Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Mar 5, 2016 at 8:04 PM
    #1821
    mtnceej
    mtnceej Well-Known Member
    Gary
    Crestline, CA
    2015 SW DCSB TRD OR 4X4
    ICON Stage II TC UCAs Demello Bumper TRD Cat Back Exhaust
    Hi all, just got my license a week and a half ago... KM6AQE
    EDIT: I am about to install a TM-D710GA in my rig with a diamond dual band antenna.
    Crom, Chipskip and G.T. like this.
  2. Mar 5, 2016 at 8:30 PM
    #1822
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    www.k0bg.com is a great starting point. i posted how i have my V/Uhf mounted in this thread
    PeterVICEG[QUOTED] likes this.
  3. Mar 5, 2016 at 8:38 PM
    #1823
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
  4. Mar 5, 2016 at 8:57 PM
    #1824
    PeterVICEG
    PeterVICEG Well-Known Member
    What Icom is that?
  5. Mar 5, 2016 at 11:18 PM
    #1825
    TYetti
    Mat
    F121 which I found out is still tuned to the local sherrif.... getting it reprogrammed next week lol
  6. Mar 6, 2016 at 1:19 PM
    #1826
    SteelCityPA
    SteelCityPA Member
    2013 Tacoma Sport TRD Double Cab
    I think if I do anything, I'll get a detachable front plate and hide the unit under the seat. Since I'm mostly an HF guy and not much into VHF I'm not in a big hurry. Antenna is my biggest concern if I do decide to put in a VHF/UHF antenna on it.
  7. Mar 6, 2016 at 2:08 PM
    #1827
    mtnceej
    Gary
    Crestline, CA
    I'm installing my Kenwood TM-D710G w/ a detachable plate in my 2015 Tacoma. For now I'm mounting the radio under the passenger-side seat and the face plate will end up where the forward sunglass holder is. I just got the power run from the battery and have a Diamond antenna that is mounted on my Yakima roof rack. I'll post some pictures once I get the faceplate mounted.
  8. Mar 6, 2016 at 2:56 PM
    #1828
    SteelCityPA
    SteelCityPA Member
    Good, I'd like to see the finished result. Sounds sort of what I envisioned I'd do actually. I don't have a roof rack though.
  9. Mar 6, 2016 at 5:21 PM
    #1829
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    First contacts with new Hexbeam
    Crom and G.T. like this.
  10. Mar 6, 2016 at 5:57 PM
    #1830
    SteelCityPA
    SteelCityPA Member
    That's awesome! Looks like you did some contesting with it. I didn't bother this year. I'm more of a CW and RTTY contester. SSB makes my ears bleed :)
    What were you running for power? It looks like 20 meters was a hot band this weekend. I did spin the dial earlier today and 10 meters seemed open for a little bit this afternoon.
  11. Mar 6, 2016 at 7:30 PM
    #1831
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    100w not turning in QSOs its just me testing antenna
  12. Mar 6, 2016 at 8:19 PM
    #1832
    PeterVICEG
    I did not realize that the faceplate coul be so separate from th radio. Do try to take some pics of how you route the wire for this.
    Thanks!
  13. Mar 7, 2016 at 9:13 AM
    #1833
    JDinSLT
    JDinSLT Member
    Tahoe
    2015 Black DCLB S/C
    pelfreybilt aluminum bumper with center hoops icon suspension kenwood tm-v71a ham radio baja designs s8 20" amber bar baja designs squadron sport fog amber
    Okay I think I've scanned the threads enough to ask this question, installed a Kenwood TM-281. Antenna has not arrived yet, but that is my connundrum, how do you get the antenna feed from outside in? Since it's going to be a permanent mount curious what method works for getting the antenna run into the cab from outside? Also for 2m, which mounts do most people prefer if running a shell? I've seen front hood/quarter panels, and rear bumper. This is going to be a permanent installation.
    73 from N6JFD
  14. Mar 7, 2016 at 10:32 AM
    #1834
    jim532
    jim532 .
    SoCal - 818
    2014 Prerunner V6 double cab
    If you're mounting the antenna on the hood there is a boot on the drivers side you can poke it through.
    There is also a plug I brought mine in through between the bed and the cab on the drivers side.
  15. Mar 7, 2016 at 10:57 AM
    #1835
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    There are rubber grommets under the cab in several places, I used one that is under the back seat, just poked an awl through it and fed the cable through, then a little dab of silicone. As far as antenna options, there will probably be several preferences, just do a little research on what guys have done on here, then go with what seems like a good fit for you. I have a lip mount on my hood with a uhf connector, I can run a decent antenna around town, but when I go in the woods I switch it to a small rubber antenna.
    PeterVICEG likes this.
  16. Mar 8, 2016 at 3:43 PM
    #1836
    Toyota Kawasaki
    Toyota Kawasaki Seasons Beatings
    2016 TRD OR
    Greetings, first time posting in this thread. I've been licensed for 14 years and prefer HF (40m) but also use vhf/uhf.. I finally got my Icom 2730a installed.. I am using an old Larsen NMO 150 until a new NMO 2/70 gets here from HRO, along with the programming software/cable.. Now to figure out where to install the Icom IC 7000. I will probably use another Lido mount like I did with the 2/440 head unit. As far as an HF antenna goes, I am still undecided.. I will just use ham sticks to get on the air for now and decide which screwdriver I want down the road..
    I am looking into the Hi-Q, Tarheel, Scorpion, etc. for screwdriver antenna's. Opinions & suggestions would be appreciated. 73, J.
    Has anyone used this mount? If it replaces the factory gps/sat antenna on the roof, I may try it..
    http://www.wpsantennas.com/NMOHFGPSSMASMA-Larsen-GPS-Antenna-NMO-Mount.aspx
  17. Mar 8, 2016 at 7:29 PM
    #1837
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Interesting mount... $123 naa id just drill a hold in roof like i did. I did use the Sat radio antenna hole at one time. Now it leaks even after replacing with sat antenna, never sat completely flush ever again... Think im just gona remove the Sat antenna and cover with clear bra material..
  18. Mar 8, 2016 at 8:25 PM
    #1838
    Toyota Kawasaki
    2016 TRD OR
    Yep, if I didn't have a sunroof, I'd just drill a hole like all my other trucks:)
    Chipskip likes this.
  19. Mar 8, 2016 at 8:48 PM
    #1839
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    My research has me leaning to a Scorpion antenna, when I can find the money. The performance is top notch and they look better than the others, IMO.
  20. Mar 9, 2016 at 7:39 AM
    #1840
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    The only other antenna I'd highly recommend you look at is the Hi-Q. rather than tapping the outside of the coil, by moving the coil up and down inside a tube with "wipers" The Hi-Q has a roller tap inside the coil that rolls up and down. Mechanically this is superior. The Hi-Q is a top notch mobile HF antenna.
    Chipskip[QUOTED] likes this.
