American Motorsports is a rip off
Discussion in 'Long Travel Suspension' started by AmeriMotor, Jun 24, 2012.
  1. Aug 22, 2012 at 9:15 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    I am sure its plenty safe, do you think they are crappy welders using thin material?
    I am sure it will be plenty strong, I have seen parts from them before and they arent unsafe by any means, its the driver in the end that determines safety, lol. Anything can be broken if your a douchenozzel.
    The products I have seen were built very beefy and failure wasnt something that came to mind when seeing them, look at the other products before you start pointing the finger to get an idea of what type of work comes out of there.
  2. Aug 22, 2012 at 1:41 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    Im not talking about material used or quality of welds. I have been to brians shop many times. Quality of workmanship was never an issue. I was the guinea pig for the 5 lug lift spindles. The only thing im pointing out is if your going to sell a product to someone it should be tested and proven before saying it is ready for orders. My situation was different because i knew what i was getting into as far as trial and error. But if your going to advertise a product and say its ready it should be tested and proven not sell it to someone then work out the bugs after the fact. The spindles were installed on my truck countless times. Yea they worked on paper but we ran into many other problems that were only seen when installed and did not allow me to drive my truck leaving the spindles useless. So id hate to see someone buy this kit without it even being tested first. Then they run into problems and have there daily driver inoperable. I wasted hundreds of dollars on hardware, gas, time, bearings etc. and there was no final product as a result.
  3. Aug 22, 2012 at 3:32 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    I was not there when Brian was using your truck as the first test run of the spindles so I cannot say much about it.
    Since I have been there we found a lot of problems with the factory parts and how much of a pain it is to keep the stock parts in order to run the spindle.
    The time constraint was an issue because we were trying to get them to work with the TC UCA to save money for customers. The plan was to get the truck together, test it on a few trails around here and then let the customer take it home and test it to see what their thoughts on it would be. But as mentioned earlier we ran out of time because we wanted to have it work with the TC UCA's as well as with our UCA's, except we found it doesn't work with TC UCA's unfortunately.
    There isn't a guinea pig in this when the customer knows that it's still developing or in prototype stages, since we now found a working setup and know it works.
    To finalize we know it cycles great with our UCA's and allows a clean amount of travel with 0 bump steer. So to sum it up, yes mistakes have been made, money has been used but a product ready to take some abuse has been designed.
  4. Aug 22, 2012 at 4:28 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    I look forward to seeing it on a truck getting some miles, until then...
  5. Aug 22, 2012 at 11:08 PM
    noSKills858
    Alex
    Poway, CA
    Don't worry, I totally agree with your skepticism, but we'll make sure it'll handle over abuse.
  6. Aug 24, 2012 at 6:49 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    are we at a point where we have a ETA?
  7. Aug 24, 2012 at 9:15 AM
    AmeriMotor
    AmeriMotor [OP] Well-Known Member
    Vista
    Offroad Fabrication
    I build kit for different year trucks and different brands (ie. Toyotas, fords, chevy trucks) from full size to mid size trucks. I dont own every truck to "test out" my product. neither does camburg, total choas, solo motorsports, SRD. I dont and cant so we build a kit prototype it on the truck cycle the suspension, check for any issues. Then it gets transfered to CAD for each part to be drawn in 3d. This makes water jetting and CNC bending easier. So there is no CAD prototyping here. Only on the truck. Then we build it and put it on a truck. Either mine or a customers. The customer is informed about the prototpye being done and they are fully aware what they are getting into. BUT the customer gets a killer deal on parts and no labor fees. So they are paying for a product that is at cost and i always throw in a bumper to sweetin the deal. On David's 5 lug with the lift spindle i was building the spindles to work with toal choas upper arms. I was trying to make a lift off of their suspension engineering. Making it safe and reliable and cost effective. You all want bad ass build parts but you dont want to pay for them. I get it but there is a lot that goes my kits and parts. I built 3 different sets of spindles for davids truck and it still didnt work. Im still working on them and i will continue to untill i get them right. David did spend a lot of his extra money driving down and parts. Problem 1 he lives 3 hours away. Not an easy fet. He did have a lot of tme into this process. What he and most of you dont understand is i spend 60 hours into these spindles to this point 5000 in material, CAD drawnings and changes, water jetting fees, bending fees, machining hubs and new bearings. So its just not a time or money issue for the customer it is for me too and my business. David backed out of the prototype design phase and i gave him his money back. Its ok. no big deal. Point being this is a process that will always be changing and evolving. Ive installed 3 98 5 lug tacoma long travel kits and im still changing little things to better my kits. I dont feel its perfect and it can always be better. Thats whoi am and how i do things. I cant say the same for other companies. I need guys like david who are willing to prototype kits and parts out for me. This kit has been prototyped and its ready for a customer to go put some miles on it. Who is ready ?
