Amp Challenged
Discussion in 'Audio & Video' started by korny351, Mar 30, 2010.
  1. Mar 30, 2010 at 9:28 AM
    korny351
    korny351 [OP] Well-Known Member
    Stockton, CA
    07 DCLB SR5 4X4
    Well, I've installed My JVC AHD-69 (20W RMS per channel) and a set of ID CTX65CS components in the front doors. Definite improvement over stock, mostly with the new JVC. Planning on the ID coaxials in the rear, no sub and a 4 channel amp to let the new speakers shine. Due to budget, I can only replace one component at a time. If I purchase the amp first, can I hook it up using only 2 channels to power the fronts and leave the other two channels sit until I can afford to get the rear speakers or is this a no-no. I could replace the rear speakers first, but because of the power requirements I don't expect much benefit until I amp the system. I'd like to go with the amp first to liven up the new components in the front.
  2. Mar 30, 2010 at 9:35 AM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    Sure! The amp will be fine until you get your new rear speakers.
  3. Mar 30, 2010 at 9:45 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    Yep, the amp will function just fine with only the front inputs receiving a signal.
  4. Mar 30, 2010 at 11:06 AM
    korny351
    Stockton, CA
    07 DCLB SR5 4X4
    Thanks for the quick replies. Time to research my amp purchase.
  5. Mar 30, 2010 at 11:27 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Make sure you wire it up for future upgrades. That way you don't need to do a tear down. Just plug and play.
  6. Mar 30, 2010 at 6:24 PM
    86ceeten
    Brian
    NW Florida
    Great advice!
