Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Apr 16, 2022 at 4:54 AM
    #9021
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Neeeeeeerd
    Gunshot-6A likes this.
  2. Apr 16, 2022 at 1:15 PM
    #9022
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Nice! You're somewhat local. I'm normally on the Phantom net repeaters
  3. Apr 16, 2022 at 1:17 PM
    #9023
    m603holden
    Marteeen
    New England
    It all started with those RTTY troublemakers :D
    taco-99 likes this.
  4. Apr 16, 2022 at 4:57 PM
    #9024
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
    No-code Extras are ruining ham radio!
    Solid state is ruining ham radio!
    VARA is ruining ham radio!
    FT8 is ruining ham radio!
    DMR is ruining ham radio!
    SDRs are ruining ham radio!
    The next one will be...
    Your cat is ruining ham radio!
  5. Apr 17, 2022 at 7:38 AM
    #9025
    Atomic
    Atomic Master Cylinder
    New Mexico
    13 TRD Sport Double Cab Long Bed
    I am gonna get my GMRS license too...especially at $35.
    Question: Do any of you know of a good dual band VHF/UHF mobile antenna that would cover both amateur and gmrs uhf? Thanks.
  6. Apr 17, 2022 at 5:59 PM
    #9026
    m603holden
    Marteeen
    New England
    None will really advertise it. A gmrs radio has no use for a vhf tuned antenna, and a ham radio isn't supposed to be used on gmrs frequencies, so mfgs won't advertise the range to be usable down there.
    So unfortunately you'd probably just have to get one and see what the swr is if you end up using it in that fashion.
    Gunshot-6A and GarlicFarts like this.
  7. Apr 17, 2022 at 8:27 PM
    #9027
    Atomic
    New Mexico
    Ok, understood and thanks. I suppose if I stick with my UHF-only rig, how about a follow up question: Is there a UHF antenna that would work across UHF amateur and into gmrs band?
  8. Apr 17, 2022 at 8:32 PM
    #9028
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Negative 70cm is 440mhz. GRMS 462 MHz and 467 MHz
  9. Apr 17, 2022 at 8:39 PM
    #9029
    Atomic
    New Mexico
    SigBoy likes this.
  10. Apr 18, 2022 at 5:08 AM
    #9030
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Dont believe the hype. Antennas can be easily changed out, not radios. Wrong radio TX on wrong antenna, burnt radio. But if you do i suggest you get a SWR meter it wont lie too bad. I haven't been an amateur long, but I've sent smoke through enough radios...
    Atomic likes this.
  11. Apr 18, 2022 at 5:11 AM
    #9031
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Atomic and maineah like this.
  12. Apr 18, 2022 at 6:56 AM
    #9032
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ya know an SWR at 1.5 to 1 is 97% efficient. With a hand held radio I can use a repeater 29 air miles away but barely use it on a repeater 14 miles away one is at 6,000 feet the other 1,200 I'm about 500'. There are lots of variables. Yes you can make a broad band antenna but don't expect miracles it is a compromise.
    GarlicFarts and Atomic like this.
  13. Apr 18, 2022 at 7:24 PM
    #9033
    Atomic
    New Mexico
    I agree with you all, it's a compromise. I do have an SWR meter. I will post up my results with the Powerwerx antenna at various frequencies across the stated band range of the antenna...I first got to get my gmrs license, so it'll be a little while. Thanks for the advice.
  14. Apr 19, 2022 at 5:20 AM
    #9034
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    To some extent that antenna is tunable. My point being if you can get each band within a useable range (less than 2:1) you are fine. By doing so you will end up with an OK SWR not top notch but useable. People tend to go over board on a "perfect" SWR like I said before 1.5 SWR is still 97% efficient. If you use an analyzer instead of an inline SWR meter the RF will be all most nil.
    Atomic[QUOTED] likes this.
  15. Apr 23, 2022 at 5:31 PM
    #9035
    joshuajayg
    Moab
    Hearing two stations on 10m right now from Australia. Band is doing well.
  16. Apr 23, 2022 at 5:53 PM
    #9036
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    did you get your 599?
  17. Apr 23, 2022 at 6:05 PM
    #9037
    joshuajayg
    Moab
    No, I need to get my beam up. 1000w into rg58 and a vertical is making too much heat and not enough rf.
    Taco 422 and BenMara[QUOTED] like this.
  18. Apr 23, 2022 at 6:06 PM
    #9038
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    If you were closer id give you a Maco v58
  19. Apr 23, 2022 at 6:11 PM
    #9039
    joshuajayg
    Moab
    I have an A3S laying on the ground with a tower but I haven't dug the hole and poured the concrete to make it erect yet.
    k8md and BenMara[QUOTED] like this.
  20. Apr 24, 2022 at 4:53 AM
    #9040
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well even if it's a 75% loss you should still have 250 watts out!
