Amateur (Ham) Radio BS and Callsign Thread!
Discussion in 'Sports, Hobbies & Interests' started by The Traveler, Jan 29, 2013.
  1. Apr 19, 2016 at 10:43 AM
    #1921
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Detachable face and student budget are usually mutually exclusive. :D
    When you speak of aviation band, are you referring to 108 - 137 MHz?
    ebbs15 likes this.
  2. Apr 19, 2016 at 10:45 AM
    #1922
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Yikes, not what I wanted to hear :eek: 118-137 MHz is aviation frequency range
  3. Apr 19, 2016 at 10:50 AM
    #1923
    Crom
    Nick
    San Diego, CA
    Millions
    Most modified ham gear probably will not work for you, unless maybe if you modify an all mode transceiver, like the shack-in-the-box like the Yaesu 857D.
    The reason is that the Airband uses amplitude modulation for voice communications. Most of the transmitters in VHF Ham rigs use FM mode.
  4. Apr 19, 2016 at 10:52 AM
    #1924
    MatthewMay1
    Matthew
    Lone Star Republic
    I see....Sounds like I would be able to only listen then.
  5. Apr 19, 2016 at 10:54 AM
    #1925
    Crom
    Nick
    San Diego, CA
    Millions
    Yup. I have a Kenwood TM-V71A and I can listen to them. My rig has wide reception: 118-524MHz, 800-1300MHz*
    Sometimes its fun to scan around and see what's on the air.
  6. Apr 19, 2016 at 10:56 AM
    #1926
    MatthewMay1
    Matthew
    Lone Star Republic
    Still though, the detachable face for cheap cost seems hard to find
  7. Apr 19, 2016 at 10:41 PM
    #1927
    redrider58
    redrider58 KG7TBQ
    Tucson, AZ
    Silver DCLB 4x4
    Mods: Not enough
    If you are on a college budget, I'd go start out with a cheap baofeng HT to test the waters. If you know you want to further pursue ham radio, I'd find a mobile you'd like. And there ya have it, you have an HT and mobile rig. If you decide you don't want to put time into it, oh well, you paid $25 for a HT.
    Also, I would recommend looking on QRZ.com or eham.net to look at radio reviews and more abundant in depth material about anything ham radio.
    Crom and Chipskip like this.
  8. Apr 20, 2016 at 9:07 AM
    #1928
    MatthewMay1
    Matthew
    Lone Star Republic
    Thanks for the tips!
  9. Apr 20, 2016 at 9:19 AM
    #1929
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    http://www.avmap.us/products/terr/geosat_6_aprs-664/introduction
    I'm looking into pairing the 710 with this. I know Crom is all set but if other were curious this is apparently a great setup
    Crom[QUOTED] likes this.
  10. Apr 20, 2016 at 9:22 AM
    #1930
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    When I was in flight school we had a separate HT that only worked on aviation freqs. There was no regulation as a radio card is no longer needed to fly. Remember what ARROW in pre-flight. They have a very limited range though, but with that, I don't think they're very expensive.
  11. Apr 20, 2016 at 10:04 AM
    #1931
    MatthewMay1
    Matthew
    Lone Star Republic
    I want one that can do both normal ham frequencies as well as aviation frequencies, which seems hard to find because of what was mentioned before.
    If I got a handheld radio, could I run it to an antenna mounted on my truck to get better range?
  12. Apr 20, 2016 at 10:24 AM
    #1932
    Crom
    Nick
    San Diego, CA
    Millions
  13. Apr 20, 2016 at 11:19 AM
    #1933
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I do have an Avmap G6 APRS and they are taking feature requests for the G7 do out soon, prototype might be at Daytona. I have mine connected to a D72a HT. I will upgrade to a 710GA someday, but that is a long way off.
  14. Apr 20, 2016 at 11:36 AM
    #1934
    llibrm
    llibrm OH NOOOOOO!
    Bill
    I have an HT with an external antenna on my truck, but that is radio dependent
  15. Apr 20, 2016 at 11:46 AM
    #1935
    MatthewMay1
    Matthew
    Lone Star Republic
    What model radio do you have?
  16. Apr 20, 2016 at 11:52 AM
    #1936
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    He has an FT-60
    Adding an external antenna will increase your range, but you are still limited to 5w from the HT. You could add an amp to boost the signal, but then you are getting pretty close to the price of a mobile rig. HTs are good for in city near repeaters and on the trail with a convoy. They have decent signal LOS and can reach several miles, without obstacles.
  17. Apr 20, 2016 at 12:40 PM
    #1937
    redrider58
    redrider58 KG7TBQ
    Tucson, AZ
    Silver DCLB 4x4
    Mods: Not enough
    If you want to go with a nice HT and not a cheap baofeng, yaesu ft60 all day. It will RX AM frequencies, just no transmit.
    Chipskip likes this.
  18. Apr 20, 2016 at 12:51 PM
    #1938
    MatthewMay1
    Matthew
    Lone Star Republic
    Thanks for the tips, guys. Is it a common practice to add an external antenna onna truck for a handheld? I feel like that would make it real easy to then get a mobile unit later on if I want to.
    Chipskip[QUOTED] likes this.
  19. Apr 20, 2016 at 12:59 PM
    #1939
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Stepping stones. Yes, spending the money on a decent antenna, cable, and HT now and then later upgrading to a mobile rig is a very common practice. It's what I did, it's what @llibrm is doing right now.
    Crom and MatthewMay1[QUOTED] like this.
  20. Apr 20, 2016 at 1:02 PM
    #1940
    MatthewMay1
    Matthew
    Lone Star Republic
    Awesome, and will any of these handhelds be able to Rx the aviation bands?
