Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Oct 27, 2014 at 2:24 PM
    #1001
    cyakker
    cyakker Well-Known Member
    SD (at least we're not Mars)
    2015 AC, TRD-OR, V6
    Usually about 6-8 business days. The big variable is when your VE sends stuff to the ARRL. Once the ARRL receives, it's usually the next day.
  2. Oct 27, 2014 at 2:43 PM
    #1002
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Congrats!
    Yes. More details somewhere in this thread, but in short, the antenna is mounted to a 1/2" bolt hole on a BajaRack roof rack.
    Two or three years now. I love it. A.R.E. MX. Holding up terrific. I load it up 150 lbs on roof, and it does really well, on and off road.
  3. Oct 27, 2014 at 5:22 PM
    #1003
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    Thanks Crom!
    I might have to install a Yakima Cargo Rack to come close to your setup...All I need is the rack...
  4. Oct 27, 2014 at 5:30 PM
    #1004
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Thanks! Should be any day now I guess.
  5. Oct 28, 2014 at 5:33 AM
    #1005
    ckeene9
    Chesterfield, VA
    See Build Thread
    Sweet, I have it. Been active since 24 OCT just never showed up on the FCC site through a name search but found it through ARRL and then searched FCC with my call sign.
    KM4FFU
  6. Oct 28, 2014 at 6:05 AM
    #1006
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    Ground Plane is not a myth... I have seen it!
    ...It's the other side of your dipole you're constructing
    When I was screwdrivering, I had a 102" whip I threw on there when stationary, really did a great job on 80. Had a couple clip on wires about 30' long to do 160. Kinda made a sideways half-square.
  7. Oct 28, 2014 at 6:34 AM
    #1007
    cyakker
    2015 AC, TRD-OR, V6
    Kudos man. Hmmm... I seem to remember needing to use a date frame with either name/FRN in the absence of callsign when searching ULS -- and just name not working. Maybe, or something. Something to keep in mind when you go for your General. ;)
  8. Oct 28, 2014 at 7:33 AM
    #1008
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    kk6pov, just popped my repeater cherry this morning on the way to work
  9. Oct 28, 2014 at 8:23 AM
    #1009
    Crom
    Nick
    San Diego, CA
    Millions
    You're welcome. Have fun with it. :)
    I think Tim was being a little facetious. I got a chuckle out of what he wrote. :D
    Congrats Travis. :) What radio you running? Which repeater you key up on?
  10. Oct 28, 2014 at 5:42 PM
    #1010
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    Howdy Y'all from just outside Austin, Texas.
    de W9ZEB
  11. Oct 29, 2014 at 5:43 AM
    #1011
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    A vehicle is more of a capacitor than a ground plane the ground losses due to the vehicle height are high on any of the HF bands. A portion of the return path flows through a very lossey ground under the vehicle making things even worse. The bottom line even at a 100 watts an HF rig in a vehicle has an ERP of a QRP rig with a ¼ wave dipole. The only way around this would be an elevated antenna and radials not real practical for mobile use. Many screw driver antenna whips are cut for use on 6-80 meters so by increasing the length you stand a pretty good risk of losing your higher frequency bands such as 6 and 10 meters. In my case I don’t care because I don’t usually use those bands my whip is 56” it is over twice the length of the stock supplied whip. A vertical multi band trap antenna will not work worth a hoot at ground level even with counter poise radials it needs to be razed above the lossey ground the same holds true for low frequency wire dipoles they need to be above the lossey ground by a ¼ wave or better.
  12. Oct 29, 2014 at 7:04 AM
    #1012
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
  13. Oct 29, 2014 at 10:08 AM
    #1013
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  14. Oct 29, 2014 at 5:11 PM
    #1014
    travis.diller
    Travis
    Kitsap Peninsula
    I Got all kinds yesterday between work and the gym I sat out on ballast point with a just a handheld. I hit monument peak KA6DAC as well as the w6ss which is in el cajon. I'm hooked! looking for a mobile unit, probably going to end up with the Yaesu ft7900r
  15. Oct 30, 2014 at 9:17 AM
    #1015
    Crom
    Nick
    San Diego, CA
    Millions
    Cool, have fun with it! The Lyon's peak repeater is a busy one. Good community usage. The .240 ECRA machine is linked. You can talk into and all over Western Arizona with it. Excellent coverage. I monitor those and many more.
  16. Oct 30, 2014 at 9:34 AM
    #1016
    Crom
    Nick
    San Diego, CA
    Millions
    I got out this last weekend in the high-desert of So Cal and hiked up to a government repeater site at about 4,600'.
    Wide area repeater site for the County of Riverside, appears to be a microwave link to Chuckwalla mountain radio site 39 miles away. Very unusual to have a large tower with only two antennas, probably a symbol that it's government and not a commercial site.
    Right next door was this FAA facility
    Antennas on this tower were tuned to the following frequencies:
    • 128.15
    • 285.6
    • 133.2
    • 282.3
    • 121.5
    • 243.0
    I also found some seismic monitoring equipment part of the Earth Scope project.
    From this location, I could use my HT to access amateur repeater sites 40 miles away high above palm springs.
  17. Oct 31, 2014 at 7:50 AM
    #1017
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  18. Oct 31, 2014 at 8:31 AM
    #1018
    Crom
    Nick
    San Diego, CA
    Millions
    Holy sh** you're not kidding! Just read the link. Elevation + bad weather = very hostile conditions.
    The building, and antennas encased in ice!
  19. Oct 31, 2014 at 4:33 PM
    #1019
    ckeene9
    Chesterfield, VA
    See Build Thread
    Recommendations for a 2M base station antenna that I can mount on the garage roof?
  20. Oct 31, 2014 at 6:36 PM
    #1020
    Crom
    Nick
    San Diego, CA
    Millions
    A zillion options to choose from. Aesthetics was a big factor for me. I settled on NMO mobile antenna with base station adapter. Almost invisible.
    I hit everything with 4 watts in a 40 mile radius at my QTH.
