Ambient temp reading stuck at 80 degrees.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fpradojr36, Sep 4, 2019.
  1. Sep 4, 2019 at 2:30 PM
    fpradojr36
    fpradojr36 [OP] Well-Known Member
    J.R.
    90804
    04 Prerunner, 2019 TRD 4x4
    Hi all. So I ran my 2019 Tacoma through the car wash and now all of a sudden my ambient temp sensor reading on the instrument cluster is reading 80. Outside it’s like close to 100. Before running it through the was it was reading pretty accurate. The reading did read to 81 when I got home, but something doesn’t seem right. I inspected the sensor underneath the hood and there doesn’t seem to be any visible damage. Anyone have any ideas or experiences with this issue?
  2. Sep 4, 2019 at 2:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    Warranty if it doesn't change back soon.
    If it does, you'll get the 'cannot replicate response, which may well be true.
    Best to present it to them while errant.
    Taco_Craig likes this.
  3. Sep 4, 2019 at 2:42 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    How long has it been "stuck" at 80?
  4. Sep 4, 2019 at 3:00 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Just as a fun aside, based on previous anecdotal evidence, when that sensor goes psycho and thinks it's like 10deg outside, it will disable your AC.
    So don't put off fixing it if you enjoy your AC.
    (Anecdotal evidence, single data point only, on a very odd failure, but still...)
  5. Sep 4, 2019 at 3:04 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I'm assuming Automatic A/C...you can run a partial diagnostic through the control panel.
    Maybe it'll pop a B1412/12 code.
    Flash1034 likes this.
  6. Sep 4, 2019 at 3:05 PM
    fpradojr36
    J.R.
    90804
    Thanks for the replies. If it doesn’t go back to normal by tomorrow I’ll make an appointment to get it checked out.
    It has been stuck at 81 now for about an hour. I haven’t driven it since I came back home, but it’s still at 81 and it’s like 96 here we’re im at.
  7. Sep 4, 2019 at 3:05 PM
    fpradojr36
    J.R.
    90804
    And the AC is working just fine as of now. The truck has 4400 miles.
  8. Sep 4, 2019 at 3:13 PM
    GreyBaldTaco
    2019 F150 5.0
    Go for a drive.
  9. Sep 4, 2019 at 3:31 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    This should help you
  10. Sep 4, 2019 at 3:36 PM
    fpradojr36
    J.R.
    90804
    Ah, thanks for that ktbell. I guess I can measure the resistance of the sensor, but I paid too much for this truck I’ll let the dealer do it lol. Thanks.
    ktbell444 likes this.
  11. Sep 4, 2019 at 4:39 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Sensor works off resistance, getting water in the sensor connection will change resistance. Since this happened after a car wash, my bet is you’ve got water in a connection or sensor housing. Wait for the water to evaporate and all will be fine. But it will happen again, if this is the case.
  12. Sep 4, 2019 at 4:50 PM
    fpradojr36
    J.R.
    90804
    Actually that was probably the issue because now the sensor is reading 100 which around what it is here in SoCal. Funny that I actually disconnected the sensor to check for any moisture and didn’t find any. I might have the dealer check it any how. Thanks for the replies, as always. Awesome forums!
  13. Sep 4, 2019 at 5:44 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    More than likely you got moisture in your sensor rather than in the connector. But wouldn't hurt to have them take a look at it just to be on the safe side.
  14. Sep 4, 2019 at 5:45 PM
    mutely
    Dealer won’t do shit unless it’s inaccurate when you take it in. So wash it exactly in the same way you did, before taking it in.
  15. Sep 4, 2019 at 7:55 PM
    fpradojr36
    J.R.
    90804
    I just made an appointment to have them look at it and then to do my 5k service since I’m there. And I will indeed run it through the wash again before taking it.
  16. Dec 27, 2019 at 1:56 PM
    cak
    cak Well-Known Member
    Palo Alto, CA
    2017 V6 4x4 SR5 ACLB
    I had similar problems with my sensor - not after a car wash, but after heavy rains/snow in Northern California, or, today, in heavy fog in Oregon. The outside temp indicator would go all over the place, the fuel gauge would act odd, and eventually the predicted range would to strange. This caused me to start using TRIP A to measure per-tank mileage. Until today, it has always returned to normal on its own.
    Dealer couldn't find anything wrong, of course, and now it's out of warranty.
    Today, not only weird ambient temp indication (for a while ---, then up in the 80s ranging over 100, which it definitely is not in Portland) and then the TSC OFF started coming on and off. And finally it apparently threw a code, lighting the CHECK light, and disabling cruise control ... and now, just to add to the fun, TRAC OFF is permanently on.
    I'm on a road trip, of course, so I don't have access to a scanner to read/clear the code. Sigh.
  17. Dec 27, 2019 at 2:04 PM
    GreyBaldTaco
    2019 F150 5.0
    Auto Zone can read it, disconnect the battery to clear it.
    cak[QUOTED] likes this.
  18. Dec 27, 2019 at 2:05 PM
    cak
    Palo Alto, CA
    Thanks! And what else will disconnecting the battery mess up? :)
  19. Dec 27, 2019 at 2:06 PM
    GreyBaldTaco
    2019 F150 5.0
    Mess up? Nothing. But I guess that depends on your definition of mess up.
  20. Dec 27, 2019 at 2:07 PM
    cak
    Palo Alto, CA
    Well, in older days, disconnecting the battery would reset the ECM, reset the stereo, etc...
