American Racing Mojave with Teflon (Series 3981)
Discussion in 'Wheels & Tires' started by k2pow, Apr 18, 2008.
  1. Apr 18, 2008 at 8:17 AM
    k2pow
    k2pow [OP] Active Member
    Valley Village CA
    08 Tacoma Silver 4x4 LB DC, SR5, deb
    Snug Top, Tint, American Racing Mojave Rims with BFG AT's, Icon Coilovers, Camburg UCA's, Wheelers rear springs, Icon Rear shocks with res, front diff spacer.
    So just ordered my ICON coil overs and Camburg control arms and want to make sure the American Racing Mojave with Teflon® (Series 3981)Part number 3981-6883 16x8 with 4 1/2 backside will work with this setup.. Was going to go with BFG All terrains 285/75/16 Anyone have this setup? Thanks in advance
    Kenneth
    08 Tacoma 74 miles, with a ton of crap pending arrival to my house.
  2. Apr 18, 2008 at 9:30 AM
    Big Guns
    Big Guns Well-Known Member
    Temecula, CA
    07 PreRunner SR5 4.0L Indigo Blue
    Aero Turbine 2525 exhaust, Black Headlight Mod, DO Rock Sliders
    They should fit if you don't have TRD sport.
  3. Apr 18, 2008 at 10:14 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    what would a sport have to do w/ the wheels/tires fitting that wouldnt also affect the offroad or prerunner base?
  4. Apr 18, 2008 at 12:30 PM
    k2pow
    Valley Village CA
    Yea, why would the sport have anything to do with it.. I am replacing the entire shock and spring and changing the UCA. Sounds like from another member who I have been PM'ing that I will need to trim the caliper but i am not too fond of that.
  5. Apr 18, 2008 at 2:23 PM
    The_Hodge
    SC
    i think that certain 16's would have probs w/ fitting over the caliper. not sure how the backspacing will affect that though
    CORRECTION: there is a guy on here w/ 15" mojave's, so the 16's will definately get over the calipers
  6. Apr 19, 2008 at 5:04 PM
    Big Guns
    Temecula, CA
    I had heard from some other posters that the 16" rim will rub on the caliper but only on the TRD sport. May have been some misinformation.
  7. Apr 19, 2008 at 6:21 PM
    The_Hodge
    SC
    the only suspension differences in the sport and the off road are thicker coils on the offroad and a thicker sway bay on the sport, i believe....besides the locker differences
  8. Apr 20, 2008 at 6:32 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    When I went to order my wheels from tirepackage.com they told me over the phone that steel wheels don't fit Tacomas due to the oversized calipers and 16" wheels don't fit the Sport for some reason. Gonna call my Toyota dealer and see if I can get the technical answer.
  9. Apr 20, 2008 at 9:39 AM
    The_Hodge
    SC
    roxspin72 has 16's on his sport, but they are dick cepek's that stick out a lil bit..and they arent steelies
  10. Apr 20, 2008 at 12:59 PM
    k2pow
    Valley Village CA
    Called a few places and they say it wont work. 4 wheel parts said you just pay 25 for the mount and balance and they will throw it on and test fit it. If they hit they will return them for you. When I called to order them they just said no way no how they will work and to just go with the 17's. Think that is what I will do since I am getting the whole coil over set up .
  11. Apr 20, 2008 at 6:15 PM
    The_Hodge
    SC
    well roxspin72 does have 16's on his sport. u might should PM him and see the exact specs of his rims, but they are definately 16's
  12. Mar 21, 2013 at 10:20 AM
    mm1ssdv
    mm1ssdv Well-Known Member
    2013 AC TRD OR
    SPC UCA's Fox Factory 2.5 coilovers CVJ high angle axles (9808TR) OME Dakar leaf pack +4" rear brake lines
    This thread is what shows up when you search for "ATX Mojave Tacoma" so I figured I'd post some relevant data.
    I just tried to install ATX Mojave (16" diameter, 8" wide, 4.5" backspace, 108mm hub bore, part number AX39816883) on my 2013 Tacoma TRD off-road and they didn't even come close to clearing the caliper. I'll have to install spacers if I want to use these wheels. Pretty disappointing, they look so damn good. I'm going to give the Discount Tire MB 72 a try.
    For the record these wheels weigh 25.3 lbs.
