Ambient temperature sensor
Discussion in 'Technical Chat' started by Alperuzzo, Feb 23, 2023.
  1. Feb 23, 2023 at 8:32 PM
    Alperuzzo
    Alperuzzo [OP] Member
    Alvin
    2016 Tacoma TRD extended long box
    I have discussed the issue with my service manager. In 2018 my Blind Spot Warning system failed. I elected not to have it repaired instead using the old tried and true method of “mirror, signal, shoulder check”. The service manager to my knowledge not knowing this asked if I use the BSW system because when that system fails its been known to effect other systems. Questions:
    Am I being handed a load of BS in preparation for a hefty repair bill?
    All of the fuses seem fine. Is there a relay that I should look at replacing just to get my heat and defrost working because its still winter here?
    Is there is a relay to replace where is it?
    Thanks
    Al from Whistler Canada
  2. Feb 23, 2023 at 8:35 PM
    Bishop84
    Bishop84 Well-Known Member
    It's independent of everything, BSM is blindspot and rear traffic alert. Thats it. It doesnt affect anything else.
    If the mirror defrost isn't working, its likely another symptom of a mirror connection issue.
    The early 3rd gens had issues with BSM radar modules and connections on the harness.
    I wouldn't fix it either, very expensive and if you don't need it. Just turn it off.
    doublethebass likes this.
  3. Feb 23, 2023 at 8:49 PM
    Alperuzzo
    Alvin
    Thank you. Do you have a work around to get my climate control system working? I can't heat or defrost my truck and it's -12 Celsius
  4. Feb 23, 2023 at 8:51 PM
    Bishop84
    That would need proper diagnoses, typically its a jammed motor on the HVAC unit, scan tools can tell you which one, but you need a licensed scanner that can read Toyota specific codes.
    Best thing you can try is to disconnect battery, let it sit and see if it fixes itself.
  5. Feb 23, 2023 at 9:36 PM
    Alperuzzo
    Alvin
    thank you I'll try that tomorrow and will let you know. What do you recommend?
