Amp help for Kicker subs
Discussion in 'Audio & Video' started by ajohnson225, Nov 10, 2014.
  1. Nov 10, 2014 at 6:16 PM
    ajohnson225
    ajohnson225 [OP] Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
  2. Nov 11, 2014 at 8:02 AM
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    Each sub is a 4 ohm, 400watt RMS rated woofer - which you will most likely want to wire in parallel, meaning you'll have a 2 ohm load overall, with 800rms handling, as you stated.
    A decent amp in the 600-800ish watt RMS range is actually not generally that expensive - just make sure that whatever you get is rated for a 2ohm mono load. Many of today's amps are - especially if you're looking at monoblock amps.
    Amp recommendations are always tricky, as a lot of brand loyalty usually comes in to play - so take everyone's recommendation with a grain of salt. Are you wanting to purchase from the same seller? If so look at the Kicker ZX line or the MB Quart RA1000.1 Even the Kicker Refurbished ZX stuff comes with a 1 year warranty - and the ZX line is typically a better product than the CX line. I'm not a budget amp buyer usually, so I'm looking at these based solely on specs.
    Otherwise, you might want to look around for
  3. Nov 11, 2014 at 1:01 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    800 Wrms amp that is compact in size to fit under the front seats can be tricky
    Ether go with an amp that produces same power between a range of ohm loads ( alpine and JL ) or get an amp thats normally rated at 1600-1800wrms @ 1 ohm @ 14.4 volts. This will give you roughly, but again depending on amp 800wrms @ 2 ohms.
    The amps i run are pretty much exactly that, their so small i can actually fit 2 under the passenger front seat and their rated 1800WRms@1 ohm
  4. Nov 11, 2014 at 2:30 PM
    adrenalnjunky
    I'd have recommended the JL XD 600/1 or Alpine PDR-M65- but the price isn't "break the bank" friendly.
  5. Nov 11, 2014 at 5:23 PM
    ajohnson225
    Austin
    Baton Rouge
  6. Nov 12, 2014 at 6:20 PM
    ajohnson225
    Austin
    Baton Rouge
    subs and box came in today, amp i don't think will fit in between. the hi phonics brutus 1100.1D i ordered, will it fit under seat?
  7. Nov 12, 2014 at 7:55 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    anything bigger than 14 will be very hard to make fit
  8. Nov 13, 2014 at 7:00 AM
    ajohnson225
    Austin
    Baton Rouge
    It's 14.4x10.3x2.5. Will that not fit under seat?
  9. Nov 15, 2014 at 3:01 PM
    ajohnson225
    Austin
    Baton Rouge
  10. Nov 15, 2014 at 6:44 PM
    adrenalnjunky
    It will probably protrude from under the rear of the the seat a bit. I have a power inverter under my driver's seat, it is 2.59" high and it fits under the seat, but there's only about 10-12" of legnth available before it starts poking out, and there's an ac/heat vent under the seat you'll have to deal with.
  11. Nov 15, 2014 at 6:52 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    you may be able to mount it side ways and run the power and ground under the centre console but i haven't checked that out yet.
  12. Nov 15, 2014 at 10:46 PM
    ajohnson225
    Austin
    Baton Rouge
    so dealing with the air vent, how do I deal with it? cover it, reroute it, or what?
  13. Nov 16, 2014 at 7:51 AM
    adrenalnjunky
    Honestly, I'm not sure - first you'll need to see how your amp lines up with it.
  14. Nov 16, 2014 at 8:00 AM
    bshell
    bshell Well-Known Member
    greensboro, ga
    G2 bakflip,step bars , weathertech mats, kenwood dnn700HD.
    Let me know how these sound with some install pics. I have looked at this on eBay and it looks like a good deal.
  15. Nov 17, 2014 at 6:01 PM
    ajohnson225
    Austin
    Baton Rouge
    This is what I've got so far. ImageUploadedByTapatalk1416276057.727121.jpgImageUploadedByTapatalk1416276069.126205.jpg
    Wires should be in tomorrow so install tomorrow or the next day depending on when they come in.
  16. Nov 17, 2014 at 6:40 PM
    bshell
    greensboro, ga
    Have you replaced any of your factory speakers yet.
  17. Nov 17, 2014 at 6:45 PM
    ajohnson225
    Austin
    Baton Rouge
    No. Just pioneer head unit. That's next on the list. The amp I believe I will be able to mount on the sub box but up on the elevated part so it sits at an angle
  18. Nov 19, 2014 at 6:23 PM
    ajohnson225
    Austin
    Baton Rouge
    Finished install. Sounds good! I ended up just mounting amp between subs
  19. Nov 19, 2014 at 6:38 PM
    bshell
    greensboro, ga
    That's awesome. I'd love to see the install pics.
  20. Nov 19, 2014 at 7:33 PM
    ajohnson225
    Austin
    Baton Rouge
    I'll snap some tomorrow
