Amazon replacement headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timmy2112, Sep 7, 2013.
  1. Sep 7, 2013 at 3:50 PM
    timmy2112
    timmy2112 [OP] Well-Known Member
  2. Sep 7, 2013 at 4:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The Depo brand is pretty good.
    Body shops will generally use Depo if the customer doesn't want to pay for OEM.
    The pattern from Spyder is horrible... stay away from them.
  3. Sep 7, 2013 at 5:19 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    How about the Anzo lights? Any good? Can't seem to find the Depo's that fit my 2011.
  4. Sep 7, 2013 at 5:23 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
  5. Sep 7, 2013 at 6:18 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I just posted two links ;)
  6. Sep 7, 2013 at 6:28 PM
    ajw1986
    ajw1986 Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    I just put in black CCFL spyder halo's and the pattern is good from them, i guess it's just personal preference
  7. Sep 7, 2013 at 6:30 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Can you do a retro or BHLM using Depo lights reasonably well or are OEM lights the only way to do it right?
  8. Sep 7, 2013 at 6:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The projectors may be better, but I put a set of halogen Spyders on my wife's Rav4 to replace the yellowed OEM and the pattern is terrible.
  9. Sep 7, 2013 at 6:44 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    My retro was with Depo housings.
    My OEM housings from '08 were starting to cloud up a bit, so I figured I'd just get a new set and mount the projectors in them.
  10. Sep 7, 2013 at 6:45 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Being that it's from Amazon, you're pretty much safe if they suck. Amazon has pretty incredible customer service.
  11. Sep 7, 2013 at 7:09 PM
    Glueman
    Utah
    The Plague....
    Same here (cloudy lenses), so was considering doing a BHLM and retros with new DEPO ( a bit cheaper than OEM) but wasn't sure if they came apart as easy as OEMs.
  12. Sep 7, 2013 at 7:25 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    They're identical... like they could have been made from the same molds.
    3 (or 4?) small screws, cook them up, separate a bit, disengage the clips, and they open right up.
  13. Sep 7, 2013 at 7:37 PM
    Glueman
    Utah
    The Plague....
    Thanks for the info Rich...much appreciated.
