Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Dec 29, 2021 at 10:28 AM
    #8821
    2013TacoDCLB
    2013TacoDCLB Well-Known Member
    Mark
    2013DCLB4x4
    Military hitch, CB install, cargo rail brackets
    k8md likes this.
  2. Dec 29, 2021 at 10:34 AM
    #8822
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    You do need a license to legally transmit on GMRS, though technically not to just listen. There's no test involved, just go to the FCC Universal License System and fill it out: https://www.fcc.gov/wireless/suppor...rces/applying-new-license-universal-licensing
    NotRed likes this.
  3. Dec 29, 2021 at 11:51 AM
    #8823
    2013TacoDCLB
    Mark
    2013DCLB4x4
    How hard is the HAM test, how much is it? Is it worth the Hassle for a 5W mobile radio? Or GMRS
  4. Dec 29, 2021 at 11:58 AM
    #8824
    BadDNA
    Eammon
    Cabot, VT
    It gets pretty technical, so if you're not already familiar with electronics, components, schematics, and formulas, you'll definitely want to do some reading/learning before diving in. There are practice exams all over the place that would be good to help guide you.
    Here's one: https://hamexam.org/exam/16-General
  5. Dec 29, 2021 at 2:46 PM
    #8825
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    That’s a handheld VHF/UHF ham radio that also transmits on GRMS frequencies. A technician ham license gets you mainly VHF/UHF frequencies. Is it hard to pass the test? Not really. There are several free apps and websites that run through the material and then have the practice tests that are the actual test. For a tech license, memorize the answers. Also, there are better handhelds than the Baofeng brand. I started out with that handheld and liked the hobby enough to continue and upgrade to a General and then Amateur Extra license.
    BadDNA and -Rorschach- like this.
  6. Jan 2, 2022 at 9:47 PM
    #8826
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
  7. Jan 2, 2022 at 9:57 PM
    #8827
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    I have the ft7900r, just make sure it has the separation kit.
    The bank system is excellent, I have all the channels separated by region. If I'm in nor cal I turn the radio on and press 1 and I have all the repeaters for my area, so cal just press 2 and so on.
    This also makes it easy for people to use it in an emergency if I'm not around. Just turn it on and press one button and it's ready to go.
    I've found RT systems is the best software for this radio, I'm able to use chirp for my other radios and the special motorola CPS for my handhelds.
  8. Jan 2, 2022 at 10:00 PM
    #8828
    Old green toyota
    Sacramento,CA
    Oil leaks
    I just saw you are local, if you get the same radio I can help with programming. Just copy my file and tweak it a little. I also have an antenna tuner if you want to go all out.
  9. Jan 3, 2022 at 2:59 AM
    #8829
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    It's illegal to use that radio without a license. There are two ways to approach a ham radio license.
    1) If you want to learn electronics and adopt a new hobby, buy the ARRL manual and read it until you understand the concepts. Feel free to post questions if you need clarification. If you do well learning from YouTube, search for ke0og. Dave Cassler has some excellent videos for learning the material.
    2) if you just want a call sign so you can legally talk, use hamstudy.org to memorize the test. It's 35 questions from a pool that's published with answers. My wife is not technical at all. She started studying on a Sunday afternoon and passed on Tuesday. She doesn't know PL tone from FM deviation, but she has a call sign and understands basic operating protocols.
    I highly recommend you get licensed and please don't operate pirate. If you don't understand what you're doing, a 5w radio can definitely cause interference to police and fire and unintionally jam their repeaters.
  10. Jan 3, 2022 at 4:07 AM
    #8830
    k8md
    Bob
    I should add: If you opt for #2, make sure to seek out help getting started. If you're licensed, then many hams are happy to be very helpful.
