amber day time running lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bentmetal, Jul 2, 2014.
  1. Jul 2, 2014 at 10:45 PM
    bentmetal
    bentmetal [OP] Member
    oregon
    2012 tacoma
    I have a 2012 Tacoma that I took to the dealer today for service and a recall . and ask about turning the daytimes off . so here's the deal. So after the service writer looked into this since the truck was made in Canada , no software to turn them off, but if the truck is a U S model , daytimes come turned off. and this is mandatory in Canada for new trucks to have daytime running lights , SO what the _ _ _ _ I'm not in CANADA:sorry: SO how do I do this without cutting wire in the fuse block ? THANKS
  2. Jul 2, 2014 at 10:48 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    They make tacomas in Canada now? Last I recall it's still made in Texas and Baja Cali :notsure:
    Why do you want it off?
  3. Jul 2, 2014 at 10:53 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Tacomas for US and Canada are made in Texas.
    Did you buy the Taco used in the US?
    Dealer must have brought in a Canadian tacoma to satisfy demand, or did a trade-in.
    Probably could change out the steering wheel stalk switch for the lights from Canada to US model. I wouldn't be surprised if the wiring is all there.
  4. Jul 2, 2014 at 10:54 PM
    bentmetal
    oregon
    2012 tacoma
    just going by the dealer word , I guess I'm just ole school
  5. Jul 2, 2014 at 10:56 PM
    bentmetal
    oregon
    2012 tacoma
    what about a different relay , or is that an option
  6. Jul 2, 2014 at 11:39 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So , wait
    Your odometer is in km and the mph is on the inside of the speedometer display or what
  7. Jul 3, 2014 at 12:15 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Relay and a shorting plug.
    Disconnect your harness and relay, new relay plugs directly into the back of the fuse box and the shorting plug goes in below it.
    But I don't know if the shorting plug is available for the '12+
    Might be able to get away with replacing the dimmer stalk... probably a $100 part. The US trucks have a 3rd position to kill the DRL.
  8. Jul 3, 2014 at 12:16 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    He's got a '12.
    The DRL-off option did not appear on the stalk in the US until '13 or '14
    His dealer is blowing smoke up his ass, but the end result is the same... he can't shut the DRL off without a mod.
  9. Jul 3, 2014 at 4:59 AM
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    Thats funny i was wondering about this the other day. Mine has the amber day time marker lights but every other Tacoma i pass on the road dosent have them. Is this something that kind of rare or year specific. Mine is a 2012 as well. I dont care if mine can be turned off or not just curious.:D
  10. Jul 3, 2014 at 6:19 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    My '13 has amber DRL and I can turn them off on the stalk.
  11. Jul 3, 2014 at 8:57 AM
    OZ-T
    Peter North
    British Columbia
    I get all that , just saying it's highly unlikely he has a Canadian truck
  12. Jul 3, 2014 at 11:01 AM
    RCKT82
    RCKT82 Well-Known Member
    Mid-West U.S.
    2013 PreRunner AC SR5 V6
    Have you tried filling the tank up with maple syrup? Maybe the DRLs are just a way for your taco to display syrup withdrawals....
  13. Jul 3, 2014 at 11:25 AM
    OZ-T
    Peter North
    British Columbia
    ahahaha , that's so original , hahaha
  14. Jul 3, 2014 at 5:54 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I modified mine for tequila.
  15. Jul 4, 2014 at 12:18 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That was my point.
    He doesn't have a Canadian truck.
  16. Jul 4, 2014 at 12:23 AM
    OZ-T
    Peter North
    British Columbia
    We agree
