Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Mar 6, 2013 at 7:09 AM
    #81
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
  2. Mar 6, 2013 at 7:24 AM
    #82
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Oh then you need a radio like proforce in order to reach the 880mhz band. I believe yours is only 2m and the mars cap mod should only let you TX on all the MHz your radio picks up and maybe expand the freq range a little bit.
  3. Mar 6, 2013 at 7:37 AM
    #83
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Most bigger metro PD/SO departments use a trunking system that uses 3 revolving frequencies in order to avoid scanner listening. However there are Trunking scanners available, but your standard 2 meter radio should be able to listen to fire, some air traffic control and rural SO. and yes race radio frequencies.
  4. Mar 6, 2013 at 9:52 AM
    #84
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Also how is range on a radio figured? Power output x antenna?
  5. Mar 6, 2013 at 9:57 AM
    #85
    SoCaltaco65
    Its Frequency dependent, however Antenna location, along with tunable wavelength and output power all play a part. The higher in Frequency above 29MHz the more Line of Sight issues play into it.
  6. Mar 6, 2013 at 9:59 AM
    #86
    tostidos
    Apple Valley, CA
    07 LT 6spd
    gotcha, any suggestions on a solid home unit? would be nice to stay in contact if our communications system we are taking for granted ever goes down.
  7. Mar 6, 2013 at 10:00 AM
    #87
    The Traveler
    The Traveler [OP] Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    On 2 meters, with an 8 foot whip antenna on the bedrail, I'm getting about 40 miles simplex. Assuming of course, no mountains or Disneyland in the way. LOL
  8. Mar 6, 2013 at 10:04 AM
    #88
    SoCaltaco65
    Well there a ton of things you can put up at the home, the biggest thing is what can you erect for a Antenna and tower/push up pole? Short of having a tower like I have a 30 foot push up mast wire supported with a good VHF/UHF antenna.
    Radio wise its up to you, ebay and QRZ generally will have some good deals on used gear.
    #88
  9. Mar 6, 2013 at 10:09 AM
    #89
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Thats pretty good! Would it be safe to say a 6 meter could get 120 miles?
  10. Mar 6, 2013 at 10:14 AM
    #90
    The Traveler
    SoCal
    2 meter is the band which I transmit/receive on. Never used the 6 meter band.
  11. Mar 6, 2013 at 10:17 AM
    #91
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Im so confused haha, im just going to have to go into HRO when i get home and talk to the guys there. this ICOM IC-7000 looks awesome but i have no clue why its so expensive. (relatively i guess not bad) some are close to $7000!
    http://www.hamradio.com/detail.cfm?pid=H0-008093
  12. Mar 6, 2013 at 10:20 AM
    #92
    SoCaltaco65
    6 meters is awesome, I love using the band in the des, however around town the interference from other devices is nasty at times. I have talked with friends in Az( yuma) Simplex from El Centro and going up the grade ( hwy-8).
    Keep in mind that Atmospherics can play a part in distance too.
  13. Mar 6, 2013 at 10:22 AM
    #93
    tostidos
    Apple Valley, CA
    07 LT 6spd
    im just trying to get a general idea vs my icom that maybe goes 10 miles max. this icom ic-7000 has 6 meter and 2 meter as well.
  14. Mar 6, 2013 at 10:22 AM
    #94
    SoCaltaco65
    yes and more I just got my IC-7800 for home, the 7000 is a good receiver, but again, the tx side is picky about voltage its fed with and is one of the reasons I went back to the 706mkiig until the 7100 is fully released.
    and 440
    http://www.icomamerica.com/en/products/amateur/hf/7000/default.aspx
  15. Mar 6, 2013 at 10:24 AM
    #95
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    With my 65watt 2m radio and my 19" antenna via repeater I can talk to peeps in Johnson Valley from the city of Monrovia...thats about 125 mile distance :cookiemonster:
    Throwing around an idea of getting a mobile amp to boost power to 200watts off of 25watts from the radio. Don't know if I really need an amp yet..
  16. Mar 6, 2013 at 10:26 AM
    #96
    SoCaltaco65
    LOL, likewise via the cal-zona link you can talk into 3x states.
  17. Mar 6, 2013 at 10:28 AM
    #97
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    I would cover up my nuts everytime I transmitted with that setup! :D
  18. Mar 6, 2013 at 10:34 AM
    #98
    The Traveler
    SoCal
    Yeah I was reaching some guy mobile to mobile using the Catalina repeater from Irvine to Barstow. Pretty sweet range on that repeater. Anywhere from Santa Barbara to San Diego. And that was on 5 watts with the 8 foot antenna.
    I wouldn't think you need an amp. Repeaters do fine around here, and there's PLENTY of them. Out in the dez, I get about 45 miles simplex on 2 meter.
  19. Mar 6, 2013 at 11:15 AM
    #99
    MonkeyProof
    SoCal- SGV
    Meh..real world simplex distance is vastly variable to terrain and conditions while out in the desert...most of the time it kicks ass but it can be limited to just a few miles
  20. Mar 6, 2013 at 1:32 PM
    #100
    tostidos
    Apple Valley, CA
    07 LT 6spd