  8. Aug 24, 2012 at 9:22 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    THIS ^^^^
    People good things take time and high quality parts have a high quality price ;)
  9. Aug 24, 2012 at 10:35 AM
    disc0monkey
    I wish I could help. Maybe I can but you might not be up for a long distance relationship. I'm an EE with minor fab skills and lots of ME friends that were on the formula team back in school if that makes any difference.
  10. Aug 24, 2012 at 11:41 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    gotta pay to play!
  11. Aug 24, 2012 at 3:24 PM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    What are the requirements to test the prototype? :D
  12. Aug 24, 2012 at 5:49 PM
    noSKills858
    Alex
    Poway, CA
    Let us borrow your truck so we can make sure everything is how it should be.
  13. Aug 26, 2012 at 7:53 PM
    AmeriMotor
    Vista
    Offroad Fabrication
    Let me clarify that last answer. I work out a time that i can use your truck to bolt on the prototype kit. We then cycle the suspension make sure there arent any clearance issues, the suspension cycles without any bumpsteer. I then put your truck back together and give it back to you. The prototype parts then get CAD drawn and then waterjet and CNC bend before welding in a fixture. I dont like using the prototype arms and spindles for testing, I get the kit in a finished (final sale able state, just like it would be when i sell it). This gives me a final mockup and test fit before we finalize the CAD work and make any final few changes. After that we bring your truck back and we bolt the kit on and get you off to the alignment shop for alignment and readings to see where the kit stands to stock specs. Then you just drive on it give me feed back and any problems you incounter.
  14. Nov 30, 2012 at 5:56 PM
    Chakaplaka
    Chakaplaka Well-Known Member
    Todd
    Napa
    F.E.A.R.
    UMMM WTF 6" OF LIFT!!! dude i am going to request some time off and drive my white ass down to socal to do this man....
  15. Dec 6, 2012 at 10:19 AM
    #35
    Chakaplaka
    Todd
    Napa
    F.E.A.R.
    Hey Brian,
    I am going to call you today.... As I said I want this mid travel kit.... Will this work with my ICON Coils????
    Those would really accent my 5 lug super well
  16. Dec 6, 2012 at 4:25 PM
    #36
    Chakaplaka
    Todd
    Napa
    F.E.A.R.
    Hey Brian I called you today and left a voicemail.
    Hit me up ASAP.
    EDIT: Thanks for the quick response! Can't wait!
  17. Dec 7, 2012 at 11:50 AM
    #37
    Chakaplaka
    Todd
    Napa
    F.E.A.R.
    Yo people no need to worry! I am buying the kit and be the first mobster to nut up and enjoy some 6" of additional ride height!
    I'll let y'all know how it works.
  18. Feb 19, 2013 at 8:25 AM
    #38
    dcvt16
    dcvt16 Well-Known Member
    Ehren
    SFV, CA
    MGM Supercharged long travel 5lug
    Total Chaos 5 lug long travel kit, Fox coilovers. Mcneil fiberglass. Defined engineering sua, 14 in kings, Defined shock hoops rear. Weathertech digital liners and vent visors. Paint match grille and added fogs. 4.56 gears, detriot truetrac LSD (gear type), LCE header, URD 2TR supercharger.
    Any updates here?
  19. Feb 19, 2013 at 7:09 PM
    #39
    AmeriMotor
    Vista
    Offroad Fabrication
    very soon
  20. Feb 19, 2013 at 11:46 PM
    #40
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Fuckin.
    Killin.
    Me.
    :D
    I tries to call you monday. I try again today!
