Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Jan 22, 2023 at 3:55 PM
    #9101
    badweatherbiker
    badweatherbiker Well-Known Member
    North Florida
    2011 blue Tacoma crew cab 4.0 TRD off road
    Guess the radio is too big, Alinco DX70th.
    If I push it in from the rear of the front seat it will go a few inches before it hits the frame but that's it, no room for a bracket.
    I might could get it under the rear seat but it's closed in with no ventilation and my power cable is too short.
  2. Jan 23, 2023 at 5:32 AM
    #9102
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Where there is a will there is away. Mine is under the passengers seat. Assuming yours's is a 4 door there still should be room there under the seat how tall is this thing? According to what I read it's only 2 1/4 inch's high. There is a frame member that it will have to fit behind sideways because of it's depth you may have to lift/remove the seat but there should be plenty room I don't believe there is a vent on the bottom so there is no reason it can't just sit on the floor. Mine has stayed put with no mount for the last 160K miles. Your wiring should be enough to go under the center consoled.
  3. Jan 28, 2023 at 9:52 AM
    #9103
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    Good morning, just started studying for technician's license so all of this is new to me. Just listening and learning and doing research. Has anyone read this before?
    The installation of a mobile two-way radio system in your vehicle could affect electronic systems such as: ● Multiport fuel injection system/sequential multiport fuel injection system
    ● Cruise control system
    ● Anti-lock brake system
    ● SRS airbag system
    ● Seat belt pretensioner system
    Be sure to check with your Toyota dealer for precautionary measures or special instructions regarding installation of a mobile two-way radio system.
    Is it safe to say this is lawyer speak and a far reach or is there some legitimacy to the above statement?
  4. Jan 28, 2023 at 10:53 AM
    #9104
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I haven’t had any issues on my ‘13 even when pushing 50W through my VHF. A quality radio with proper installation reduces the chance of interference significantly.
    jerrybear[QUOTED] likes this.
  5. Jan 28, 2023 at 11:16 AM
    #9105
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Ive pushed 75w VHF and no ill effects.
    jerrybear likes this.
  6. Jan 28, 2023 at 11:22 AM
    #9106
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    That is why you need a quality proper tuned and installed antenna and coax. My 3 radios cover from 10 to 220 to 440 no issues with truck electronics even at 100 watts.
  7. Jan 28, 2023 at 12:30 PM
    #9107
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Lawyer language. Having your cell phone next to your nuts is 1000x worse. Most radios' spurrious emissions is pretty good, they have to pass to get type accepted. Some of the chinese ones are dirty splatter boxes.... RFI in 3rd gen tacomas is horrible anyway.
    Taco 422 and jerrybear[QUOTED] like this.
  8. Jan 28, 2023 at 12:47 PM
    #9108
    jerrybear
    17 off-road
    right on. thank you evryone.
  9. Jan 28, 2023 at 2:21 PM
    #9109
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Radios are fine they are well regulated for the most part. High SWR antennas, poor coax installs, poor grounding things like that cause issues with vehicle electronics. The vehicle stuff is pretty hardened because of electronics in general, cell phone are no exceptions just another part of vehicle electronics.
    Taco 422 likes this.
  10. Feb 1, 2023 at 8:38 PM
    #9110
    badweatherbiker
    North Florida
    No go on the passengers side as well
  11. Feb 2, 2023 at 6:38 PM
    #9111
    NotRed
    NotRed Well-Known Member
    On my Access Cab I took the passenger seat out (only 4 bolts) and then installed the RT to the bottom of the seat springs with spacers between it and the springs. That way I could get it in there without the bar and mounting brackets being in the way yet still allowed airflow all around the unit.
  12. Feb 2, 2023 at 8:33 PM
    #9112
    badweatherbiker
    North Florida
    I will prob try this next in a few weeks when things slow down, thanks!
  13. Feb 16, 2023 at 6:47 PM
    #9113
    golfindia
    Yes.
    pickup truck
  14. Feb 16, 2023 at 9:42 PM
    #9114
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
  15. Feb 17, 2023 at 11:56 AM
    #9115
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Lawyer speak - ISH
    First - Tacoma isn't a hybrid or electric vehicle. In those cases, I have heard (mumblings, high level) problems with radios interfering, either with static or whatnot. Your completely ICE tacoma will be a okay. That said, if it DOES cause any sort of issues, that's on you, not on Toyota.
    Second - They (radios) actually DO have issues running through switch panels. Auxbeam et. al. I think it voids warranties/they won't care about a failure if you call them and say it was a radio. So, you'll need to go direct to battery (it's the best way for a vehicle mount anyway).
    Edit to add more: That list sounds a LOT like things Toyota has seen before. I can think of (1) cutting wires or using an add-a-fuse for power may have interfered with ABS, SOS, etc and someone tried to say it was Toyota's problem (2) stuffing/running a wire over an airbag or mounting a speaker near an airbag and then getting clocked with it when it goes off. That seems like lawyer speak for "If you do something stupid with a radio, that's on you"
  16. Feb 17, 2023 at 5:14 PM
    #9116
    jerrybear
    17 off-road
    figured. no aux switches or panels here. def direct to battery. thank you.
  17. Feb 18, 2023 at 3:46 PM
    #9117
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    A panel's not the end of the world. There was more issue back when we were running strobes in everything (hideaways and lightheads, not the Edge 9000 bars as much) but having an aux panel from the battery to the cab or box for comm stuff isn't generally a problem.
    As mentioned, the tap-a-fuse mentality is where you run into issues with the OEM stuff.
  18. Feb 18, 2023 at 3:49 PM
    #9118
    Taco 422
    USA
    I run high power mobiles, 100-110w. The taco has a VHF 110w with a shitty antenna position currently, and the only issues been with the aftermarket stereo loosing the wired connection to the phone at a few frequencies. I'll roof mount the antenna when I get the measurements figured out and know where to center the darn thing - and presume there won't be many issues from that point on.
  19. Feb 18, 2023 at 5:03 PM
    #9119
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
  20. Feb 18, 2023 at 5:16 PM
    #9120
    golfindia
    Yes.
    pickup truck
    BenMara[QUOTED] likes this.
