American Outlaw Rims for Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBlood9, May 30, 2011.
  1. May 30, 2011 at 12:27 PM
    JBlood9
    JBlood9 [OP] Well-Known Member
    Jordan
    Baton Rouge
    Black 08 SR5 PreRunner
    Pesonal LSU plate. Flowmaster 40 Series BFG A/T KOs on TRD rims AFE Cold Air Intake (Pro Dry S) Weather Tech Digi Fits Sportsman Camo Shadowgrass custom seat covers. Custom Trailer Hitch receiver flag pole. Front and back matched tint. AVS rain guards. Pioneer CDE 123 head-unit. Derped Rims and Rear Bumper. Yellow Badges.
    I'm thinking about buying some american outlaw rims with master craft at's. What is the bolt pattern of an 08 4 door 2wd tacoma? i checked the diagram in the wheels and tire forum but didn't see specifics for my truck. Can anyone shed some info on this? thanks.
  2. May 30, 2011 at 12:29 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    6 on 5.5 (139.7)
  3. May 30, 2011 at 12:42 PM
    JBlood9
    Jordan
    Baton Rouge
    alright thanks. I thought it was 6 on 5.5. Just wanted to see the 139.7. The guy i would be buying from said they came off a chevy but would fit a tacoma. I believe he is right but dont want to risk it too much.
  4. May 30, 2011 at 12:44 PM
    KPT
    09 Prerunner
    Nope he is wrong. Chevys have a much smaller hub bore. If the wheels are chevy-specific then you would need to get the hub bore enlarged in order for them to fit your Tacoma.
  5. May 30, 2011 at 12:52 PM
    JBlood9
    Jordan
    Baton Rouge
  6. May 30, 2011 at 12:56 PM
    KPT
    09 Prerunner
    Yeah like you said the bolt pattern is fine. But the hub bores are definitely different. Toyota-specific rims will fit on Chevys, but not visa versa. I would ask him to measure the hub bore on the rims. You need at least 106mm. Chevy hubs are somewhere around 78mm IIRC.
  7. May 30, 2011 at 1:05 PM
    JBlood9
    Jordan
    Baton Rouge
    alright. Thanks for the info. I would have never measured that and been screwed.
  8. May 30, 2011 at 1:07 PM
    KPT
    09 Prerunner
    You're also going to want to know what the backspacing of the rims is. You'll want between 4.5" and 5.5" for those 265's.
    If he doesn't know it you can calculate it from the rim width and offset, both of which should be stamped on the back of the rim.
  9. May 30, 2011 at 1:11 PM
    JBlood9
    Jordan
    Baton Rouge
    the 4.5- 5.5 was about the only thing i knew. And i asked but he didnt know the back spacing so i guess i will be trying to calculate. but if the hub bore is off it doesnt matter either way because they wont fit.
  10. May 30, 2011 at 1:13 PM
    KPT
    09 Prerunner
    Yeah when you ask him to measure the hub bore, also ask him to send you and of the letters and numbers stamped on the back. You can post it up here and I can translate....
  11. May 30, 2011 at 1:22 PM
    JBlood9
    Jordan
    Baton Rouge
    sounds good. thanks man
  12. May 30, 2011 at 1:41 PM
    JBlood9
    Jordan
    Baton Rouge
    i just talked to the guy and he said the rims came with a spacer he put on that let it fit the chevy hub. so i could take that out because of the bigger tacoma hub. Is that legit/normal?
  13. May 30, 2011 at 1:51 PM
    KPT
    09 Prerunner
    Yep that is normal and good news for you.
  14. May 30, 2011 at 1:54 PM
    JBlood9
    Jordan
    Baton Rouge
    yeah, I had a sigh or relief when he said there were spacers to fit. he is going to text me the numbers off the back the rims tonight when he gets home so that is the last part up in the air. I'm going to try to get the package for $500 maybe $600 tops. I think that would be a good deal. Whats your opinion?
  15. May 30, 2011 at 1:55 PM
    KPT
    09 Prerunner
    I don't really know how much those go for but that sounds reasonable to me. :thumbsup:
  16. May 30, 2011 at 2:01 PM
    JBlood9
    Jordan
    Baton Rouge
    reasonable enough for a college student that pays his own bills! Anyway, thanks a lot for all your help. i really appreciate it.
  17. May 31, 2011 at 7:07 AM
    JBlood9
    Jordan
    Baton Rouge
    KTP, the guy sent me a picture of the numbers on my phone, but I can't post it here. Its pretty hard to see but it think it reads:
    6F481
    46X63 ? Its really tough to see. Do those numbers make any sense?
  18. May 31, 2011 at 7:11 AM
    KPT
    09 Prerunner
    No the stamping I'm talking about should read something like:
    "18x9JJ ET-12"
    That would mean the wheel is 18" in diameter, 9" wide, with a -12mm offset (which would be 4.5" backspacing in this example)
  19. May 31, 2011 at 2:33 PM
    JBlood9
    Jordan
    Baton Rouge
    alright, got the corrected print:
    6F481
    16x8J
  20. May 31, 2011 at 2:47 PM
    KPT
    09 Prerunner
    Alright I just got on the American Outlaw/Liquid Metal (same company) website.
    Those wheels are called the "Buckshot", and it appears there is only one chrome Buckshot wheel that is both the 6x139.7 bolt pattern and is also a 16x8 (which the stamping showed). That wheel has a -6mm offset, and is model #100-6883C.
    -6mm offset on a 8" wide wheel is 4.25" backspacing. Therefore, they should fit with those tires on your tacoma, without rubbing (maybe minor rubbing on the mudflaps but I wouldn't expect them to).
    That model # also shows a 106.25 mm hub bore, so you're good to go there too.
    http://www.liquidmetalwheel.com/wheel.cfm?id=479
    Now the only thing is that some brands of 16's rub the brake calliper on Tacomas. I would ask him if you can just bolt one up to check before you give him the cash.
