Amp cutting out from low power.
Discussion in 'Audio & Video' started by mrmumbels, Jul 7, 2011.
  1. Jul 7, 2011 at 8:13 AM
    mrmumbels
    mrmumbels [OP] Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
    Jl audio 1000/1v2 and 300/4.
    1/0 power n ground throughout
    99 Tacoma with the outlet in the bed so I believe that means I have the better alternator?
    Highs have been cutting out at high volume/bass since the first install. Headlights blink pretty bad.
    What should I do to fix it? Extra battery? Cap?
  2. Jul 7, 2011 at 8:22 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Check the condition of the charging circuit and of the battery. Cap will help.
    I don't know about a better alternator.
  3. Jul 7, 2011 at 8:27 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    If ANYONE says "big 3" I will cut you myself.
  4. Jul 7, 2011 at 8:28 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    But yes, the real fix is a better alternator.
  5. Jul 7, 2011 at 8:29 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    Why?
  6. Jul 7, 2011 at 8:30 AM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
  7. Jul 7, 2011 at 8:32 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    What's the amperage on this alt? 140?
  8. Jul 7, 2011 at 8:34 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    That's what 1/0 throughout meant.
  9. Jul 7, 2011 at 8:37 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Because it's a stupid non-solution that doesn't solve or do anything, ever. (As you just discovered.)
  10. Jul 7, 2011 at 8:37 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    Ouch, pricey unless I can trade in my current alternator.
  11. Jul 7, 2011 at 8:39 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Fair enough. I get very aggravated when people say "OMG DO THA BIG 3 LOL!!!11!1" when someone has a power problem.
    Upgrading wiring on your existing factory alternator and battery will do absolutely nothing, unless you have a corrosion problem or something.
  12. Jul 7, 2011 at 8:40 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Also, that alternator doesn't list its output? That's shady...
    But you can simply look at the maximum amperage from your battery / alternator and use that to find out what diameter wire you actually need by looking at a chart for the length of run you'll use.
    Hint: It's still probably not going to require 0/1 gauge, unless you simply like soldering with a blowtorch :p
  13. Jul 7, 2011 at 8:41 AM
    207Copper
    207Copper Well-Known Member
    South East Kansas
    08 V6 SR5 Quad Cab Red
    16"wheels, Bull bar, Side bars, Retrax roll top tonneau cover
    Cap is only good for short burst power then it has to recharge. I had a similar setup in my last car with a 500/1 and a 300/4 and with the factory 140amp alt it would pull the headlights almost out going down the highway. I installed a gel cell in the trunk (stinger yellow top) with an 80 amp charging relay and it solved the issue. After the battery went out (5-6 years) I put in a big cap 3-4 farad and it worked OK for short burst but would still dim the lights at night if you were pushing it hard. just my .02
  14. Jul 7, 2011 at 8:45 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Sounds about right. Batteries and capacitors both act as charge-storage devices, whereas an alternator will actually increase the power you generate, so you can solve it with any combination of these.
    Basically:
    - Capacitor will do like you noted. It stores some charge, but discharges very quickly (but also charges more quickly than a battery.) It sort of works for brief, intermittent, high power draws, but they don't work that great and honestly a 1F capacitor is so big it scares the shit out of me.
    - A second or larger battery will provide more continuous power than a capacitor, but it will still need to be charged. If the load from your amp is intermittent enough that it is able to charge more than is drawn on it, this should work fine. (And it sounds like this should be the case, based on the above...)
    - An alternator is the only thing that actually provides more power from the engine to your electrical system. Your battery should still be large enough to support what you're drawing, even with a larger alternator, but you'll actually be putting more power to your electrical system.
  15. Jul 7, 2011 at 8:50 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    How about a solar panel and a cap? :p
  16. Jul 7, 2011 at 8:50 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Hah! I like where your head's at.
