Amazing deal on Steel Braided Brake Lines!
Discussion in 'Automotive Group Buys' started by OCTaco, Jun 11, 2010.
  1. Nov 10, 2015 at 11:16 AM
    #2001
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Yup Frankenscivvies
  2. Nov 10, 2015 at 11:24 AM
    #2002
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    ur lift parts arrive yet?
  3. Nov 10, 2015 at 11:29 AM
    #2003
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :laughing: that is similar if not the same as one he has used before
  4. Nov 10, 2015 at 11:30 AM
    #2004
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Some are supposed to be here today and Thursday. Saturday is the day for the complete install including ECGS bushing
  5. Nov 10, 2015 at 12:07 PM
    #2005
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    for that bushing is that bc u assume it will be a problem or what?
  6. Nov 10, 2015 at 12:10 PM
    #2006
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Already vibrating bro truck has been at 1.75 of lift in the front since new and now I am at 17,500
  7. Nov 10, 2015 at 12:16 PM
    #2007
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    gotcha, ive been in trucks lifted 3 inches with no cb drop or shims or bearing problem. Is it really noticeable? do u feel it or hear it or what?
  8. Nov 10, 2015 at 12:24 PM
    #2008
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    As far as the carrier bearing and shims. I have added it to my last 2 Tacoma without issue. I would rather have to remove it after if not needed
  9. Nov 10, 2015 at 12:26 PM
    #2009
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    gotcha but this ecgs bearing can u feel it or hear it? i chalk alot of it up to its a truck and it makes noise>?
  10. Nov 10, 2015 at 12:50 PM
    #2010
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Got my lines in! Thanks JP!:cheers:
    Crom, Unchained 5150 and Rattletrap66 like this.
  11. Nov 10, 2015 at 12:51 PM
    #2011
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :woot:
  12. Nov 10, 2015 at 1:14 PM
    #2012
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You can feel the slight hum
  13. Nov 10, 2015 at 6:12 PM
    #2013
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
  14. Nov 10, 2015 at 6:18 PM
    #2014
    sect0r
    sect0r Well-Known Member
    Oregon
    14 TRD Sport
    King Mid Travel, BAMF w/ 12" King's, ect
    Yay! They're going on on Thursday!
  15. Nov 13, 2015 at 5:52 PM
    #2015
    Azazruk
    Azazruk Well-Known Member
    NJ
    Fellas hope y'all can help me out here with what I imagine is an easy question. I have some lines on order from JP so while I'm waiting I figure getting familiar with the procedure is paramount. My concern is when disconnecting the lines what prevents the fluid from completely draining from the system and possibly causing damage to the ABS control. Is this just me being overly cautious or is there a technique that someone could share.
    Thank you
  16. Nov 13, 2015 at 7:11 PM
    #2016
    GHOST SHIP
    GHOST
    I just did mine today. I used a small piece of rubber hose capped with a bolt to stop the fluid from leaking out while changing out the lines. It still got messy, but minimized fluid loss. Couldn't tell you the size as I got all that stuff from a junk drawer in my toolbox, but I can tell you that it's smaller that the stopper from your oil filter drain on your engine. Worst case scenario, just be quick about it. You're going to lose fluid no matter what, but this helped me.
  17. Nov 13, 2015 at 7:16 PM
    #2017
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    You don't lose that much fluid to have to do anything extra. Simply pull the old one off and put the new one on then do the next one. Spray down whatever got brake fluid on it with brake cleaner then bleed the brakes and add brake fluid when needed.
    Mothman likes this.
  18. Nov 14, 2015 at 4:25 AM
    #2018
    Azazruk
    NJ
    Thank you that is encouraging feedback
    Rattletrap66 likes this.
  19. Nov 14, 2015 at 5:29 AM
    #2019
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Welcome man, if you run into any issues, feel free to pm me
  20. Nov 26, 2015 at 2:47 PM
    #2020
    Velonici
    Velonici Member
    Mesa, AZ
    04 4Runner 4.7L
    PM sent about getting a single line.
