Amaz - Water Stain Remover
Discussion in 'Detailing' started by Lexxx_2011, Sep 19, 2010.
  1. Sep 19, 2010 at 12:48 AM
    Lexxx_2011
    Lexxx_2011 [OP] Active Member
    South Mississippi
    2011 DC TRD Off-Road Magnetic Grey
    Who has used it and how was your experience with it? Thanks.
  2. Sep 22, 2010 at 8:37 AM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    I've used it and it works very well. I was skeptical at first, but when a buddy used some on his '68 Camaro restoration that had major water spots on the windows and cleaned them all off. Make sure you use the white scruffy pad too.
  3. Oct 5, 2010 at 5:21 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    I've used it. I first used it on an 88 bronco II. It cleaned up 20 year old windows pretty well.
  4. Nov 18, 2010 at 9:18 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Before you go buying anything gimmicky or late night (i've never heard of amaz.. but it sounds hokey)... just go to napa and buy theirs. Pick up a bottle of their glass polish while you're at it.
    I think its called duragloss 505. Believe its a napa brand. Its the only thing Ive found that will take off the concrete that is our water.
    For windows the only way to go is with an abrasive glass polish. Makes anything like new in a few wipes..
  5. Dec 15, 2010 at 3:23 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I had been useing Amaz the last couple years and it seemed to do a pretty good job but was alot of work. The other day I picked up a bottle of Malco water spot remover at a automotive painting supply store...it's easier to put on than Amaze and completly removes water spots. The stuff is more of a liquid paste with light grit. If you ever see it give it a try...you won't be dissapointed!!
    http://www.paulsdist.com/catalog_i11324009.html?catId=203593
