Amateur needing help with lift kit.
Discussion in 'Suspension' started by HSmith_11, Sep 19, 2016.
  1. Sep 19, 2016 at 10:03 AM
    HSmith_11
    HSmith_11 [OP] Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I recently got my first Tacoma ('01 ext cab 4x4). I want to put 33s on it but don't want to spend a lot of money on expensive lift kits. I don't do crazy off-roading besides a few trails here and there. Also, I don't mind a little bit of rubbing at full lock since I can deal with it. I am also planning on getting some steel black wheels if anyone has options for me (not too much $$). I was looking at the rough country 2.5" lift (I know it's not loved by many guys here) but I don't have much money and I have been busy with schooling. Thanks.
  2. Sep 19, 2016 at 11:30 AM
    HSmith_11
    Hunter
    Madison, Va
    Anyone? :(
  3. Sep 19, 2016 at 11:32 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
  4. Sep 19, 2016 at 11:36 AM
    Trachito
    Trachito Well-Known Member
    New Orleans
    I paid $280 for my simple lift on my 05, and I did the work myself. It was a Toytec AAL setup with 2.5" spacers up front and 2" leafs in the rear. With that, I was able to install 33's, but I still had to cut down the cab mounts. I also don't do any crazy off roading.
    One thing, the Toytec leafs are very rough and stiff. about 4 years after installing them, they both broke, although it didn't affect my ride much; it stayed stiff. I recently installed leafs from SD Truck Springs and they are so much smoother. They have good systems as well. http://www.sdtrucksprings.com/index...1&make_select=654&model_select=8688&x=83&y=11
  5. Sep 19, 2016 at 11:38 AM
    HSmith_11
    Hunter
    Madison, Va
    I'm really new to this whole lifting experience so some tips and some more explanations would be very helpful. Thanks.
  6. Sep 19, 2016 at 11:42 AM
    Trachito
    New Orleans
    The kits come with instructions. There are a lot of vids on youtube as well. The real pain is gonna be compressing the springs manually unless you can find a shop that can do it for you.
  7. Sep 19, 2016 at 12:10 PM
    TexAggie
    Eric
    Houston, TX
    OME Lift
    Front
    Spacers- (1"-3") - cheapest and easiest. Goes between the coil and top mount. This lift will make your ride rougher.
    http://toyteclifts.3dcartstores.com/TAC2--2-Front-Spacer-Kit_p_305.html#
    Coil and strut- (2"-3") - brand new coil spring and strut that are obviously longer than stock, will give you stock like ride quality.
    http://toyteclifts.3dcartstores.com...il-Overs-955-04-Taco-96-02-4Runner_p_994.html
    Rear - all rear lift options require new shocks
    Block- a block of aluminum that goes between your leaf springs and the axial.
    http://toyteclifts.3dcartstores.com/BK-2--Rear-2-Block-Kit-includes-U-bolts-_p_1136.html
    Add a leaf- a single leaf spring that you add to your stock springs
    http://toyteclifts.3dcartstores.com/TAC-AL-LA--Rear-ToyTec-Add-A-Leafs_p_303.html
    Leaf pack- completely new leaf springs that you replace your stock ones with
    http://toyteclifts.3dcartstores.com/Old-Man-Emu-rear-springs-with-bushings-98-04-Tacoma_p_144.html
  8. Sep 19, 2016 at 12:13 PM
    hunglikebuffalo
    hunglikebuffalo Member
    Andrew
    MD
    2015 Black Tacoma TRD Sport
    Toyota devil horns emblem Plasti dipped emblems 2in Rough Country Leveling Kit Nitto Terra Grapplers G2 265/70/17 with MONSTER II Wheels by XD Series
    I did the rough country 2in front level kit, I have no issues with it, but you can only run 32s with it
  9. Sep 19, 2016 at 3:09 PM
    Stakoner
    Stakoner Well-Known Member
    Santa Cruz ca
    2013 Dcab 4x4
    Alot
    Pro comp spacer kit. It comes with spacer in front and blocks gor rear. 150