    The boafengs are interesting animals. I believe they are terrible radios for beginners. As they lack some of the automated features of the regular ham radios. One item in particular is the repeater offset. When you set up the radio to work with repeaters, the radio is transmitting and receiving on two different frequencies. The difference between these two frequencies is called the repeater offset. In the 70cm band (44x.xxx) the repeater offsets are usually +5 MHz. So if you're listening to a repeater at 443.500, then you transmit on 448.500 to uplink to the repeater. Repeaters in the 2m band (14x.xxx) have a 0.6 MHz offset. So if you're listening to a repeater at 147.100, you transmit on 147.700 to get into the repeater. I have seen experienced hams mess this up using Baofengs. If you have the 5 MHz offset configured for 70cm and then switch to a 2m repeater, you need to re-configure the offset. A 5 MHz offset at 147.100 will put transmit at 152.100. Well outside the amateur allocation. This is possibly causing interference for public safety (police & fire). The federal government is also a big VHF user, so you can potentially be causing interference to FBI, ATF, Fish & Wildlife, National Park Service, etc, etc. This is not just limited to new users, it's as easy for an experienced ham as it is for someone new.
    The regular ham radios from Yaesu, Icom, and Kenwood come locked to the amateur allocation. While they don't prevent all mistakes, at least they will keep your mistakes inside the amateur frequency allocations. They also generally have automatic repeater shift. So the correct repeater shift is automatically applied when 2m or 70cm is chosen. I'm not trying to hate on Baofengs. I'm just explaining that they are more difficult to use and have a higher probability to making a mistake and transmitting out of band. I believe it's possible to use CHIRP to lock a baofeng to the amateur frequency allocation. Many new models are arriving that way. Which I think it's a good thing.
  11. Jan 3, 2022 at 4:15 AM
    #8831
    2013TacoDCLB
    Mark
    2013DCLB4x4
    One of the goals this year is to get licensed either GMRS or Technical HAM license. I have no illusions that the Baofeng radio I have is complicated but learning how to use this radio legally will be one of the goals for 2022. Once, licensed then I can get a better radio for the truck.
    k8md and BEAR_KNIFE_FIGHT like this.
  12. Jan 3, 2022 at 6:37 AM
    #8832
    trucknh
    trucknh Well-Known Member
    Southern NH
    Yes. Download the hamstudy app, there's a explanation for every question. Take practice tests and review. Understand or memorize questions until you are passing. I paid the 3.99 so I could pick up on where I left off on my laptop and phone, was worth it.
    Buy an old ARRL handbook used, the physics of radio propagation and antennas doesn't change.
  13. Jan 3, 2022 at 8:21 AM
    #8833
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    And if you're only planning on using a laptop/desktop, you can create an account for free. If you want the app, it will cost $3.99.
  14. Jan 3, 2022 at 9:11 AM
    #8834
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  15. Jan 3, 2022 at 9:44 AM
    #8835
    trucknh
    Southern NH
    Yes I should have been clear it is free and will only cost 3.99 if you want to track progress between devices.
  16. Jan 3, 2022 at 9:50 AM
    #8836
    BillW
    N. Phoenix
    2018 DCSB TRD OR MT
    No worries, and I didn't intend to nitpick.
  17. Jan 3, 2022 at 10:09 AM
    #8837
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Hate to say this but that sounds like a CB operator, the ones that you may want to talk to went to the effort to learn it.
    BenMara likes this.
  18. Jan 4, 2022 at 6:03 AM
    #8838
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Once you do get it the technician Squawk is the same garbage(at least in my area) but more "sophisticated". Best study to upgrade your license to HF, Apparently that's where the real Hams are.
    golfindia likes this.
  19. Jan 4, 2022 at 6:10 AM
    #8839
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    LOL.
    And everyone has at least one CW Sweepstakes plaque.
  20. Jan 5, 2022 at 10:49 AM
    #8840
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Got to admit I have heard more trash on HF! There was a group on 80 meters (NE area) that were politically extreme and I think the FCC pulled a few licenses lot quieter now. If you really have a serious interest find a local repeater listen, and see what it's all about most active clubs do classes, licensing etc. The club repeater has to have a call sign look it up and see if they have a web site. My license is up for renewal this year so that will make it 30 years on the air.
    Hawk373 likes this.
