Amazing deal on Steel Braided Brake Lines!
Discussion in 'Automotive Group Buys' started by OCTaco, Jun 11, 2010.
  1. Mar 19, 2015 at 11:21 AM
    #1721
    OCTaco
    OCTaco [OP] Well-Known Member
    OC
    '16 TRD Sport DCSB
    :thumbsup:
  2. Mar 19, 2015 at 11:30 AM
    #1722
    Adamar85
    Adamar85 Well-Known Member
    Adam
    Baker City, OR
    22 Ford F350 Lariat
    Wow, super fast turn around time! Thanks for the awesome deal, looks like they will arrive tomorrow!
  3. Mar 19, 2015 at 12:10 PM
    #1723
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Hi all.
    Can I get a set for my 2003 tacoma with 3" lift and tundra caliper mod?
  4. Mar 20, 2015 at 7:48 AM
    #1724
    OCTaco
    OC
    '16 TRD Sport DCSB
    Hi,
    Yes, I can definitely set you up with those lines. I'll shoot you a PM shortly.
    JP
  5. Mar 20, 2015 at 7:10 PM
    #1725
    AKK
    AKK Well-Known Member
    Alexis
    Santa Barbara, CA
    2014 TRD Off-Road
    Am I doing this right?
    Got em! Thanks a ton once again
  6. Mar 20, 2015 at 8:45 PM
    #1726
    Adamar85
    Adam
    Baker City, OR
    22 Ford F350 Lariat
    Got my lines today, thanks so much! Exact length I requested!
  7. Mar 21, 2015 at 4:51 AM
    #1727
    tacooh
    tacooh Active Member
    Brad
    SW Ohio
    '10 S/C Prerunner TRD Sport
    Got the lines yesterday. They look great. Now to find some time to install. Thanks JP!
  8. Mar 21, 2015 at 6:05 AM
    #1728
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    Got my lines in yesterday
  9. Mar 21, 2015 at 4:21 PM
    #1729
    Pigpen
    Dan
    Northwest Montana
    I should have looked today. I'll check tomorrow on my way to work.
  10. Mar 22, 2015 at 4:35 AM
    #1730
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Red lines w/heatshrink in 24 in length for the rear and 3" lift front. For an 06 Taco DCLB
  11. Mar 22, 2015 at 4:50 PM
    #1731
    Silver PreRunner
    Silver PreRunner Well-Known Member
    Justin
    Buda, Texas
    07 PreRunner Tx Edition
    Aem Bruteforce "Cold"Air Intake, Aero Turbine, Satoshi Grillcraft, 3k Fogs, Led Halo Lights, Led Tail Lights, Oem Roof Rack, Camburg Spindles, All Pro Leaf kit with Timbrens, Rear Fox Shocks, Konig CounterSteers, Nittos 285s, Kenwood Single Din
    Got my lines in on Friday !!! Just ran into a little error sent a message to op but aside from all that the lines are top of the line :)!
  12. Mar 22, 2015 at 6:37 PM
    #1732
    Velonici
    Velonici Member
    Mesa, AZ
    04 4Runner 4.7L
    Hey JP, I was wondering if I could get an update on my lines? I looked at my tracking info and it hasn't updated.
  13. Mar 23, 2015 at 11:51 AM
    #1733
    AnchorCop
    AnchorCop Well-Known Member
    Arizona
    13 TRD DCSB 4x4
    Same as above.
  14. Mar 23, 2015 at 1:41 PM
    #1734
    OCTaco
    OC
    '16 TRD Sport DCSB
    Hi,
    I expect both of your sets to ship out today. I will keep you guys posted.
    JP
  15. Mar 23, 2015 at 7:22 PM
    #1735
    Pigpen
    Dan
    Northwest Montana
    Got a USPS notification that my lines are in my PO Box. might not get there for a couple days, but wanted OCTaco to know they're in. Thanks!
  16. Mar 23, 2015 at 11:44 PM
    #1736
    Machvii
    Machvii PEW PEW PEW
    Q
    Enumclaw, WA
    13 DCSB TRD Off-Road
    Can I get a set for my 2013 Tacoma TRD off road with 3 inch lift?
  17. Mar 25, 2015 at 7:31 AM
    #1737
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    Just coming back to review now that these have been on for awhile. Still working great (thank goodness). Good deal for some quality lines.
    Thanks again.:)
  18. Mar 26, 2015 at 11:36 AM
    #1738
    OCTaco
    OC
    '16 TRD Sport DCSB
    Definitely! I'll shoot you a PM shortly.
    JP
  19. Mar 27, 2015 at 5:51 PM
    #1739
    Velonici
    Velonici Member
    Mesa, AZ
    04 4Runner 4.7L
    Any update?
  20. Mar 29, 2015 at 7:08 AM
    #1740
    Pigpen
    Dan
    Northwest Montana
    I finally got back to my PO Box and picked up the lines. Yesterday I installed them. I had some minor complications, but they're in and I'm happy. Thanks OCTaco!
    Just a little info on my complications in case anyone else runs into this...
    OCTaco posted that his friend who makes these lines ran out of fittings, which delayed sending out some sets of lines. He must have added different fittings to my front lines to just get them out since I was part of the batch that got lost in the mail.
    I didn't take any pics, but the fittings on my front lines had a different end where the clip holds them in the bracket. The issue was that the fitting didn't protrude through the bracket far enough to affix the retainer clip. This issue was solved by simply filing a small part of all four fittings to allow them to fit through the bracket. This actually made them reach further through than they should, so I had to bend the retainer clip in order for it to do it's job properly.
    I definitely want to make the point that this modification was easy to do and has no effect on the functionality of the lines. I just want people to know there is a simple fix in case they find themselves with the same situation.
    My brakes now feel slightly firmer. With my lift and going to bigger, heavier tires I am very happy with these lines.
    Thanks again OCTaco!
    unsubbed
