Amazon wiring harness for light bar
Discussion in '1st Gen. Tacomas (1995-2004)' started by Evan 213, Jan 14, 2017.
  1. Jan 14, 2017 at 1:34 PM
    Evan 213
    Evan 213 [OP] Member
    Evan
    01 sr5 trd
    2.5 inch lift in the front, 2012 Trd stock rims, flowmaster super 10, Camper Cover
    Where do I mount the relay on a 01 Tacoma with a Amazon ligt bar wiring harness, please show some pics if you can.
  2. Jan 14, 2017 at 1:54 PM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    you can mount the relay anywhere its convenient, doesn't have to be anywhere special
    Yotamac likes this.
  3. Jan 14, 2017 at 2:00 PM
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    Those harnesses come with a ton of extra wire. Coil up the extra wire and tuck it away from any hot or moving parts. Bolt the relay on the inner fender and your all good.
    When you have more then one wiring harness is can get messy.
    Scoobarooo likes this.
  4. Jan 14, 2017 at 2:41 PM
    Evan 213
    Evan
    01 sr5 trd
    @Yotamac with the battery when I loosen the negative and it has jiggle room the alarm goes off anything I can do to prevent it.
  5. Jan 14, 2017 at 2:46 PM
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    If you need to work on the electrical then just take it off completely. Otherwise i usually just keep the alarm remote in hand to shut it off quickly.
