Feb 21, 2021 at 12:50 PM
    #8486
    GarlicFarts
    Lil Rhody
    That costs more than my radio :rofl:
    I’m aiming for a bit more budget than that (I know). I was hoping to get the cheap antenna I linked and the baofeng mic. I need to get a usb charging connection. I was thinking about getting one of the radioditty gs5bs since it can be charged via usb and does all the baofeng stuff and then some. But I’ll probably just get one of those extendo batteries for the baofeng instead or something. I have one of the battery eliminators I might see if I can rewire that to usb instead and could just stuff that into the center console with everything.
  7. Feb 21, 2021 at 1:03 PM
    #8487
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    The battery life on my UV-82HP is absurdly good. Like you probably wouldn't even need to charge it if you were out for a few days. I keep a spare in my work bag with our freqs in it and I honestly cannot remember the last time I charged it. Probably not even in 2021 yet
  8. Feb 21, 2021 at 1:08 PM
    #8488
    GarlicFarts
    Lil Rhody
    yeah there’s an Amazon special combo pack - extra life battery, charging cables, chirp cable, and mic! Might grab that and the mag antenna.
    I had my UV5R plus (awwww yissss it’s red!) on a road trip through Vermont and around the middle of day 4 it started getting shy on battery, that was just the stock one.
    if I can get a way to charge up instead I’d prefer that instead of having something connected to the trucks power.
    Basically just being more intricate than I need to be. As said - the radio as is handles everything I need and then some. Just getting more toys.
  9. Feb 21, 2021 at 1:14 PM
    #8489
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Seems like a solid plan. A nice antenna system will allow you to do most of what a mobile system will do anyway, just in a different package [and with a lot less wattage, but still]
  10. Feb 21, 2021 at 1:20 PM
    #8490
    GarlicFarts
    Lil Rhody
    with my application being simplex off road, I’m good with the power of the HT.
  11. Feb 23, 2021 at 8:16 AM
    #8491
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    This weekend decided to improve my antenna. Originally had a 10ft pole at the peak. I added a 27ft telescoping pole in a 5ft tripod. The tip of my base antenna is 49ft above ground level and the feed point of the inverted dipole is at 39ft agl.
    This has greatly improved reception. Did some net check ins this morning, everyone said we were booming. We were able to confirm signal into the parts of Mexico my parents are normally around.
    3F177795-BF5C-4119-BB38-E475647F640A.jpg D4FA7D39-9C43-4E57-8ED5-529BD47C95FB.jpg
    On 40m contacts in Boise and La Paz just now. Woot!
    k8md, joshuajayg, golfindia and 2 others like this.
  12. Feb 23, 2021 at 8:53 AM
    #8492
    GarlicFarts
    Lil Rhody
    Have a mag mount antenna coming in for my baofeng for the truck, but when that's not in use I might try to set it up on my file cabinet in my office at home. Joined a radio club, I can get the repeater but it's meh. Hope setting it up on my file cabinet gets enough to be better. Don't want to go all out.
    PS if anyone wants a baofeng - this plus an external antenna (I have the $10 one I posted earlier coming in the mail soon, but there are better ones) and you've got a pretty good setup!
    https://www.amazon.com/Extended-Mir...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
    Gunshot-6A likes this.
  13. Feb 23, 2021 at 9:01 AM
    #8493
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    The NA771 18" or the 40" aubree makes a good handheld antenna for those as well.
  14. Feb 23, 2021 at 10:37 AM
    #8494
    GarlicFarts
    Lil Rhody
    :rofl: I know what you mean, but in my application at least, "handheld" would be "in the cab of the truck" I just pictured someone with a 40" antenna fumbling around inside the cab :D
    I think @BadDNA has an 18" antenna on his baofeng though, or at least not the stock rubber ducky.
  15. Feb 23, 2021 at 10:38 AM
    #8495
    Gunshot-6A
    Conner
    Everett, WA
    The 40" folds down to 18ish.
    Its enormous unfolded though
  16. Feb 23, 2021 at 10:40 AM
    #8496
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    I just had to drop $1K on an aviation headset for work. Is there any way I can use that thing for ham radio when I am not working?
    k8md likes this.
  17. Feb 23, 2021 at 10:42 AM
    #8497
    GarlicFarts
    Lil Rhody
    Yeah I have seen those. Pretty cool setup, especially if you're out hiking/riding or something. I'd say it's overkill for me but hell, even having a radio is overkill I guess so why not keep going :D
    They're pretty cheap if I remember correctly.
    This one here is 15 bucks, don't know about the quality of the build to be fair.
    I think my in-laws have the same tiles in their kitchen.
  18. Feb 23, 2021 at 10:59 AM
    #8498
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Yup. I've got the Nagoya that's down in the discussed products - 15.6"
  19. Feb 23, 2021 at 11:32 AM
    #8499
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    What kind of plug does it have? I use Disco 32's PTT's for my helmet comms.
  20. Feb 23, 2021 at 11:32 AM
    #8500
    Gunshot-6A
    Conner
    Everett, WA
    I use it for staffing offroad races. Folds down for sitting in the cab, but can still talk to race control 5-20 miles away while out in the boonies away from the truck.
